travel trailer roof leak
Started by sbishop, August 04, 2008, 09:07:56 PM
sbishop
Hi all, i've got a leak in my travel trailer (1979). i've think i've narrowed it down to a section up front. I tried putting roofing cement on it last year but it has come back.
Any suggestion on what i can put on it that will last a long time? i was thinking maybe putting a piece of ice and water shielf, then tarring it?
What do you think?
Sbishop
Radar67
Elastomesteric (sp?) roof coating. It is a white rubberized coating that is used on mobile homes and metal roofs.
Coat the whole roof. ;)
CLL
Agree with Radar67, it works great and will keep trailer cooler too.
Too much work-not enough pay.
sawguy21
Patching the leak will only buy  a little time. The moisture will be trapped in the roof rotting the framing. The only solution is removing the trim and carefully peel the skin back so you can re use it. Replace any rotted wood and the insulation.
Coon
Sawguy is right.  Just have a look at my camper.  Seems the people that had  it before me never sealed anything up  and moisture got under the tin and rotted the framing which was mainly 3/4" plywood.  I got a heck of a deal on it and will eventually be using the fridge, stove, and furnace, along with various small parts and pieces to build myself a new and bigger model.
mad dog
        I had 3 leaks in my motorhome ,seal it with liquid roof,been 2 years and no leaks! I used etrabond on the seams(did this first)
mad dog 78 acres,pasqualli tractor,L-15 woodmiser
sbishop
Elastomeric seems to be the way to go, do any of you know if it will stick to tar? 2 years ago i tarred the area in question!
Sbishop
Radar67
Everything I've read says it is geared toward roof replacement for old asphalt and metal roofs.
2000
sbishop
i did half my trailer yesterday...this Elastomeric seems to be some good stuff!
Sbishop
