Please visit this sponsor
Lucas Sawmills
Margeson Insurance
Hud-Son Forest Equipment
Author Topic: foam on eastern white pines  (Read 5029 times)
Offline davidlarson
« on: March 15, 2009, 04:15:25 pm »
Here in the mountains of western North Carolina the eastern white pine is a dominant forest tree.  Sometimes after a heavy rain (it has been raining here most of this week-end) a white bubbly foam, like soap suds, will appear at the base of some of the pines, as though it is exuding from the bark.  It disappears after the rain ends, and doesn't seem to appear during drier weather.  I haven't seen any obvious holes in the bark that might suggest beetle infestation, but I'm not an expert.  Does anyone have any idea what this might be?  Should I worry about this, or is it just a harmless natural phenomenon?  Thanks for any thoughts or opinions.  Sorry I don't have any pictures.  Probably I should enter the 21st century and get an appropriate camera.
David Larson
Offline Chuck White
  • Sawing Mobile since 2005
Re: foam on eastern white pines
« Reply #1 on: March 15, 2009, 07:17:27 pm »
I've seen it here to, but not often.
I think all it is, is the rain water running down the tree trunk, much like water running down stream in a small creek.
Here and there you'll have bubbles.
Retired USAF, Retired Bus Driver, and now a Mobile Sawyer
1995 Wood-Mizer LT40HDG24 (Onan) - Shingle & LapSider
Cooks Cat Claw Sharpener & Single Tooth Setter
4 ft Logrite cant hook, and others
I LOVE MY SAWMILL
Offline cairnrescueleague
  • Member*
« Reply #2 on: April 03, 2009, 07:39:44 pm »
No, this is definitely a white foam-like substance.  I just saw it at the base of a white pine in my yard in NH after a very heavy rain, possibly more than 1.5".
Offline Jeff
  • Lead Administrator
  • 1920's Sawmill Hand
    • THEE Forestry Forum
« Reply #3 on: April 03, 2009, 07:57:48 pm »
It's the same type of mechanisms at work that creates foam in a stream or lake.
http://dec.alaska.gov/water/acwa/pdfs/fy05_arri_foamfactsheet.pdf
I don't know the key to success, but the key to failure is trying to please everybody. Bill Cosby.
Online SwampDonkey
  • Board Moderator
  • Large Tooth
« Reply #4 on: April 03, 2009, 08:58:58 pm »
It's generally termed stemflow. As an example, stemflow from a 30 cm diameter hickory tree amounted to as much as 113 litres during a 2.5 cm rainfall. Stemflow serves to funnel a portion of the intercepted water into to soil at the base of the tree. It can result in increased leaching and podzolization of soil under the stem. (Pritchett and Fisher 1987, Properties and Management of Forest Soils)
I would guess that the rainwater is picking up impurities off the tree trunk and reacting with such things as atmospheric nitrogen, sulfur or potassium coming through the rain causing changes in surface tension. They are part or many particles up there in the air used to make precipitation, known as "condensation nuclei" in meteorology.
Jeff's paper gives further explanation.
I think the foam in streams is part of the process of forming conglomerates, when stream flow is reduced and that foam dries with calcium left behind to bind small stones with large ones. Nature's cement. ;D
Dirty Harry
Forum Sponsor</a></div><br>
				</td>
			</tr>
			</tbody></table></td></tr>
			 </table>
		</div>
	</div></div>
	<div id=
Page created in 0.072 seconds with 20 queries.
Saw Anywhere!
