A whatzit?
Started by farmerdoug, December 13, 2008, 10:49:16 PM
farmerdoug
Here is something I found in two boxes in the trailer.  Anybody care to guess what it is and what it is used for?
Here is one with handles.
A look inside.
Here is more in the box.
Doug
Truck Farmer/Greenhouse grower
2001 LT40HDD42 Super with Command Control and AccuSet, 42 hp Kubota diesel
Fargo, MI
Molds, for..well, er...molding things. ???
farmerdoug
Dang,  you are half way there. ;D
I suspect a lineman will know their use.
Doug
Fargo, MI
farmerdoug
Since DanG is halfway there, we need what they are used for and how?
Doug
Fargo, MI
Since I got it half right, does that mean I get half of the Knaack boxes? 8)
LeeB
Well I don't know what they were used for, but I'll guess they were used in Spokane. Just so we get that out of the way, anyway. :D
timberfaller390
we njeed a better view of the first pic
L.M. Reese Co. Land Management Contractors
Stihl MS390
John Deere 50G excavator
John Deere 5103
John Deere 440 ICD dozer
I'll keep this going,insulators?
Dana
Is it used to splice the power lines together?
farmerdoug
A good guess Dana, among other things.  Now how do they do it?
Doug
Fargo, MI
Chuck White
What about using it to apply lead sheathing to underground cables!
scsmith42
That, my friend, looks like a mold used for exothermic welding.  The most common brand name is "Cadweld".
Typically it is used for making a permanent attachment of a ground wire to a ground rod.  They are also used to weld ground wires together, to attach ground wires to steel members, etc.
There is no chance of oxidation developing in the completed joint (which can cause interferance to radio equipment at a cell site / repeater site), and the welded connections are very strong.
The ground rod and wire are inserted in the mold, and then a mixture is poured into the mold and ignited.  The mix usually contains something like gunpowder and metal shavings, and it melts around the components, welding them together.
Scott
Tom's 3638D Baker band mill
farmerdoug
We have a winner.  8) 8)
Now what am I doing to do with them. ::) ;D ;D
Anybody need exothermic welding molds in various sizes?
Doug
Fargo, MI
Gary_C
Quote from: farmerdoug on December 14, 2008, 10:49:51 AM
Ya, Scott needs them. He's the only one that knows how to use them.  8) 8)
They might make a mold for a fishing sinker too. :-\
Warbird
Quote from: Tom on December 14, 2008, 10:55:04 AM
I was thinking they looked like good boat anchors.  ;D
scsmith42
I think that this is the first "Whatsit" that I've won!  I kinda feel like Steve Martin did when he found his name in the phone book.... :D
Doug, as I recall the molds are good for a certain number of charges, and then they've worn to the point where the powder blows out when you light them off, and thus are discarded.
If yours are unused (or in very good condition), you can probably sell them on e-bay.  Depending upon which molds you have, the price could be anywhere between $15 - 100.00 each.
Scott
farmerdoug
They are in various conditions.  Also have four boxes of charges for them too.
Thermite anyone? ;D
Doug
Fargo, MI
dolittle
Great explanation guys.  As an ex-electrical contractor I know of this method but have used it nor have I ever seen the equipment to make the weld.
sawman
  When everything works right it does make a heck of a connection.
They are used for grounding connections. We use them alot on grounding to structure
steel.
'14 LT40 Hydraulic 26 HP koehler ,massey ferguson 2200 forklift, Case IH D40
Wallenstein FX85
Don K
Just saw this. I knew exactly what they were the moment I saw the pics. I used them alot in the 80's when I worked electrical construction. They will make you check your pants when they get worn and the charge and melted copper blow out from the sides. :o
Don
Lucky to own a WM LT40HDD35, blessed to have a wife that encouraged me to buy it.     Now that\'s true love!
Massey Ferguson 1547 FWD with FEL  06 GMC Sierra 2500HD 4X4 Dozer Retriever Husky 359 20\" Bar  Man, life is getting good!
