hydronic heating sources
Started by trapper, January 12, 2009, 01:31:19 PM
trapper
where do you find sources for hydronic heaters to use with my owb.  At times i want to add extra heat to some areas in the house.
rowerwet
Central Boiler dealers can sell you what you want , at a mark up. google "modine heater", and try ebay for other ideas, plumbing and heating supply houses would likely have them.
Husky 460, Fiskars x27, X7
pasbuild
If it can't be nailed or glued then screw it
DouginUtah
-Doug
When you hang around with good people, good things happen. -Darrell Waltrip
There is no need to say 'unleaded regular gas'. It's all unleaded. Just say 'regular gas'. It's not the 70s anymore. (At least that's what my wife tells me.)
