one of my friends cut a finger off on the tablesaw
Started by Part_Timer, July 07, 2008, 09:14:12 PM
Part_Timer
This could be here or in the safety area
One of the guys that works for me cut his thumb, index, and middle finger of his left hand on the table saw on saturday.  He lost the index to the second joint.
PLEASE take the extra time and be aware of the set up you choose.
Peterson 8" ATS.
The only place success comes before work is in the dictionary.
That's not good.
Did he slip, fall asleep, or a board kick back?
I worked with a man that had something similar...but due to wearing leather gloves that were required by the safety procedures (so he wouldn't get splinters from the wood). The leather caught up in the blade, and pulled his hand down into it.
Tom,
A little bit about the circumstances would be helpful and appreciated.
bck
have you seen the table saw thats out now that will stop the blade before it can do damage to your finger?  Was looking at it the other day, I think it was at sawstop.com
I think when I replace my tablesaw thats the way Im going.
TexasTimbers
Ouch. Sorry to hear it.
bck there's a whole lot to be read about the Sawstop. Been out for at least 3 years I believe.
Some think it is a waste of money. I have mixed feelings on it. I think it is a smart choice for many types of personalities/experience levels. The guy or gal with the personality that says they are a little smarter than the rest of the crowd probably need it more than the rest of the crowd. The "weekend warrior" that uses a saw a dozen times a year probably needs one.
But of course anyone can get lax and careless in the woodshop. Some think the seasoned pro is more apt to become careless than the weekend warrior. It's hard to know. All I know is anyone who ever loses a finger will say in hindsight it's a real cheap piece of machinery.
ADAMINMO
I saw the Sawstop table saw being demoed at a woodworking show once. Really cool machine. It barely nicked the hotdog before the blade was stopped instantly. They say it works on a human body part like it does a hot dog. You can walk away and put a bandaid on it versus losing it and having a hefty doctor bill. Wonder what the first guy was thinking as he stuck his finger up to the blade to see if it would work on his finger like it did on the hot dog. I wouldn't have been the first to do it. Anything could happen .   ... Like stick in your finger and the saw dont stop , assembly guy says " Whoops.... I forgot to hook up the sensor didn't I? Sorry about that Pete , Let me go find the end of your finger and get you to the doc  and then I will hook up the sensor and you can try it again."  " Ok Bubba ... I sure can't wait to stick my finger in that blade again":D  :D  :D The one I seen demoed worked like a champ though.I think you are out the cost of the blade and a new aluminum brake. Well worth the money spent on it versus losing a digit and paying a doctor bill.
Fla._Deadheader
You're telling us, that, if I'm cutting a chunk of wood, and manage to get a finger into the blade, there is a sensor that will instantly stop that blade, before I can pass that finger through the blade ???
  Sorry, I don't "test" the wood, to see if my finger can touch the blade. I just cut the wood.
  I don't believe the story, Sorry.  ::) ::)
thedeeredude
Youch!  I hate tablesaws.  I think its good to be scared of machines like that, it reminds you what can happen and you think things through more.  When you think you own the machine is when it bites back.  I have heard that the saw stop really does work from someone who found out the hard way.
ohsoloco
Harold, the sensor detects something like a finger, and then releases an aluminum "brake" pad into the blade.  It ends up wrecking the blade, as well as the brake, as the aluminum gets fused to the blade.  Still pretty cheap considering the alternatives.
http://www.sawstop.com/
Yep.. the system does actually work.
The whole saw arbour is on insulated bearings and is carrying a low voltage ac current. When something conductive (like a finger or a hotdog) come in contact with the blade it instantly changes the electrical characteristics of the circuit. This blows a fusable link in the cartridge and a big spring throws a chunk of alloy into the blade. The momentum of the blade is then used to retract it away from the stray finger and under the table top.
Downsides - it wrecks the blade, and you have to buy a new cartridge as well. You can also accidently trigger it with wet wood or an alloy fence or guide. It does have a switch to lockout the brake cartridge for those situations though, also lets you do the hotdog test without actually tripping the brake (A light just comes on)
Upside - you get to keep your fingers
Larry
Well ok....since ya brought up a finger story...my finger started throbbing.
Some 30 years ago I had a molding head on the tablesaw.  Molding a little trim out of redwood.  For some reason the board exploded and two fingers along with my thumb ended up in the blade.  The thumb just had a small scratch, the first finger required a couple of stitches.  The index finger was a 1/4" shorter, the nail was gone, and the first joint was shattered.  Eight hours in the OR where my buddy, the surgeon did micro surgery...without a microscope.  He put a screw about 1-1/4" long down through the joint to hold things together, stitched enough fingernail tissue back on so the nail grew back, and somehow put the nerves back together so I have feeling in the finger tip.
