Central Boiler Classic 6048 finally Up & Running.
Started by DR Buck, November 02, 2008, 09:23:13 PM
DR Buck
My Central Boiler Classic 6048 was delivered some months ago and I've been slowly working to get it installed and operating.   Today I reached a significant milestone.  I got it fired up!
Here's a shot of the unit with "first" smoke coming out of the top.
The open pit to the right is where I will continue digging the trench to the new garage/barn in the background.  I am putting under floor heat down before I have the slab poured.   That should happen sometime in December after I get all the cash accounted for.  The concrete work for the floor is almost $6000!    :o
This view is from the back porch out to where the unit sits.  It's about 85 feet.  The distance was limited by the cost of the Thermopex  tubing.  At $12 per foot I put it as close as I could and still be clear of smoke.
The thermopex is buried and goes under the porch where the two new looking deck boards are installed.  It then comes up and goes up the outside wall into the eves of the house.
My heat pump where I installed the the heat exchanger is in the middle of the house and is not easy to access from the outside. This was poor planning on my part 11 years ago when I remodeled the house.   We do not have a basement, so going up and over was the only choice.  I had to fight the pex tubing through the walls.  In one place I even had to take up the floor upstairs so I could route the tubing through the floor joists.
Here is the "closet" where the heat pump is located showing how I installed and piped the heat exchanger.
We're testing it tonight.    ;D   I've run the thermostat up to 85° to see how long it takes to climb up from 70°.   In just over 2 1/2 hours we're up to 81° ;D    The wife is starting to complain that it's hot in here.   :D
I still have to hook up the heat exchanger for the domestic hot water.  That will have to wait until I start the kitchen and downstairs bath remodel job later this winter.  The hot water heater is even harder to get the plumbing to than the air handler for the heat pump.
You will enjoy having the boiler.I did put a shut off in my heat exchanger so I could use the furnace to heat the hot water all summer without heating the house up too much.Worked real well for us.Kept it running for a year steady.Should of got one years ago as I say.
OneWithWood
Nice job, DR.
How difficult or easy was it to join the pieces of Thermopex tubing?
For the run to the greenhouse I laid the pex in 4" corrugated tile, split up the side and filled it with the foam insulation you buy in a can.  Pain in the patootie and I don't know if I saved all that much dinero.
One With Wood
DR Buck
Quote from: OneWithWood on November 03, 2008, 08:46:21 AM
Nice job, DR.
Joining the Thermopex wasn't an issue.  I put it in in one long section up to the eves of the house.   However, handling it was another issue.  ::)    It was kind of like trying to push a 2500 bull into the back seat of a PT cruiser.   ;D    The stuff does not want to bend.  Even the section bolted to the wall of the house had a serious curve from the roll.  I couldn't push it tight against the wall.  I used the bucket on the Kubota to hold it in place while I screwed the clamps into the brick.   ;D
From the eves I connected with straight connectors and copper compression rings to "standard 1" pex lines.   I'm going to cover them with the split side slip-on foam sleeves to give them some insulation.
For the run to the new barn/garage I'm using a different method recommended by an installer.   He said for the customers he has that do not want to pay for the high price thermopex, he uses standard pex.  First he covers each run of the pex with the good quality neoprene style split-side insulation, then places both runs inside 4" sewer and drain PVC pipe gluing the joints to keep out water.    I've already purchased everything and the total cost was <$200.   If I used Thermopex, it would have been about $560.
antos_ketcham
FWIW - I've run a CB 5036 and am now running an E-Classic. My experience has been that chimney caps on OWB's creosote shut and before they do that they help keep smoke near the ground.
Nice set-up.
