Last board
Started by bandmiller2, August 21, 2008, 05:51:43 AM
Do most of you bandmillers cut the last board down to an inch or do you chicken out when you get close to steel and stop at 2".What about you swingers how close do you cut to a clamp/dog.I put a stop on my mill at 1" won't go lower.When I had my old circle mill I always cut to 1" except twisty stuff like fresh oak,of course back then I didn't know any better. Frank C.
frank
Larry
A lot of older mills, my mill included could not physically saw much closer to the bed than a couple of inches.  Some sawyers made modifications to allow sawing to 1".  On my mill it was a simple matter to raise the bunks.  And it don't bother me a bit sawing a 1" board...unless I forget to lower the log stops all the way. >:(
Chuck White
I cut to 1" on my mill. The blade clears the clamp by over 1/2".
I have the flip-up hydraulic clamp and the high-performance blade guides on my mill and I have to move the blade guide out around the clamp when going to 1", or the guide will bump the clamp.
Yesterday, one of my blades had an accident when the sawyer (me  :o :-[) forgot to lower the log stops.
I believe the blade was only injured.
Dan_Shade
I cut 1 inch, but if you can't cut 1", tuning the log so that the pith is in the last board is a good idea
lots of dull bands and chains
timberfaller390
I can actually cut down to 3/4 in. on my mill
L.M. Reese Co. Land Management Contractors
Stihl MS390
John Deere 50G excavator
John Deere 5103
John Deere 440 ICD dozer
flip
I can get to 3/4 until the limit switch stops me.  If the last board is an odd size for what I'm sawing (too thin it goes in the junk pile).  If it is thicker I will put the best face down and skim off the top to bring it down to correct thickness.
Timberking B-20, Hydraulics make me board quick
TexasTimbers
Mine will go down to 3/4 of an inch too but it tilts the head a slight bit causing the board to be angled off the side a hair. It will cut down to 1" with no problems though.
I'm certainly not afraid to cut to one inch.  It's harder on the spectators than it is on the sawyer.
On my old Woodmizer, knowing that I could cut to 6" with the clamp up and 1" with the clamp down, I gave many new off-bearers and spectators anxiety attacks. :D
Fla._Deadheader
We built ours to bottom out at 1", so, no problems.  ;D
Engineer
I could probably get to an inch if I tried hard, but the clamp limits me to about 2" and the stops won't hold the board if I get that low.  What I do is cut from both sides so that the pith is in the last board, which works out to a 2" board with QS wood on either side of the pith.  Those thick and narrow QS pieces are just as valuable to me as anything else because I save them for butcher blocks or tool handles (if hardwood) or trim pieces (if pine).  The last thick piece on a pine log, if you plan your cuts right, will also get you decent framing lumber.
Now, if you're resawing cants for lumber, I can see where you might want to get down to an inch.  I've wanted to do that but I can't make the saw do it.  What I'll do is set the last piece on a cant and saw it about 6" off the bed.  Still, it's hard to get the stops to hold it well (old mill + beat up stops = poor holding power).
MrMoo
I cut down to the last inch too. Plenty of clearance.
milling man
My mill will also cut down to an 1" maybe even alittle thinner. I have not tested the limits yet but you really need to watch the log stops they really can play havoc on your saws when you hit them :o
Corley5
Grandpa added short pieces of angle iron to the bunks on the Corley so it will cut to one inch.  Before it would only saw to 2"s
brdmkr
With the swinger things are still round on the bottom but I have cut until my blade kisses the bunks.  I use a small floor jack to keep the middle of the log from sagging.
StorminN
With the Mobile Dimension saw, things are round on the bottom too... my mill bottoms out at 2" (log dogs do not retract), but I've flipped the bottom board over a time or two and surfaced it on the other side to get a 2" board out of it if I needed...
-Norm.
Happiness... is a sharp saw.
solidwoods
The back fence on my mill (Kasco IIB) only allows 1.5".
If I'm making 4/4 I cut on 1.125" increments so when I get to a 3.375" cant, I set the blade height to 2.25" ,, cut the top board off.  Then put the board right back on the cant exactly how it came off (match the ends also in case of any wave in the cut), flip the 2board cant and 1 board sandwich over ,, blade is still at 2.25" Voilà 3 boards at 1.125" thick.
Also when splitting that last cut I watch the blade to make sure it stays in the middle of the cut.  I move the blade up/down if required as I cut.
If I have a Tail person, they walk on the cant to ensure it stays flat to the bed.
jim
Ret. US Army
Kasco II B Band mill
Woodworking since 83
I mill & kiln dry lumber, build custom furniture, artworks, flooring, etc.
If you mill, you'll be interested in some of my work in one way or another.
We ship from our showroom.
N. Central TN.
backwoods sawyer
I get a lot of call for ¾" cedar, and until I upgraded to the newest style of saw guide it was no problem, other then getting the clamp to hold in the soft cedar. Since up grading, the saw guide clears the bed rails at 7/8". I can cut ¾" but the guide rubs each of the bed rails lifting the outer edge of the saw head as it passes over each one. As long as I slow down for each bed rail and ease over it, I can cut ¾" The rise is only noticeable when the wood is planed, most of what I cut is used rough.
Backwoods Custom Milling Inc.
Kinda makes me wonder what you are doing to the set on the bottom of the band, and if the tips of the teeth that are bent outward are being damaged.  I don't think I'd want the band touching anything.
backwoods sawyer
Quote from: Tom on August 21, 2008, 06:43:03 PM
Tom could you clarify whose post you are replying to? I am not seeing where anyone mentioned that there band is hitting anything.
Chuck White
Quote from: Tom on August 21, 2008, 10:40:39 AM
Mine cuts the same as yours Tom.
I've had more observers run around the mill to get my attention.
It's kinda funny, but someday, it could save me a blade.
When the blade comes within 1/8 to 1/4 inch of "any" iron people get excited.
I have forgotten to lower the clamp before though.... so far I've always cought it in time. Unlike yesterday with the log stop.  FIL says the blade is salvagable, but probably lost one sharpening.
Mine last cut is always an inch.It cannot go lower than an inch.Good thing too,or I would be hitting iron.
ladylake
Quote from: backwoods sawyer on August 21, 2008, 07:34:12 PM
What part of the guide is hitting, might be time for a grinder or lathe work. If you have the bottom guides must be the best you can get for clearance.  Do they help?   Steve
backwoods sawyer
Maybe this will help:
The flat part on the bottom of the guide is what is rubbing on the bed rails, not the saw.
(I was cutting some white oak today and havent washed the guides off yet)
MikeH
Mine will go below a inch even when I leave up the clamp. :-[
moonhill
backwoods, it looks like the bottom bolt is what hits, grind it a bit.
I can saw to 7/8" (3/4" stops)  for the last board.  My trick for sawing to 1/2", for siding, is to leave the last cut at 1-1/8" keep the last 1/2" piece on after its cut and flip both over so the 1/2" is on the bottom,  I place a catcher piece on the outside and with no dogs slowly cut the top thicker piece in half.  Tim
