Reflective insulation
Started by okie, January 13, 2009, 09:53:18 PM
okie
Anyone ever use reflective bubble insulation? Saw some at the hardware store, label says it blocks 95% of reflective heat and blocks most of conduction. It is 5/16" thick and is comprised of a layer of foil, layer of polyethylene, and layer of bubbles.  It says the foil blocks reflective heat and the bubbles block the conductive heat.  The brand I saw was Refletix (? SP).
The package didnt state a R value but clerk says many local contractors have started using the material and several homeowners swear by it, they used to onlyy special order but have started stocking the product.
The price was quite a bit lower than the fiberglass insulation.
Striving to create a self sustaining homestead and lifestyle for my family and myself.
scsmith42
Okie, I've used it quite a bit, and learned that it is quite effective in certain situations, but not all.Z
It workes very well for keeping heat in (reflective and emissive), such as what you'd need in an oven.  Another example would be keeping cold or hot air inside a duct, well cold or hot.
It does not work well at all for keeping "passive" temperatures in or out.
My kiln is built inside a steel container, and it works quite well to keep the heat inside the kiln.  On a cool day, if it' is 135 degrees inside the kiln the outer metal skin will be whatever the ambient outdoor temp is - say 70- degrees.
A good spray foam insulation is probably better in terms of overall effectiveness.  I have some insulated containers, and when it's cool at night they will stay fairly cool during a hot day (passive temp does not migrate through the foam insulation).  However, in my kiln (if it's not in operation) it will be just as hot or cold inside as it is outside - ie the passive temp passes right through the insulation.
The brand that I use is called Tekfoil (purchased from farmtek.com).  I also use it underneath concrete slabs to serve both as a vapor barrier as well as an insulation to reflect heat from the radiant heating in the slab back up into the building.
Tom's 3638D Baker band mill
Paso
It works great on the ground when installing radiant floor heat forces the heat up.
I was attaching photo but the site doesn't accept Jpegs
Welcome to the forum, Peso.
What site doesn't accept jpegs?   This one does.  :) :)
Go to help button above to learn to post. It is easy, and now we have the java uploader that resizes for you.
Seems to me bubble insulation would be somewhat temporary...that is until the bubbles are no more. I'm not a believer in plastic holding up for very long.   ::) ::) ::)
But until that happens, suspect it is good insulation.
Paso
105-0501_IMG.JPG.
You cannot upload that type of file. The only allowed extensions are xlsx,txt,doc,pdf,xls,wks,avi,mov,mpg,html,htm,shtml,kmz,eml.
This is what I got when attempting to attach my jpeg
Radar67
Welcome to the forum.
Pictures can't be attached to a post. They have to be loaded to your gallery here on the forum, then linked to. The help section will cover the steps to set up the gallery and upload the pictures.
Paso
Sorry  Most of the forums I belong to allow the pictures to be attached to the post.
That usually helps the topic along :)
okie
Thanks for the responses. I just had'nt seen the stuff before and was curious about it.
Paul_H
Quote from: Paso on January 14, 2009, 08:11:32 PM
Like this..
or this?
That would be really cool,I'll ask Jeff if he can do some tweeking with the software that would let us have pics in posts :)
Tom Sawyer
Quote from: Paul_H on January 14, 2009, 10:50:29 PM
Like this..
Where did you find the 2 headed deer?
scsmith42
Hi Paso - welcome to the FF!  I recently poured a slab with radiant heat and the bubble insulation, and can post a photo.
Here is a photo of the slab pour for my new shop.  The white material underneath the wire and tubing is the Tekfoil radiant barrier insulation.
stonebroke
Is that all you used or did you put foam under it also?
Stonebroke
scsmith42
SB - I just used the Tekfoil, because my intention was to reflect all of the heat upward into the building and minimize the heat loss into the ground.
After compacting the soil, I placed a few inches of gravel and then put the Tekfoil on top of the gravel (the tekfoil also serves as a moisture barrier).
However, I'm in North Carolina and we don't get the depths of freezing like our Northern Cousins.
If I had a situation where I had some extremely cold ground underneath my building, I would consider using styrafoam as a thermal break and to minimize passive cold transfer, with tekfoil on top to reflect the heat upward into the building instead of downward into the foam.  The foam would keep the cold out, and the tekfoil would keep the heat in, and my utilitiy bills should thus be minimized.  If the building was not going to be heated, I would skip the tekfoil and only use the styrafoam.
stonebroke
So you have no thermal break around the perimeter of your shop?
Stonebroke
Don_Papenburg
I was informed by some radiant heat gurus that a radiant barrier has to have an air gap to work properly (most efective) Then it needs some sort of good Rvalue insulation to help out .
I put 2" of extruded foam  under my concrete over a visqueen moisture barrier.  Then my pex and then rebar and wire.    Covered it with a bit of concrete
Paso
Okay I see I have to upload the picture to the gallery that I create then attach it to my post.
I have usually attached it directly from my computer.
It's nice to be new to the site and get so many nice welcomes.
What was with the warning I got saying only these files can be  uploaded?
scsmith42
Quote from: stonebroke on January 15, 2009, 12:47:18 PM
Stonebroke
Not on the outside - it doesn't get that cold here (the ground rarely freezes).
stonebroke
Boy are you lucky  or maybe just smart enough not to live up here.
