Stihl ms 290 max bar length?
Started by blame, April 11, 2009, 02:41:33 AM
blame
Whats the max length bar you can use with a Stihl MS290
blame
18" is probably about right. I think they are sold locally with a 20" bar and run OK.
If you ran one with a skip chain it could probably run a 28" bar.  It wouldn't be fast , but it would work.
I have a Ms310 (5cc bigger brother) with a 20" bar, works OK in softwood. But for the bigger stuff a bigger saw is better.
SawTroll
Information collector.
John Mc
ErikC
I do fine on my 290 with a 20" bar, skip chain. It might do 24" in softwood with that chain, but I think 20" is about all it wants.
Al_Smith
Sure you can a long bar on a little saw.It just won't cut too fast .
The greatest extreme of this I've seen is a 6 footer on a Mini Mac 110 . It cut you just couldn't lean on it too hard . :D
markct
i dont have the sheet in front of me, but im almost certain stihl recomends 20 inch max on the 290 and 25 max on the 310. i have a 18 inch bar for my 310 and a 25 inch bar with skip chain and the saw has no trouble pulling itself thru a full bar of oak. i once cut a 4 ft oak log with it and it cut great but just barely met in the middle! i think the skip chain realy helps since theres half as many teeth cutting at once, and the skip chains sure do cut fast and are faster to sharpen too
SawTroll
Quote from: markct on April 12, 2009, 10:16:46 PM
Sure they do, what they "pull" is depending on your expectations, and a lot of other factors - there aren't any limit carved in stone....... :)
