028 oiler problems...
Started by Ever Green, January 19, 2009, 06:07:30 PM
Ever Green
A friend has a 028 and is having a hard time getting the bar oil to flow.  I'm a Husky guy so I don't know any tricks for his 028.  He has taken it apart and cleaned it up real well...how does this oiler work and what should we try to remedy?
Vince
Vince
From what I've learned here on the forum, the "drive" to the oil pump may not have been lined up right when the saw was put back together. Drives off the clutch.
joe_indi
Quote from: Ever Green on January 19, 2009, 06:07:30 PM
The bigdifference between the Husky and Stihl oil pump is that their flow adjustment screws work in the opposite direction.
That is: Husky screw needs to turn anti-clockwise for increasing the flow and clockwise for decreasing the flow.
Stihl screw turns clockwise to increase the flow and anti-clockwise to decrease it.
So, if by any chance you have advice him on the oil pump adjustment, you could have given him the Husky directions. Stihl is just the opposite.
Joe
Kevin
Is he using the thinner winter weight oil?
Does the hole in the bar line up with the oil output when the chain is tensioned, I've had a dealer sell me the wrong bar before.
Is the bar groove clean?
I don't think the 028 has an adjustment it is automatic oiling.
Ever Green
yes it is an automatic oilier...I will have him check it all once again...thanks to all that are trying to help...
Vince
terra8186
I had the same problem.  Try the winter oil.  I think it just gravity drains.
Kevin
There's an oil pump drive gear that's in with the clutch assembly.
