Husky gas/oil mix?
Started by Kevin_H., June 12, 2003, 06:43:30 PM
Kevin_H.
Just wondering if the Husky uses the same mix as a stihl?
My local pawn shop has a Husky 136 for $89.00, that's about half of what northern wants...Looked at it a couple of days ago and the bar still has the husqvarna name on it
I think I will stop in tomorrow and see if it starts
Got my WM lt40g24, Setworks and debarker in oct. '97, been sawing part time ever since, Moving logs with a bobcat.
Kevin
Kevin_H.
SawInIt CA
Most guys that rebuild saws will tell you to run 32-1 in Huskys and Stihls. The 50-1 is to pass lower emissions at the cost of longevity.
woodbeard
Also keep in mind that the 136 is really a Poulan.
Not to say it isn't a good machine.
And made in the good old USA!
Kevin_H.
Thanks for the info,
I have a stihl 017 that I use to trim with around the mill and I have a poulan "wild thing" that refuse's to run once it gets hot.
local chainsaw guy say's my poulan has scared cylinder walls because I was running the stihl mix instead of poulan...
I wasn't going to buy the husky if I had to carry two different mix's with me.
I plan on buying a nice stihl with a 20" bar this fall when they go on sale at our local farm store.
Thanks again for the input.
