Filling in knotholes in flooring
Started by ellmoe, October 21, 2008, 08:05:42 PM
ellmoe
  I have a customer that purchased some rustic, spalded oak flooring from me. He kept all the knot holes. He wants to fill the holes in with something clear so the hole will show, but still seal up the hole. He will be using a water based urethane as the finish. Any suggestions?
jason.weir
look into a pourable bar top epoxy, the stuff is self leveling and hard as wood pecker lips when cured.  Its expensive but just a little bit would fill a bunch of knots...
-Jason
ellmoe
   Thanks Jason. Do you think that there could be a problem with the finish applied over the epoxy?
metalspinner
The problem will be the epoxy oozing underneath the floor.  If a leveling type liquid is used, he will need to dam up the bottom of the knots prior to filling.  If he has not laid the floor yet, he can put tape on the bottom of the holes to seal them up.  Spinkle in a little saw dust on the exposed tape to match the color of the floor.
jason.weir
No idea on final finish compatibility..
-J
pigman
I have filled  nail holes in furniture with clear epoxy and the poly finsh seemed to stick to the epoxy just fine. At least it looked fine when I delivered the furniture to the customer. ;D
ellmoe
Larry
Epoxy has worked well for me.  I also tried body putty one time dyed black.  It worked just as good as the epoxy.  I've never used a water based finish as your customer plans...he might want to test a couple of samples first.
Dodgy Loner
I've used clear epoxy with a polyurethane finish to fill knots in some cherry flooring and an apple coffee table.  It's been 2-3 years and I have no problems to report.
Chuck White
Quote from: metalspinner on October 21, 2008, 09:55:20 PM
Another way would be to pour a little of the epoxy into the knot holes (to seal the bottom) and once it's cured, just fill the holes the rest of the way.
ely
and if you want it to look interesting you can drop in a few quarters or 22 shells and fill them on up. makes a nice conversation piece.
ellmoe
Quote from: ely on October 22, 2008, 11:57:38 AM
   This is Florida. I was thinking about palmetto bugs (cock roaches on steroids). :D
woodmills1
NICE, put the bugs in and then pour in the goop