Pete
DR Buck
Quote
The sales guy told me the same thing.  So, I left the mesh screen out and just put the cap on to keep rain out during the summer as I will not be burning it then.
tonto
Dr. Buck, nice set up. I just fired up my Central Boiler 5036 this past weekend. I've had it for 2 months now and am so glad to finally be blowing smoke. Had to wait on friends to help with digging trench and plumbing, but well worth the wait. It's going to be nice not having to pay oil bills. My wife called me today and told me we had turn down the heat and the hot water is to hot !!!!! I agree with the chimney caps, with out one, mine blows straight up. A friend of mine has an old Heatmore with a cap an creosote builds up bad. I love this forum, every question I had about OWB's has been answered with out having to ask.
Stihl MS441 & Husqvarna 562XP. CB5036 Polaris Sportsman 700 X2. Don't spend nearly enough time in the woods.
firefreak47
new member here but have been reading the post on owf for a couple of days, i have a central boiler ordered i chose them out of the 20 or so i found on line because most of the people i know have a central boiler and one guy has had his 10 yrs with no problems, just wondering what you guys have used for the underground piping the stuff from cb is exspensive at 12 per foot also have you hooked them up direct or through an exchanger my hot water comes from coils in my furnace now but dont understand how the cb will heat it because it wont circulate through the furnace like it will for the heating zones thanks
DR Buck
Quote from: firefreak47 on November 06, 2008, 10:01:33 PM
Quote.....customers he has that do not want to pay for the high price thermopex, he uses standard pex.  First he covers each run of the pex with the good quality neoprene style split-side insulation, then places both runs inside 4" sewer and drain PVC pipe gluing the joints to keep out water.
sawdust
I'm not sure what the insulation factor would be. Using 2 inch thick blue styro span sheet ripped in six inch wide strips. Two channels routed length wise and half the depth of the pex. The pipes were sandwiched in there and duct tape wrapped around to keep it closed. The resulting box was buried in the dry clay about 1.5 feet deep to the top of the box. Total run was about 150 feet. I have no idea how it works, Merv died.
sawdust
comforting the afflicted and afflicting the comfortable.
DR Buck
Quote from: sawdust on November 06, 2008, 10:43:14 PM
sawdust
I've seen pre-cut foam insulation on ebay that is sized to go into pvc drain pipe.  However, I have not tried sing it.  The biggest issue is to keep the pipe dry.   If it lays in water or ground water gets into the insulation heat is "wicked" away into the ground.
firefreak47
i plan on using 1 in pex with foaminsulation then put in 4 in drain pipe but was wondering if anyone has done this and how it works, also seams like there is alot of air space so i was wondering if i should try to fill that with some regular insulation and tape it before putting in 4 in pipe or would it be ok like that for 100 ft it has been less than $250 2 rolls 1 in pex roll of 4 in and enough foam insulation compared to $800 for 75 feet thermo pex that i would need
That's how I did mine.I do lose some heat this way.I only buried my lines about 18 inches.The snow will stay on top of where the lines are buried for 2-3 days than it's bare ground.I want to put a cold frame over the lines.   ;D  But it's kinda good that I do lose some heat.At least when the power goes out I don't have to run to start the generator up.The ground will keep the pipes warm for quite some time.I did spray a bunch of expandable foam on each end of the lines.Just to keep the cold air from coming into the house and the back of the furnace.I used all one piece of drain pipe.No seams to try to seal up.I have my own wood too.If you are buying wood how much more wood would it take the cheaper way?Would the more expensive PEX pipe pay for itself in 10 years?
firefreak47
thecfarm how  far away is your owf i work with a guy that did this also and said he only lost 1 degree in 50 feet, mine will be about 75 feet,  as of right now wood is free but that could change years down the road, also dont want to spend 12 a foot on the good stuff because eventually i will be putting an addition on because we had triplets  in jan. and this pipe will be dug out and half or more of this pipe will then be inside the new garage so then i might put the good stuff in for the underground,what coldd box are you talking about? thanks
I doubt it's 40 feet away.I may not lose much temp from the owf to the garage,but I lose heat from the pipe.That's why no snow on the ground.I'm heating the great outdoors one foot at a time.  ;D  It will work just fine,if you don't mind losing some heat and using more wood.In your case,it would be foolish to use the more expensive pipe from what you stated.I just wanted to make it clear that it would take more wood to use the cheap stuff.
