Now I Went An Did It!
Started by Foxtrapper, September 26, 2008, 02:04:02 PM
Foxtrapper
I been wanting a mill soooo bad, that this is what I bought:
Well, guess I will post photo's later..
It will handle a log 30" X 30'.  Has hydric up/down/feed.  Currently has an 18hp kolher engine, but also got a 25hp with it, which is being serviced at the local small engine shop.
Need to make a blade guard for it as well.
Any ideas on how to remove water from a hydric reseivor tank that has no bottom plug, and has the pump mounted inside it?
2014 WoodMizer LT28
StorminN
Good going Foxtrapper!
Quote from: Foxtrapper on September 26, 2008, 02:04:02 PMAny ideas on how to remove water from a hydric reseivor tank that has no bottom plug, and has the pump mounted inside it?
If the tank doesn't have a drain... get a bucket, drill a hole in the bottom of the tank (make sure you miss the pump)... drain the tank, then drill a bigger hole and tap it / weld a piece of pipe to it, to make the tank have a drain from now on!
-Norm.
Happiness... is a sharp saw.
Foxtrapper
Yup that was my thinking too.  Gonna be a job though.
My photos are too big to put in the gallery.  I'll have to try to resize them.
2014 WoodMizer LT28
While you're resizing the photos,can you tell us what kind it is?Congratulations on the mill.You will enjoy it.What are you building?
Foxtrapper
Actually, someone built this one at home.  Whoever did it knew how to weld and engineer things, as it's rugged built, and thoughtfully engineered.  I can't wait to get it going and see what it will do.  I had thought of trying to build my own, but, I got this one for less than the cost of the steel to make one.  I'll get on those pics. :)
2014 WoodMizer LT28
Foxtrapper
2014 WoodMizer LT28
Robert Long
Welcome foxtrotter
"Any ideas on how to remove water from a hydric reseivor tank that has no bottom plug, and has the pump mounted inside it?"
Yup........Turn the mill upside down! :D :D
You'll enjoy that mill a lot!
Robert
Foxtrapper
"Yup........Turn the mill upside down!"
Would that be the whole mill, or just the carriage ;D?
"You'll enjoy that mill a lot!"
I sure hope so...just gotta alittle work to do is all.. :)
2014 WoodMizer LT28
Foxsnapper,congrats on the mill,it looks well made.Best thing on that hyd tank is to remove it put a drain in the bottom with a small ball valve and flush it good with kerosene.That way after its been sitting you could check for water/condensation easily.Find out how that water got in the tank and correct it.Try different bands many manuf. will send you a sample free you will find one you like the best.Frank C.
wannabeonetoo
Bandmiller...how the heck do you get "freebie" anything  ;)!!!!! (Other than the wealth of information found here 8))
   Curious minds want to know ???
          Steve
Foxtrapper
Quote from: bandmiller2 on September 27, 2008, 07:40:08 AM
Can these be made to any lenght?  I will get you a measurement and pm it to you.  Thanks. :)
I was hoping someone would mention what to flush the tank with.  The last time I had problems with water in the hyd was on an AC 5050 tractor.  I drained the transmission and filled it with disiel fuel, ran it for awhile then drained and refilled.  That worked well.
2014 WoodMizer LT28
Fox T,bands can be made up any legnth,they buy it in a long roll cut and weld to cust. specs.Most homemade mills use the same legnth band as the mill they took measurements off.You usally get a band and build a mill to fit it.Kreosene and diesel are next of kin your choice.        Steve,call the folks that sell the bands,talk to someone important pick their brain and ask to try one before you buy a box.Their is always someone their that knows and can help if your having problems or at least thinks they can.Be charming Frank C.
wannabeonetoo
Thanks Frank,that sounds good , explaining your situation and problems makes good sense .The "be charming" part probably goes a loooooong way too  ;D.
   Steve
logwalker
Congrats on the mill. As to the water you could use a oil change hand pump. Put the pickup at the bottom of the tank and pump it out. Heat the tank with a propane brush burner and boil off the last remaining water. Be careful of course.  ;)
Joe
Meadows Miller
Gday
Foxtrapper congrats on the new mill  8) 8) 8) Hmmm 30" 30' I wouldnt mind being able to cut timber that length again  ::) at least You can access a larger market for timber  ;) with that mill . With the Hyd tank Id go with the other Blokes that said drill it out and weld a drain plugg in it it will make Your life alot easer in the future Good luck with the new Toy errr I mean peice of Equipment give it a coat of jam and it will come up looking like New.
Reguards Chris McMahon
4TH Generation Timbergetter
Foxtrapper
I'm thinking that putting in a plug would sure save some headaches later on.  I borrowed a buddies sandblaster, and plan to give her a good coat of paint....now...ur....what color... :D.
2014 WoodMizer LT28
backwoods sawyer
Backwoods Custom Milling Inc.
nas
Better to sit in silence and have everyone think me a fool, than to open my mouth and remove all doubt - Napoleon.
Indecision is the key to flexibility.
2002 WM LT40HDG25
stihl 066
Husky 365
1 wife
6 Kids
