Do borers weaken wood?
Started by brdmkr, July 30, 2008, 11:26:35 PM
brdmkr
Actually, I suppose I know that they do, but I am wondering if I need to be concerned about them given my intended application.
I am in the process of building a lean-to off of my shop for my tractor and a few implements.  I figure I will need to span about 12 feet with a 2 foot or so overhang beyond my posts.  So, I picked out a couple of 16 foot SYP logs and sawed up some 2x6s.  However, the logs had borers going all the way to the heartwood.  Other than their tunnels the wood seems OK.  I intend to place the rafters on 2' centers with 1x4 lathing and galvalume on top.  Given the light weight of the roof, is there any need to worry about the tunnels?  I know that I am spanning a bit much for a 2x6, but I am hoping that I won't have any appreciable problems given the light weight of the roofing material.  Am I off in my thinking?
LeeB
 I hope not because I plan on doing the same thing. :D
Disclaimer: Since I'm no structural engineer, take my comment as opinion only and your taking all the risk, while I am not liable or obligated in any way.  ;)
Unless it's full of holes like Swiss cheese, punky and stringy like a pumpkin and gooshy like a sponge, go for it.  ;D
I really don't know either.Do you have enough 2X6's to build 16" on center?That would help on your concerns.
moonhill
When engineering Timbers for a frame one should keep in mind the peg hole, for you have now severed the fibers running through the length of the beam and it is now weaker, I am assuming borers the size of a small finger are doing the same thing.  Over size the 2x stock?  See attached disclaimer.  Tim
tcsmpsi
Well, none of my stuff has fallen down around my head.   :D
Not sure how tied in you are to running 1X4 lath, but I believe you would be happier running 2X4.  It'll help tie your rafters together, giving them a bit more strength, especially since you're 'stretching' them a bit.  Whole lot better for holding screws/nails, and working on.
\\\"In the end, it is a moral question as to whether man applies what he has learned or not.\\\" - C. Jung
brdmkr
A pic or two of the borer holes would be helpful.
If you still have continuous grain (fibers) along the tension edge of the joist/rafter, (similar to grain required in structural grading) then you should be ok. If the borer holes remove wood along that tension edge, and are similar to cutting a notch along the edge, then the width of the 2x6 is comprimised, and reduced strength is the result.
If concerned, you might consider doubling up the 2x6's, and gluing/screwing them so they share the load.
Again, pics would be helpful for discussion.
brdmkr
Quote from: tcsmpsi on July 31, 2008, 07:43:44 AM
I was just thinking that the 1x4 would be lighter and I have a bunch that I likely won't use for anything else ;)
beenthere,  it may be a while before I can get pics, but I'll try to put some up before I begin construction.
Quote from: brdmkr on July 31, 2008, 10:25:19 AM
I was just thinking you might be looking for some direction prior to beginning construction, and pics could help.
As to the answer to your question in the title...it would be Yes and No.    :)
brdmkr
beenthere,
You are correct.  I will be sure to post some pics before I begin.  I'd post some now if I could steal away some time to visit my sticker pile.
