cleaning planer rollers
Started by brdmkr, November 23, 2008, 07:20:09 PM
brdmkr
What is a safe solvent for removing pine sap from planer rollers?  I have been planing some heart pine and the resin is giving my rollers fits.  Will alcohol hurt the rollers?  They seem like some sort of rubber.
Kevin_H.
I have been using simple green to clean my blades on the gangsaw it seems to work real well, you might try that.
Got my WM lt40g24, Setworks and debarker in oct. '97, been sawing part time ever since, Moving logs with a bobcat.
VT
I use citrol  Here:
http://www.schaefferoil.com/specialty/266_citrol.html
I put a  small spray amount on the rollers while running , and then cheap sponges under the rollers to run on while cleaning with more orange / citrol on them also, after i feel there clean , wash the sponges and then run the rollers on the sponges to clean the residue and leave the rollers clean. the odd Sponge gets planed , but no real damage.
I never would use any harsh solvent,alcohol or caustic on an unknown rubber / neoprene material . But if i found old rolllers that were just plain hard and no longer able to do there job , i would experiment with a neoprene renew chemical .
Here::  http://www.wytekdirect.com/rubber-renew-and-lable-remover.htm
VT.
Thats more like my style Jeff
