SYP shrinkage
Started by Jimbob, November 22, 2008, 03:20:42 PM
Jimbob
If your were to flat saw a green Southern Yellow Pine log into say, boards that were exactly 2"x8", what would you expect them to shrink to after air drying to about 20% ?
Or, to put it another way, what size would you saw to get a rough lumber board that measured 1.5"x7.5" after air drying ?
Thanks,
Arky
In scientific notation....
→MC =  Vsh (FSP-MC)
  Vsh     FSP
→20 =  Vsh (FSP-20)
  Vsh    FSP
and
VMC = Vg - →MC * Vg
                Vsh
                100
thus
VMC = Vg*(1 - →MC)
                     Vsh
                     100
You say SYP, which species?
for loblolly pine Gg = 0.47, Vsh = 12.3% to oven dry condition
thus FSP = Vsh% = 12.3% = 26.17%  no shrinkage at this MC
                Gg       0.47
Thus,  Vsh% per each % MC loss is 12.3%
                                                26.17%
,which is Gg or what we call specific gravity in green condition and shows how it is derived.
The MC loss is 26.17 -20 in your request
So,
→20 = 12.3 * (26.17 -20) = 2.9%
  Vsh   26.17
And applying to your dimensions.... 2" x 8"
2" - (2" x 0.029) = 1.942 " (~1 and 60/64") thick
8" - (8" x 0.029) = 7.768" ( ~ 7 and 49/64") wide
so.........saw your boards
1.5" = Xth (1- 0.029)
Xth = 1.5"
       (1-0.029)
Xth = 1.5448 or ~ 1 and 9/16" thick
7.5" = Xw (1- 0.029)
Xw = 7.5"
       (1-0.029)
Xw = 7.724 or ~ 7 and 3/4" wide
To calculate for others species
longleaf Gg = 0.54
shortleaf Gg = 0.47
slash Gg = 0.54
I don't have figures for pond and pitch pine
zopi
ScotDonkey...you are a dweeb.
Cut 'em about a sixteenth over..unless you want to be really precise that is...
Got Wood?
LT-15G GO chassis added.
WM sharpener and setter
And lots of junk.
Lanier_Lurker
 :D :D
A dweeb, indeed.  I have those tendencies myself - at times.  On other occasions I just use redneck engineering.
I rather enjoyed reading that.  Might be easier to work the calculations in metric and convert the results to English, tho.
You guys missed the answer  ::) It's not those 64th dimensions it's the 16th and 4th dimensions further down. I just answer the questions.  A 16th thicker and a quarter wider.
Ah, now I know why you guys got trigger happy. I was in edit mode doing some proofing and adding some real world numbers to the dimensions after you guys intercepted the initial post. You need to relax and not go off half cocked.
Sorry I'm watching some Eastwood Westerns. :D :D
SD
Then let us know when you are done with the "edit" mode.   8) 8) 8)
I'll save up and see if you have made all the edits.
I know beenthere.  :D  Sometimes when you type stuff and hit that dang post button it dawns on you that something needs fixing or adding or clarifying, stuff like fractions are all out of alignment, that kinda stuff.  Go ahead and have fun. ;)
mechengineer13
And using cold water as your lube makes the shrinkage worse.  ;D
I'm right with ya Swampdonkey, I followed your post completely and thought I was back in school.  Purely a sizing calculation first based on percent moisture content change/delta, and then solving for desired final dimensions.  Great algebra!
zopi
Quote from: mechengineer13 on November 22, 2008, 09:42:23 PM
  Great algebra!
I gotta little chinese catfish keeps that stuff cleaned up.
Got Wood?
And lots of junk.
timberfaller390
carp and pond suckers would help too. :D
L.M. Reese Co. Land Management Contractors
Stihl MS390
John Deere 50G excavator
John Deere 5103
John Deere 440 ICD dozer
mechengineer13
Must be some smart fish feeding on that.  Think how smart they'll get when they start feeding on third order differential equations.  :P
Gary_C
I did not take the time to follow your math, so just one two question(s).
Did you take into account the difference in shrink from radial to tangential?   ;D
Or did you use the volumetric numbers and assume the shrink is all the same (not)?
You are right Gary, one should use tangential shrinkage, in this case tangential shrinkage is 7.4 % for loblolly pine
We know FSP = 26.17% from previous calculation
So,
→20 = 7.4 *(26.17 - 20) = 1.74 %
Tsh    26.17
Saw your boards
1.5" = Xth (1- 0.0174)
Xth = 1.5"
       (1-0.0174)
Xth = 1.526 or ~ 1 and 9/16" thick
7.5" = Xw (1- 0.0174)
Xw = 7.5"
       (1-0.0174)
Xw =  7.633 ~ 7 and 11/16" wide
Not really a whole lot of difference though. I'd still saw it 7 and 3/4" wide. Your talking hairs. ;D
Quarter sawn, we would use radial shrinkage for change in width dimension, in this case 4.8 % for loblolly pine. And that would be utopian, assuming all the rings are vertical across the width. ;D
If I might add, I think I would saw according to tangential shrinkage so as not to saw yourself short.  But with such narrow dimensions your just trading hairs in this species example. ;D
Lets look as butternut just for fun.
