this old house
Started by Greg, November 14, 2008, 12:13:01 PM
Greg
Hey all,
Just stumbled on a current season episode of This Old House last night.
Apparently they are mid way through a Ted Benson timberframe project. I think somewhere in NH.
Awesome looking so far. Seriously high end project.
Combination of a reclaimed douglas fir frame, lots of interior studded walls, and pre fab building components dropped in by crane, all in one project. What they can do with pre fab is remarkable, higher quality, cheaper to build. Seems like the wave of the future.
I assume they'll be using SIPs as the outside skin, but I'll have to keep watching to find out :)
Greg
LeeB
I watched part of that last night and slept through part of it. I'm curious as to how the drop ins will look with the timber frame. Sems like it will cover up a lot of the beauty of the frame work.
Jim_Rogers
I recently heard Ted Benson speak at the TFG conference and he said that the filmed 16 episodes of this house project.
He was there when they set the copula on top and someone screwed up their lines and they had to do it again. And then someone else screwed up something else and they had to do it again, and again, and again. He said it took them 11 takes to get everything right...... so the crane lifted the copula up and down each time.......
Larry
I've been really impressed with everything but the cabinets so far...the third episode airs today at 12:30...right after that Norm guy. ;D
Lanier_Lurker
Is this the same project that included a trip to the shipyard to salvage a monstrous timber to trim down into a beam?
That was one massive log.
bigshow
regarding the SIP questions...well, they are kinda using SIPS.  Looks like Benson is doing their own.  2x6 stud panels filled with expanding foam, then 2" rigid foam applied to the outside.  Pretty nifty actually.  If one could rent the doo-dad used to fill the cavities with foam.....possibilities....
I never try anything, I just do it.
Brad_bb
So this last Saturday I happened to catch the TOH episode where they installed the cupola.  I can't believe they flew it up there 11 times!  I would rather see them do it once, and so what if it's not perfect and their lines are not perfect.  Do they always need scripted lines?  Let's see how it didn't fit right when they flew it up the first time (if that were the case) rather than a perfect fit every time.  That's not reality.  Would you rather it be more realistic and less scripted, or keep the scripting and every thing fits each time?
bigshow
This Old House isnt so much instructional...more informational.  For instructional - cant beat Holmes on Homes.  They aren't afraid to show when they themselves screw up and how to fix it.