Cold frame,just a box with a glass or plastic top angled to catch the sun rays in the early spring or late fall to extend the growing season.I think most are used for salads greens,spinach,cold crops.The ones I have seen are 2-3 feet by 4 feet long.People must use them around you in NY.
Jasperfield
Dr_Buck,
I can tell you've spent a lot of time planning and arranging for a "clean and proper" if not "Bristol" installation. It looks good. As for the ditching...try not to think while you're doing it. Just focus on the digging and remember..."This is the job I've got now, and it'll soon pass."
Northern VA is beautiful country.
Jasperfield
DR Buck
Quote from: Jasperfield on November 07, 2008, 10:19:49 PM
Dr_Buck,
Jasperfield
Thanks for the complements.  The ditch digging is not going to be a problem.  I bought a backhoe for my Kubota.  ;D
firefreak47
thecfarm how did you get the pex through the 4 in pipe? did it slide in easy also did you use 1/2 or 3/8 insulation on the pipes thanks
My pex pipe is kinda joined together with ¼ inch foam than that is wrapped up with something like aluminum foil wrap.All this is about 3½ inches wide.I did not run this through the 4" drain pipe.The dealer I bought the furnace from did it for me.
DR Buck
Well after a little over a week of burning for what it's worth I've got some data on wood consumption.   It will all change when the barn/garage floor is poured and the heat loop is hooked up.
So far when temps are above 40° F  I get two fulls days of burn on one load of wood. The past couple days the temps have dropped into the low 30s at night and I'm filling the burner once each evening.   Wood is a mix of oak, poplar, cedar and pine from my slab pile.   Most of it is dry.  A lot of the red oak was cut down this past May and is still somewhat green.
I still haven't removed any ash from the unit.  I does not appear to be to full and what is there contains a lot of hot coals.   Maybe this coming weekend I'll shovel some of them out.
firefreak47
just picked up my 5036 sunday plan on hooking up this weekend, but as it sat in my driveway on the trailer neighbor already bitching they are going to complain about hte smoke it causes because of all the negative things online about owb and how bad they smoke and the emissions they give off. the people i know that have central boilers said they dont smoke that bad so hoping not to have to much smoke but was wondering if there are any websites that have actual emission test on these boilers expecially the 5036 since any sites i found say they have really been any full testing or if they mention test it doesnt say what owb was tested i have a permit from town so not much they can do but i have seen some royal crown furnaces that smoke alot and the smoke just hangs there thank
tonto
Congrates firefreak47 on your purchase. I also have a 5036 and I don't run a cap on it and it doesn't smoke to bad. The dryness of the wood has alot to do with how much it smokes - mainly only when the damper opens. Where in NY are you, I'm near Kingston if you wanted to check it out.
firefreak47
tonto i am near middletown i dont plan on running it with a cap either how long have you had it? where did you purchace. i think the problem with the neighbor is just all the negativity online about owbs they pointed out the one from office of attorney general smoke gets in you lungs but even in there they say there hasnt been enough testing i have to tried to find positive test results expecially on this model to so them but havent found any, but hey cant please everyone
tonto
Firebreak47, I live in Kerhonkson just a bit north of Ellenville. My Neighbors where a little nervous at first also but once they have seen running now for 3 weeks it doesn't smoke much more than their wood stoves did. I placed it so the way the wind blows the most , it sends the smoke out into a corn field most of the time. It is only about 50 feet from all 3 houses. I bought mine from Halloran Farms in Callicoon Center - very nice people to deal with.
firefreak47
tonto that is where i purchaced mine as well, my owf will be about 250 feet away from there house and the wind will blow it to the back not the side towards them most of the time
