48' walking floor trailer and firewood
Started by barniescamp, April 30, 2009, 10:53:48 PM
barniescamp
do any of you guys know or heard of anyone hauling firewood in a 48' trailer with a walking floor[ live deck ], I'm asking this because somebody asked if I could produce and deliver approximately 400-500  face cords of firewood and the only way I see getting this much wood delivered in a timely matter is with a 48' walking floor trailer but I don't know any body who ever did it without the wood being on a pallet. I don't like the idea of the wood getting hung up inside the trailer as 40 face cord would take awhile to unload by hand.
bkellyvtme
My father worked for an outfit that delivered wood that way. It did get hung up every now and then.
Sawyerfortyish
I don't think you can haul 40 cord in 1 trailer. Since a cord of green cut wood weighs 5000+lbs per cord 40 cords would weigh 200,000lbs+. Don't get pulled over by the dot.
I would think that most of the wood on a walking floor would unload and you may have to kick a few pieces off that didn't.
chucker
  ? 40 cords on a 48 foot trailer? you talking thirds as a cord or how do you measure a cord? 220000 pounds sounds just a little heavy to me ....
respect nature ! and she will produce for you !!  jonsered 625 670  2159 2171/28"  efco 147 husky 390xp/28" .375... 455r/auto tune 18" .58 gauge
chucker
  but to answer your question a live bottom farm wagon works good if you dont have far to go ... or maybe try a end dump ?
barniescamp
Sorry I ment face cord or 1/3 cord, I fixed the original post.
chucker
Gary_C
I would suspect that dropping firewood into a live floor trailer with a conveyor would be kind of hard on it. You could probably expect a lot of repairs and some unloading by hand.
If it was me, I'd look for someone to hire with a big end dump or one of those side dump trailers.
I wouldn't get to excited about big promises. That's a lot of firewood and don't forget firewood is just a commodity and they could get it from a lot of sources.
Ron Wenrich
We do it on an almost daily basis.  Our trailer is 40' and we use it for firewood and hauling bark.  We use live bottom trailers that clean out like farm wagons for sawdust.  In the winter, those things can freeze up and you get a bunch of damage.
We have used live bottom for firewood, and they work OK.  We used to load logs in the top and cut to length inside the trailer when the call was for cut and not split.  We have also put cut and split onto large piles and loaded trailers with knuckleboom loaders.  We no longer dry any wood in our yard.
We use a MultiTek processor, which goes onto a conveyor and is dropped into the walking floor trailer.  We load about 9-10 cords per load, and that's plenty heavy.
We've used the current one for about 4 years.  The last one lasted about 7-8 years before someone decided they wanted it more than we needed it.  They stole it right out of the yard.  Walking floor trailers are the preferred trailer for NY garbage haulers.
woodmills1
anyone else trying to make up a joke about the walking floor trailer that suddenly just walked away ??? :D :D :D
treecuttingsob
i have hauled wood in mine from missouri to arizona a lot of times works good but will hang form time to time just walk the flore forward when it happens then back again
Quote from: woodmills1 on May 01, 2009, 07:01:58 AM
No, but Ernest Tubb did a song about walking a floor that was probably in a trailer. ;D
isawlogs
Ok ya got me sthumped on the walking floor  ???   What is it .....  :-\
   Marcel
rebocardo
Like a conveyor belt loop for a floor.
Ron Wenrich
Not really a conveyor belt.  There are 2 types that I have seen.  Our web type is large chains on each side of the truck, and it has paddles that are welded to each side.  The chain is advanced, and the load comes off that way.  That's what we used to use for firewood.  We even put loads of logs in these.  We currently use this for sawdust.
The other type has a slated floor that runs lenghtwise in the trailer.  These move back and forth and moves the load from front to back.  This is the type we are currently using for firewood and mulch.
SouthernRumRunner
They are different type of walking floors. I use keith walking floors on my chip trailers.There is another company called Mac who builds  different type of walking floors. check this video out  www.youtube.com/watch?v=eiXIYtIFMyM&feature=related
I see there are no conveyor belts there.
Looks like it would work fairly well.  :)
rebocardo
This link explains the "continuous belt floor" aka conveyor belt system.
http://www.jgpress.com/BCArticles/2001/050170B.html
This is the Keith Walking Floor others have mentioned
http://www.keithwalkingfloor.com/stationary_agriculture.html
justintimemoto
my neigbhor uses a walking floor for doing round bails works allrihgt you got to help them a little bit but it does good
ms660 372xp 455 rancher
2006 suzuki rm 125 for sale
wi woodcutter
I have used a end dump trailer for hauling wood, it works good.
Just make sure you raise it nice and slow and be on level hard ground.
2-066's ms660 034av 076av huskee 27ton splitter CB5036
A guard dog needs food, water, shelter, walking and training.
My Smith & Wesson only needs a little oil!
TwinCut
I saw somethink kind of neat last fall in Washington, they took a stinger pole type log trailer and took of the bunks. Then they mounted an open top sea can on the trailer that they had installed a walking floor in. The idea is that they can move around on bush roads a lot easier than with regular chip trailers. Seemed to work really good.
arojay
How do they dump, just open the barn doors?
440B skidder, JD350 dozer, Husqvarnas from 335 to 394. All spruced up
TwinCut
Yep, that's about it. The back doors open and the hydraulic system is kicked in and the material "shuffles" it's way out.
