TJ 230D WINCH Spool Question
Started by GRANITEstateMP, January 15, 2009, 05:17:10 PM
GRANITEstateMP
Hi Guys,
A quick question for ya's on our mid 70's TJ230D.  When we put the winch into release or free spool it unwinds really fast.  I'm sure there is some easy adjustment just haven't been able to get the cd to check the troubleshoot guide.  It pulls fine, you just end up respooling the cable all of the time, it's makes the trip take doulble the time.  Thanks for the help
Matt
Hakki Pilke 1x37
Kubota M6040
Load Trail 12ft Dump Trailer
2015 GMC 3500HD SRW
2016 Polaris 450HO
2016 Polaris 570
SureTrac 12ft Dump Trailer
MaineLogger
Tighten the brake by turning the adjuster nuts down on the brake piston rod.A little goes a long ways.
380 Timberjack (cable)
230E Timberjack (cable)
648G Grapple
Husky 372's
John Woodworth
I don't know which winch you have but the gearmatic has a set screw in the housing on the top side over tha brake band, there is a spring under that set screw to put a slight drag on the drum which you can vary tension by adjusting screw.
Two Garret 21 skidders, Garret 10 skidder, 580 Case Backhoe, Mobile Dimension sawmill, 066, 046 mag, 044, 036mag, 034, 056 mag, 075, 026, lewis winch
MaineLogger
Sorry,I assumed your 230 had a Eaton winch.I have a 380 with a Gearmatic and that tension screw doesn't seem to do much.
648G Grapple
Husky 372's
John Woodworth
One thing I learned with the tension screw on the gearmatic is that unless you keep it lubed with anti-seize it rusts in the bore, also seal the screw opening in case with silicone sealer to keep the water out.
I can adjust mine down to almost stop the drum.