The joint is stiff and the finger gets cold easy.  And every time somebody starts a thread like this I think of the accident after all these years.  It also has helped me remain accident free for the last 30 years.
Although the accident happened at home my experience level at the time was professional...my first job out of high school was running a tablesaw 40 hours a week which I did for a couple of years.  The cause of the accident was because I was not using proper hold downs.
Oh yeah...the bill was $3,000 or so which I thought outrageous.  Might be a tad more these days.
I've seen the Saw Stop demo in KC were they actually wrecked a blade...impressive.  I don't have a Saw Stop and don't intend to buy one but I do use guards and hold downs.  More importantly I pause to think before hitting the on switch.
Dave Shepard
As Kevin mentioned in the safety thread "Don't get complacent". That is my mantra every time I start the chainsaw now. I've always been leery of table saws and such, will have to keep the mantra in mind in the wood shop too.
Part_Timer, sorry to hear of your friend.
Dave
woodmills1
I try to keep my hands away from the blade at all times.  For 95% of my regular ripping I push the board half way then pull it out, flip it over, then finish the rip.  For any other work I use hold downs and push sticks.
Part_Timer
The guy was using his left hand to help hold the board against the fence and guide it into the blade.  He says the board jumped and his hand went forward and the fingers went in.
I'm going over to see him tonight.  Bad part is he is a PLC programmer and graphic display designer for our systems here at work. Typing is a major part of his job.   I'm sure he will adapt fast. Lots of work using a mouse is in his future.
Peterson 8" ATS.
Brad_bb
Yeah, that sucks.  My fingers are worth more than a wood working project.  Unfortuneately I have a delta unisaw without the safety features, I respect it well and use push sticks etc.  the Sawstop does work.  I was an engineer at Bosch until last year and saw it demo'd there.  Most of the table saw manufactuers got together to understand it and consider safety.  It is added cost, but it does work well. A hotdog (being the closest thing to a finger) does stop it.  I do believe someone did try it with a real finger only got a cut like on the hotdog.
SeeSaw
FDH,
I didn't beleive it either,  but I saw it demo'd on DIY network on cool tools and it works just as stated above.  Pretty impressive really.
SeeSaw
Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, completely worn out and loudly proclaiming, WHAT A RIDE...!
Dodgy Loner
I think the most important safety feature that's missing on our table saws is not the SawStop technology, but the riving knife.  In your friend's case it may have prevented the board from jumping up in the first place.  Kickback is the most common safety issue with table saws - think about how many of you have had a board fly back at you versus how many are missing fingers.  The anti-kickback pawls and blade guards on most table saws are poorly designed.  I know very few people who don't remove them.  A riving knife, on the other hand, moves with the blade, so it doesn't interfere with any type of cut, and it still prevents the board from pinching the back of the blade, which is what causes kickback in the first place.  I've had enough "close calls" with flying boards that won't buy another table saw without a riving knife.
treecyclers
The SAWSTOP tablesaw is a true woodworker's dream saw.
It works as advertised, and has saved countless fingers and hands since it came out on the market.
The biggest downsides to it are it's price tag (They start at just under $4000 for a decently equipped saw), to over $7500 for the top of the line with all the bells and whistles.
I sold them for a year for a friend's shop, and the horror stories I heard time and again were gut wrenching.
The one that I remember the best was the call from the shop that had bought 2 saws.
Their saw man was running hard and fast that morning, and had tripped the two brake cartridges they had, plus their two backups. They had called to get more cartridges, and wanted to be sure we had them in stock.
I got a call from them about half an hour later, telling me that their saw man had jumped over onto their old powermatic 66, and had proceeded to cut off 3 of his fingers within 15 minutes of starting it up.
New SAWSTOP tablesaw - $4000
One brake Cartridge - $75
Having all your digits at the end of the day - priceless.
I respect that some folks find the concept of the sawstop difficult to believe. I myself didn't believe it until I watched it with my own eyes.
When anyone comes in looking for a new tablesaw, I would always show them the sawstop, as well as every other saw in their price range. It amazed me the number of people that would choose the sawstop over any other saw, regardless of price.
That being said, I asked my fiancee what she thought the cost of having a finger re-attached would cost, being that she's an RN.
Figure somewhere in the ballpark of $18,000.00, give or take.
And that's assuming that they're able to reattach it.
SD
I wake up in the morning, and hear the trees calling for me...come make us into lumber!
Quote from: Dodgy Loner on July 09, 2008, 01:01:05 PM
...........the riving knife.  .............  A riving knife, on the other hand, moves with the blade, so it doesn't interfere with any type of cut, and it still prevents the board from pinching the back of the blade, which is what causes kickback in the first place.  I've had enough "close calls" with flying boards that won't buy another table saw without a riving knife.