Stonebroke
woodbowl
About the color silver. The ability of the color silver to reflect heat in the broad daylight is understandable, but it befuddles me that a mere color, (silver) sealed inside a dark wall claims to do the same. Does anyone know the technical reasoning for this?
Full time custom sawing at the customers site since 1995.  WoodMizer LT40 Super Hyd.
Quote from: woodbowl on March 07, 2009, 10:01:41 PM
Well light doesn't go through walls, but Infra-red light (heat) can. So by relfecting it back into the room, it acts as insulation. Every object thats above absolute zero radiates infra red energy, even the internal parts of your wall.
So anyway, another layer of insulation inside the wall will increase the total insulation value of the wall.
bandmiller2
Save the scraps of that thin foil insulation and make disposible insoles for inside your work boots.Frank C.
SPIKER
That PEX install looks good for the Mesh & stand offs, but looks like the PEX is too far apart for the northern climates. I'm told in Ohio you need 12" spacing, and 2 rows around perimeter 6" from outside walls.   This was told to me by guy who does the installs a lot.
I got some info from a company who also has a 1/4" thick layer of foam built into the foil bubble stuff.   Unfortunately that is in my email which crashed and is all gone.. :( thank you YAHOO.
I bought the foil bubble bubble poly for under my slab, but I'm putting it between a layer of 1" white styro and /4" blue styro sandwich.  (plastic/poly vapor barrier, 1" white styro, foil side down bubble bubble poly, and then 3/4" pink/blue styro, mesh on chairs PEX-AL-PEX and then 5" concrete with fiber in 6000 mix.) this is what my floor is going to be made up of. I bought the PEX-AL-PEX and the fittings & the "Foil Bubble Bubble Poly" from Farmtek a year or two back. just prior to the prices all going up.   the pricing is all back down now, reason I didn't get it in was I still had to have the outdoor pipe run prior to doing the floor. time money and loss of job kept the pour from happening for a couple years almost now...   This other foil bubble foam stuff looks good I have a sample from "PRODEX" http://www.insulation4less.com that will be going into my boots for this next winter!  thanks for that IDEA! lol should be just enough if I cut the stuff just right...;)
Mark M
I'm looking for help all the shrinks have given up on me :o
moonhill
I would place a caution on using the foil face bubble wrap as an insulator.  It needs an air space to work properly.  Squished under a slap leaves no air space, a vapor barrier, sure.  You can't beat 2" of foam under the slap, yes it cost more but you get what you pay for.  scsmith made a great point in his kiln being the same temp out side as in when the kiln is not running.  And being in the a warmer climate he will get away with it.  In the north it would be best to use the foam.
I run pex on a 1' grid also and rebar for a floating slab.  After you get done with the pour the wire mesh is usually on the bottom of the slab not in the middle where it belongs.
Tim
This is a test, please stand by...
OneWithWood
For the pured floors of the greenhouses we used 2" styro underneath the slab and on the sides of the slab.  A lot of heat is lost out the slab sides if it is not insulated.  The pex was installed on 12" centers using two overlapping rows.  The greenhouse stays nice and toasty during the winter.
One With Wood
Engineer
I put a product under my basement slab that is thin foam on both sides with a layer of foil in between.  I put wire mesh on top of that, ran my tubing on 12" centers, and ziptied all the tubing to the wire, and then poured concrete.  My floor stays nice and warm, it actually heats my entire house except for two second-floor bathrooms.
trimguy
I found this old thread about Reflectix, I thought I would just add to it. This is the first hands-on experience I've had with it. These pictures are from the same wall in my shop from the same time.
That's 20* difference. These readings were taken one afternoon. This wall gets sun all day. I realize that this will not make this much difference, if any on a wall that is shaded, but I would say it's money we'll spent.
Don P
That is a good application for it. When I see it being used under a slab, don't do that with any notion of it being more than a vapor barrier. At best, till the bubbles pop, it is R-1 and provides no radiant benefit at all being in direct contact with the concrete.
This is a good explanation;
Avoiding Home Energy Saving Scams – Part 2 - Reflective Insulation - Sustainable Energy Group
trimguy
Ljohnsaw
I just bought the aluminum foil on Mylar product about 10 years ago.  I have a tile roof that was put on skip sheeting from the old shake roof.  There is a layer of Cool Roof or something like that to act as a tar paper.  Though it doesn't work that well I found out.  That's another story.  Anyhow, my 10/12 pitch roof gives a lot of attic space and it is HOT up there in the summer and pretty warm in the winter.  I stapled the Mylar product to the rafters and foil taped the seams.  I have a ridge vent, so air comes in the soffit vents and up the heat goes between the rafters now acting as plenums, and out the ridge vent.  It made a huge difference in my attic and more comfortable in the room below the attic - no heat radiating down.
Raider Bill
I stapled plain old aluminum foil to the underside of my roof decking in my garage.
Reflects the heat pretty good here in the hot south.
Dropped the underside of the roof 20 degrees
The First 70 years of childhood is always the hardest.
peakbagger
More than few independent building authorities do not give this type of insulation a good review
Here is one
Stay Away from Foil-Faced Bubble Wrap - GreenBuildingAdvisor
trimguy
I wasn't under the impression that I was getting any R value from this, I want something to reflect the excessive heat back out of my shop. My test convinced me that it was a big help. I put R-19 insulation inside of this to help with the temperature control.
