need help for new saw
Started by missourilogger, January 02, 2009, 07:15:02 PM
SawTroll
Quote from: Cut4fun on January 09, 2009, 07:33:31 AM
Sometimes you have to overlook da saw snobs out there. If you are a homeowner firewood cutter. Get your saw and enjoy.
Sort of true, but there is a very good reason that Echo doesn't usually publish power specs - and when they do (in OZ), they are obviously fake, as they seem to not know da difference between kW and hp..........
Information collector.
John Mc
Quote from: SawTroll on January 09, 2009, 02:01:23 PM
Sometimes you have to overlook the saw snobs out there. If you are a homeowner firewood cutter. Get your saw and enjoy.
Sort of true, but there is a very good reason that Echo doesn't usually publish power specs - and when they do (in OZ), they are obviously fake..........
There are junk saws and good saws, and everything in between. I think the point about "saw snobs" was not meant to offend those who actually NEED a pro saw. If you are a heavy user, or sue the saw to make your living, a good pro saw in the size range to fit the job is a good investment.
I think the point is to avoid the "Tim-the-Toolman-Taylor" syndrome (sorry for those who never caught that TV show -- he's the kind of guy who takes the turbo charger off his car and mounts it on his weed-whacker, or gets a 200 amp MIG welder when a 30 Watt soldering iron would do the job -- because it's the "manly" way to do it.) Not everyone needs to buy a pro saw, and not everyone who needs something in the pro line-up needs a 90+cc engine. (I'm not saying you are pushing that, SawTroll. It's just that some of us need to be reined in a bit when we're shopping for gadgets and tools... we tend to get carried away.)
stonebroke
Yeah but there is never a replacement for displacement when you have a really big log to honk on.
Stonebroke
Cut4fun
Thats what was meant John Mc, some push pro saws even when a homeowner dont need them. I was there once. I am Joe Harry homeowner that just needs a trim saw 33cc and storm damage clean up saw in 60cc. But now I have 4 stihl 084's and 2 dolmar 166's and 20+ other saws.
Why no reason except the Tim Taylor adrenaline rush of gtg racing and being able to show up and help friends with their firewood chores and being able to just rip cut anything in my path.   8)  :)
stonebroke
What, I thought a 084 was a homeowner saw. Don't you own a home.
Stonebroke
Cut4fun
Quote from: stonebroke on January 09, 2009, 07:22:11 PM
Stonebroke
Better read my post slowwwwwly  ;),  I am Joe Harry homeowner .
missourilogger
 the maximum i need my is a 24" bar i dont think i really want a 372 yet so a 361 stihl, 2165 jonsered (if i can find a dealer around here), or a 365 husky if i can get one new
i Was here
and here
trouba
Quote from: SawTroll on January 08, 2009, 07:20:42 PM
Quote from: underdog on January 03, 2009, 09:52:55 AM
   Echo  CS-670
   Echo  CS-8000
Not at all....... :D :D :D
AH SawTroll let up you know those ECHO'S are good saws that CS-670 is a great saw and I own a CS-8000 and can tell you first hand it's rock solid dependable. For the money you cant beat them. I'm not saying Stihl or Husky are bad but I am saying ECHO isn't bad either.
Echo CS-306 12in bar
Echo CS-370 16in bar
Echo CS8000 36in bar
Homelite 360 24in bar
JONSEREDS 49SP locked up now, (went through flood)
Troy Built 6ft pole saw 8in bar
Warm Morning (The Hog Feeder)
Lopi Answer (insert)
Jotul #8
MTD 20 Ton splitter
cheyenne
Look at the husky 359 w/20" & 24" bar it will take more abuse than you can give it and the price is right......Cheyenne
Home of the white buffalo
trouba
SawTroll I assume you mean the other company's numbers are fake, or maybe just meaningless.
Statement from ECHO.
Horse power is not the best way to rate a 2 stroke engines power. When comparing the performance of two-stroke engines, going by horsepower is not really an accurate way to determine the performance capabilities of a unit. The reason for this, is that there are no industry standards set for rating the horsepower of a two-stroke engine. Due to the fact that there are no set standards, this allows too may variables to come into play allowing for possibly an incorrect or misleading horsepower rating. ECHO does not publish horse power ratings.
I can also confirm this holds true with cars boats trucks ect, HP ratings don't mean squat. Have you noticed in the small engine catalogs like northern toolhttps://forestryforum.com/board/index.php?action=position"> Note:Please read the Forestry Forum's postion on this company aren't rating their small engines by HP only anymore. Here's another scenario have you ever been to the drag race's only to see the car with the smaller motor with less HP win? How could that be that car was junk because its motor didn't produce as much HP, humm seems like there are some other variables that should be considered like maybe torque for one. Ask any ECHO user and they will tell you ECHO'S have lots of low end power. My CS-8000 has no trouble pulling a 36in bar in some very hard oak or locust even with my 225lb leaning on it and I don't mean cutting some 8in sticks I mean buried in some 38 40 inch wood. So maybe ECHO has decided to stay out of the so called bogus HP rating war and just make great dependable saws that sell themselves, and I don't think anyone can make a case that ECHO's are shelling out left and right. More like that Timex slogan they take a licking and keep on ticking  or err cutting.
