Small metal to missing teeth ratio
Started by Banjo picker, March 22, 2009, 09:22:19 PM
Banjo picker
I hit one screw of some sort deep in a sweetgum today and it for the most part knocked off 27 teeth. :D ;D >:( :( :o   I used up a lot of emotions.  But thats nothing I am going to get a log tomorrow if its dry enoungh that has a bumper jack sticking out of it.  I am going to take a few pic.  Hopefull some day i will get to where i can post them.  Tim
fishpharmer
That sounds like a bummer for sure.  So what do you do after that happens.  I guess I should search this.
Did you continue sawing the same log or just put it off to the side?   Newbie question I suppose.
Lucas 618 with 50" slabber
Deere 5065E mfwd w/553 loader
Dan_Shade
i like to live life on the edge.  I turn the log over and see if I can hit it from the other side.
lots of dull bands and chains
fishpharmer
Then if you hit it from the other side you cut that part out with a chainsaw?  Guess it depends where the metal is located.
I got alot to learn. :P 8)
Dan_Shade
actually, if I hit metal, i go digging with the chainsaw and then chisel/pry/pull out the culprit.
I carry a crowbar, a prybar, wedges, and a crescent nail puller doohickey to help in nail/screw extraction.
I hit a broadhead arrowtip once, they're a lot harder than the band blade!
Ironwood
I recently won a battle w/ a spalted, nail infested 7' hard maple. I just would NOT give up  ::) Three blades later I won, nailiest darn wood I ever cut. I just gave it away the other day for free (maybe the log won that one). But it was cut up!
Fence ceramic insulators NEVER lose! Especially if it is on a low oblique orientation.  >:(
       Ironwood
woodhick
Been there done that, I agree with Ironwood on the ceramic insulators.  I've cut three to date.  I decided to try one of those cheap metal detectors similar to what security guards use.  I bought one from Harbour freight.   I was cutting a persimmon log and hit a nail and sent my son to get the new metal detector out of the shop.  I scannned over the log and it "hit or beeped" in two places.  Both places were right over the metal supports on the mill and I told my son it had to be picking up them.   Sure enough next cut I hit two nails and plastic fence insulators, each right dead on top of the supports.   My son just looked at me and asked if I was going to beleive it next time :D.  Oh Well.
Woodmizer LT40 Super 42hp Kubota, and more heavy iron woodworking equipment than I have room for.
ErikC
  I will back up any negative statements made about ceramic, and adds some of my own. I hit a fence insulator once, it was down where you expect trash, so I was kinda prepared. Then one time I hit a telegraph insulator, way up high where you're "safe". Those are a LOT bigger, and tougher than fence ones. Made a terrible noise, then the carbide tips on my Peterson just vanished, never to be seen again. :o
brdmkr
Quote from: Dan_Shade on March 22, 2009, 09:55:56 PM
One of my favorite metal removal tools is a cordless drill.  If you can find the metal and drill beside it, you can often vice-grips on it and pull it out.  I hate pulling metal, but I hate hitting it even worse.
ErikC
Quote from: brdmkr on March 23, 2009, 11:49:45 AM
Great idea brdmkr, why haven't I tried that before ??? Now I can't wait to find some more metal and see how it works. :-\
Banjo picker
Quote from: fishpharmer on March 22, 2009, 09:30:23 PM
James I finished cutting the log WITH that SAME blade.  I just slowed the saw down to a down right crawl.  The blades are 17 feet one inch so i had knocked off about 2 feet or so worth.  I figured screws were like nails--no body uses just one. :D  i wasn't gona ruin 2 blades on it.  I got two 7 x 9 ties out of the rascel.  Didn't hit any thing else.  I had heard that the screws were tough.
The bumper jack had already been pulled out of the tree when i got there today, but I had forgot the camera anyway. ;D  Took the 084 and split the three bigest logs into so the loader could pick them up.  42 inches on the butt cut.   8) 8) 8)  Tim
Part_Timer
I hit 3 nails on a job last month.  I couldn't figure out why they didn't show up I had scanned with the metal detector and everything was good.  I changed blades scanned it again.  it looked good, even changed the batteries.  Hit one more that chipped 2 teeth.  The metal detector was set on jewlery not all metals.  I guess the detector was right, there wasn't the first diamond ring or gold bracelet in that log. :)
Peterson 8" ATS.
The only place success comes before work is in the dictionary.
STUMPKICKER
In all the years I've bin' makin' sawdust, the hardest object I've ever hit was a mill bastard.  :o
ToddC
Quote from: STUMPKICKER on March 27, 2009, 07:57:09 PM
Did you have to pay him workmans comp?
Meadows Miller
Gday
Todd  :D :D :D :D :D ;) i gota good laugh outa that one Mate  ;)
Tim ive never knocked that many teeth of a band  :o and i can understand you not being too happy  :o :) :( >:( ::) as ive hit plenty of metal over the years too Mate  ;) :D
Chris
4TH Generation Timbergetter
STUMPKICKER
Todd C., he never put in for it.  ;D :D 8)