Gg = 0.36 , Vsh = 10.6%, Tsh =6.4%
FSP = Vsh% = 10.6% = 29.4%
          Gg       0.36
So,
→20 = 6.4 *(29.4 - 20) = 2.04 %
Tsh    29.4
Saw your boards
1.5" = Xth (1- 0.0204)
Xth = 1.5"
       (1-0.0204)
Xth = 1.531 or ~ 1 and 9/16" thick
7.5" = Xw (1- 0.0204)
Xw = 7.5"
       (1-0.0204)
Xw =   7.656 or ~ 7 and 11/16" wide
Not very significantly different
But, what about white oak
Gg = 0.59 , Vsh = 15.9%, Tsh =9.2%
FSP = Vsh% = 15.9% = 26.9%
          Gg       0.59
So,
→20 = 9.2 *(26.9 - 20) = 2.36 %
Tsh    26.9
Saw your boards
1.5" = Xth (1- 0.0236)
Xth = 1.5"
       (1-0.0236)
Xth = 1.536 or ~ 1 and 9/16" thick
7.5" = Xw (1- 0.0236)
Xw = 7.5"
       (1-0.0236)
Xw =   7.681 or ~ 7 and 11/16" wide
again, just hairs ;D
What about white oak quarter sawn so as the width is radial shrinkage?
Rsh =5.3%
FSP = 26.9 % in previous calculation
So,
→20 = 5.3 *(26.9 - 20) = 1.36 %
Rsh    26.9
Saw your boards
7.5" = Xw (1- 0.0136)
Xw = 7.5"
       (1-0.0136)
Xw =   7.603 or ~ 7 and 5/8" wide
I'm curious where you are getting the value FSP ?
FSP (fibre saturation point) is the point at which wood shrinks if the moisture content drops below this level, now a living tree can have way more than this. Wood does not have dimensional change above or equal to the fibre saturation point. When wood has more weight from water than from wood fibre the MC is considered greater than 100 %. So basically, if we want to find wood shrinkage we have to find the threshold of shrinkage, which is the FSP. This figure pertains to the moisture content bound by the cell wall and not cell lumens and is the maximum swollen volume of the cell wall.
FSP = Volumetric shrinkage from green to oven dry condition
          Specific Gravity in Green condition.
Those figures are in a table in the Wood Handbook as well as Textbook of Wood Technology.
Many folks make the assumption this is 30 % for simplicity, but when you have the data, might as well use it. :D
SamB
So would it be safe to come to the conclusion, a skinny 1/8"over on the thickness and a fat 1/8"over on the width? ???
PIE    R   ROUND?
COBLER  R  SQUIRE ?   :D
zopi
Quote from: SamB on November 24, 2008, 03:52:04 PM
PIE    R   ROUND?
Depends on if yer buildin' a space shuttle or a barn...<G>
Got Wood?
And lots of junk.
Keep in mind, that shrinkage is for 20 % moisture content. In my mind, maybe I'm out to lunch, but a more meaningful calculation would be for lumber at it's EMC (equilibrium moisture content) in the environment for which it will be used. If I recall the EMC for my area is around 12 %, in the Middle East it might be as low as 4%. Maybe in this gentleman's area it is 20 %, I don't know. It must have some meaning for him as he posed the question.
Let us look at what happens if we take the MC to 6 %.
Use tangential shrinkage of 7.4 % for loblolly pine as before.
So,
→6 = 7.4 *(26.17 - 6) = 5.7 %
Tsh    26.17
Saw your boards
1.5" = Xth (1- 0.057)
Xth = 1.5"
       (1-0.057)
Xth = 1.59 or ~ 1 and 5/8" thick
7.5" = Xw (1- 0.057)
Xw = 7.5"
       (1-0.057)
Xw =  7.95 ~ 8" wide
All of the sudden you decide to sit up and take notice when you have to leave an extra 1/2". ;D
DouginUtah
I just hope Jimbob, the OP, is aware that a standard 2x8 is 1 1/2" x 7 1/4" and not 7 1/2".
I hope I'm right about that--I hardly ever use 2x8s.  If he is matching to store-bought lumber he should measure one to be sure about what is actually is.
-Doug
When you hang around with good people, good things happen. -Darrell Waltrip
There is no need to say 'unleaded regular gas'. It's all unleaded. Just say 'regular gas'. It's not the 70s anymore. (At least that's what my wife tells me.)
Here is a good visual for figuring shrinkage (and note that FSP (fiber staturation point) for Loblolly pine is 21%).
http://timber.ce.wsu.edu/Supplements/Moisture/Default.html
