Grading Hardwood Logs
Started by Good Feller, July 18, 2008, 08:48:48 AM
Good Feller
I was wondering if there is a log grading "bible" that has been published.  A book with everything about log grading including colored pictures of logs and defects.  If not, is there anything on the internet?    Thanks
Good Feller
Ron Wenrich
These seem to be pretty good:
Log grade link #1
Log grade line #2
And if you're into veneer, try this one:
Veneer grade link
Be aware that a lot of mills don't use the Forest Service log grades.  Some of them have made up their own, and buy accordingly.  Know your market ahead of time.
VTLogSlayer
NHLA (National Hardwood lumber Association) makes an inspection training manuel that we use here at Paul Smiths College for our sawmill and lumber grading class.  This manuel has everything you need to grade hardwood lumber.
ms361 20"
044 20"
Polaris xcsp 600
97' Land Rover Discovery
Good Feller
There are published Log grades and also Tree grades (based on the log grades).
As Ron pointed out, the publications show standard log grades that may not used by the buyers, however there are lumber yield figures for each of the log grades, by most species of hardwood logs, and by diameters of logs.
Allows anyone to grade a log, figure the yield in NHLA lumber grades, and from those yields get a pretty good estimate of log value based on lumber prices by lumber grade.
Log grading usually requires looking at least at the best three faces of a log.
The last log grade research done 1973 in the US Forest Service was out of the NE Exp Sta project in Princeton, WV. Referenced in the link #1 that Ron posted, as Rast, Sonderman, and Gammon. The yields are still valid as the lumber grades have not changed since then.
Ron Wenrich
We do have a tree value calculator developed from that research.
https://forestryforum.com/calcs/treevalue.htm
But, although the grades haven't changed, there is a wide variability of any tree species within the range.  And, different cutting patterns will yield different sawn volumes and values.
I pretty sure that for the research all logs were sawn into 4/4 lumber.  There were no cants.  I don't know of too many mills that saw in those patterns.  So, the amount of 2 and 3 Common lumber would be greatly reduced.
gaproperty
I am looking for an opinion what the log in the video is worth.  So this maple log is 8.5 feet long 3 feet in diameter.  Would it be veneer grade.  What could it be used for instead of just firewood.  Here is a video. Look at the first log that is pulled to the tractor using the winch.  This is the log I would like an opinion on as to what it can be used for other than firewood.
https://youtu.be/r0wcOHGX3RA
Ray
lostcaper.com
youtube.com/c/LostCaper
mike_belben
I havent encountered a sawmill that follows anyone elses rules.  For me to get veener on anything itd need to be 10'6 min.  THEY might be able to resell a shorter log to the veener buyer theyre yarding for.. But IM not gonna get their veneer price.
I see some nice sawlogs but being 8fters puts them down to a 1com rate where i sell.  With that much diameter you might be able to get the scaler to bump them up a little higher.
Theyre your logs.. Theyre worth what youll accept.  Trim them up nice and load them up, cruise over to the mill and say "whatll ya give for these?" before unstrapping.  They might overlook the length to buy the diameter.  Here id get .65/bf as 1com or 1.10/bf primeA.
If it measures 36" inside bark at the small end you got 512/bf doyle.
Praise The Lord
Clark
Quote from: gaproperty on July 08, 2017, 08:11:56 PM
I didn't watch the video but based on the amount of heart I can see in the preview photo there is no chance it will ever sell for veneer.
Clark
SAF Certified Forester