Jotul #8
MTD 20 Ton splitter
ladylake
  Don't mind Troll to much, he's never ran a Echo saw. Over here I have Echo, Husky, Stihl, Solo and a Cub Cadet and I can tell you that stock Echo's cut faster per cc than home owner Stihl and Husky saws and a little slower than thier best Pro models, like my CS6700 (67cc)  with a small muffler mod is 1 second behind my stock 044 Stihl (70CC) in a 20 second cut. Pretty much the same between my CS8000 and 385xp Husky, the CS8000 might be 2 seconds slower but has 5 less cc's.  Far as HP rating how about the Stihl MS260 at 3.2 HP compared to a Stihl MS290 at 3.8 both published numbers fron Stihl yet they cut almost the same. I'd think Stihl puts the bigger number on the 290 to help sales of a saw that is cheap to make.   Steve
missourilogger
Quote from: cheyenne on January 12, 2009, 11:26:01 PM
we got a 359 it wont take a 24 well for pin oak and thats mostly what we cut
i Was here
and here
cheyenne
I cut red & white oak all the time never had a problem. What chains are you using......Cheyenne
missourilogger
Quote from: cheyenne on January 13, 2009, 06:55:02 PM
full square chisel
i Was here
and here
ladylake
Quote from: missourilogger on January 13, 2009, 05:04:54 PM
Seems like a MS361 wouldn't be that big a step up from you 359. I'd think a Husky 372, Stihl 440 or 460 Dolmar 7900 or a Echo670 (under $500) with a muffler mod would be the way to go.     Steve
missourilogger
i Was here
and here
cheyenne
I meant what brand or mfg. some chains are softer than others and won't hold an edge in hard wood as long as others.But it may be a sharpness factor also. I use all husky chains and have never had a problem. I support my dealer.....Cheyenne
missourilogger
sorry i misunderstood what my dad said (its his saw i have a 310) it can take a 24 inch bar but he dont need it
If i know n a 310 could take a 2 foot bar i wouldnt buy a new one but sill might buy a 361 or something like that
i Was here
and here
SawTroll
Quote from: trouba on January 12, 2009, 11:39:19 PM
SawTroll I assume you mean the other company's numbers .....
What I refer to is not company numbers, but the ones that are on a certain OZ web-site that have been referred to lately, and obviously are mistaken. it looks like they post the hp numbers as kW ones, and that sure leads to some intersting results when they calculate the factor of 1.34 in another time.......
olyman
Quote from: missourilogger on January 03, 2009, 09:02:40 PM
i dont need a saw that can handle any thing bigger than a 24/25 inch bar and i need it for the occaional tree i think i will get a 361 when things pick up a little with deer season about over ill be able to go back to work were just people who cut on weekends for extra money but dont cut little stuff the smallest we fall for logs are about the size of a normal steering wheel on a truck thanks for the help
please put periods, or some sort of break in your sentences--makes for hard reading
Engineer
You might as well have asked about Ford vs. Chevy vs. Dodge.  Or maybe John Deere vs. Kubota vs. New Holland.  There is NO good answer.  You need to go to several dealers, preferably someone who has a good rep for service, and pick up different saws to get a feel for them, maybe try them out if the dealer will let you.  There are dozens of saws available that will run a 24" bar occasionally, but might be better suited with a 16" to 20" bar for more frequent use.  The smallest you probably should consider is probably in the 55-60 cc range.  A larger saw will simply cut faster and make you more efficient, but it will tire you out faster.  All of the manufacturers make some excellent saws, and all of them make some real pigs that would be better suited to boat anchors.
Back about 20 years ago I was looking for my first saw.  I had grown up using my Dad's old 1968 vintage Homelite Super XL.  That thing turns your knuckles white and has no anti-vibe at all.  I went to a local Jonsereds/Echo dealer that had an excellent rep (and he still does) and picked up and tried out some of the Jreds and an Echo.  I hated them.  They felt like I was trying to cut wood with a wet noodle.  The antivibe made them seem floppy and uncontrollable.  I went with a Stihl saw because it felt more 'solid' like the old Homie.   If I had just bought the Jred saw, I'd have probably been happy with it, but it's got to feel right to ya, and those sure didn't.
Having said that, last week I used a Husky 372XP and a Stihl 361, neither of which was my saw.  I've spent enough time with good anti-vibe on saws in the last four years that picking up the Husky (same as a Jonsereds 2171, or darn close) did not feel nearly as uncomfortable as I thought it would, but the Stihl saw still just fit me better.  So you need to decide which saw's gonna be right for you, and not what one of us here thinks you should get.
missourilogger
Quote from: olyman on January 27, 2009, 09:00:41 AM
ok, sorry i'll start doin that.
i Was here
and here
missourilogger
Quote from: Engineer on January 27, 2009, 02:37:52 PM
oh thats ford all the way 8) :D :D :D :D
i Was here
and here
okie
OHHH, Since you like fords you would probably love a 40cc poulan for your needs :D
Striving to create a self sustaining homestead and lifestyle for my family and myself.
ely
or since you are pushing you may as well use a crosscut saw. ;D