I'm not picturing the riving knife you describe (moving with the blade). Best I come up with is what I'd call a splitter that is in line with the sawblade, and prevents pinching of the back of the saw blade. I added one to my table saw, as most of the work I do on the saw is without the guard, which includes the splitter.  Is the splitter and riving knife on a table saw one of the same??
Dodgy Loner
No, a splitter is stationary.  It interferes with non-through cuts, such as dadoes and grooves, and the distance between the back of the blade and the splitter will increase as you lower the saw blade.  A riving knife, on the other hand, moves up and down with the blade, so it will not interfere with any kind of cut.  Also, it's always the same distance from the back of the blade to the riving knife, so there's no chance for the kerf to close up before contact like there is with a splitter.  As far as I know, it's not possible to add a riving knife to most American table-saws, but they are (fortunately) becoming more popular.  They come on all SawStop table saws.
treecyclers: it sounds as though the fellow you describe had no business using power equipment of any kind.
metalspinner
That 4 grand buys you one heck of a table saw.  Everything that I have read about it puts it above the Powermatic 66 as far as features and heft... plus the blade stop technology.
Sorry to here about your friend. Not long ago, a buddy of mine had a jointer accident.  He still is reluctant to discuss it. ::)
Treecyclers,
That figure sounds about right... just for the ER bill.  You need to figure physical therapy after all is healed up a bit , too.  Oh, also time lost from work.
I agree with Dodgy about the cabinet shop fellow.  He sounded very reckless and possibly a danger to others.  Just because I am wearing a seatbelt in my car doesn't mean I should go tearing around town like a maniac.
The Sawstop cabinet saw is on my "someday" list.  Just hope "someday" isn't a day too late. ::)
OneWithWood
My Powermatic 2000 came with a riving knife, kickback pawls and clear guard.  The pawls and guard atach to the rining knife so everything moves with the blade.
Sawstop is still on my wish list.
One With Wood
Dodgy Loner
Quote from: metalspinner on July 10, 2008, 10:32:08 AM
I like that analogy, MS :).  The SawStop is a great invention, and I'm sure it will save many digits (as it already has), but safety starts with being familiar with your equipment and aware of your work environment, and taking proactive steps to prevents accidents from happening.  I'm not what you would call a "safety fiend" - I still drop-start my chainsaw (hey, it's got a chain break ;)), and I make an occasional cut on the table saw without putting on my safety glasses first (no excuse for that one) - but I always try to think before using a power tool and making sure that my flesh will remain clear of any rapidly moving parts.
I lost the end of my middle finger on my left hand to a 10", 5 horse, Unisaw at my Adult Education Shop Class.  It didn't even slow down. :D
I was being as careful as could (new to be) and now know a lot more about how the body reacts to sudden changes in the environment than I once did.  Basically, I chalk my injury up to ignorance.
I was cutting a piece of cedar that was really too short to be handling by hand and maybe even too short to be using a push stick.  I don't remember how short it was, but I think it was in the 6" range.   I had actually completed the cut, pushing it through with a push stick, but it didn't clear the back of the blade.  I reached around the back to pull it out and there was much clatter.  The short piece of wood must've begun to move and my mind was set on grabbing it .  It all happened so fast that my mind didn't get turned around and I guess it was instinct to complete the original action.  I grabbed at the wood, which was being kicked by the blade and my middle finger hit the teeth.  The injury was lightening fast.  I immediately knew I had done something to myself, grabbed my left finger with my right hand squeezing it tightly and holding it to my stomach.  I was afraid to look.  There was blood, but I was holding it tight enough that it wasn't pouring.  I asked for a rag and looked at the finger as I wrapped the rag around it.  "I think I should go to the emergency room".  I told my buddy.
The fat tip of the finger was gone and the nail was cut back into the quick.  The big concern was that the bone had been chipped.  Bone infections from wounds like this are common and very dangerous, I was told.
The wound wasn't closed, it was covered with a mesh simulated skin and gave the skin something to attach itself to as it healed.  It was covered and I was given pain medication and told to hold it over my head.
I was distraught.  "Will I be able to play the guitar", I asked?
The emergency room doctor got this look on his face like he had never been given an opening like that before and he wasn't going to miss it.   "I don't know", he answered, "could you play one before"?
My wife was there by then and the Four of us, she, I, my friend and the Emergency room doctor, just about brought the house down laughing.   It probably didn't hurt the joke any that my mind was numbed with some powerful drugs either. :D
Anyway, I began reading about tablesaw safety after that and found a lot of things I didn't know about the handling of the tool.  Today, I'm a lot more knowledgeable but forget what I don't use.
Thinking back, I'm a bit disappointed that the instructor turned us all loose in that shop without some preliminary education.  His idea was that we paid the taxes for the equipment and it was there for our use. He spent the time in his  office.  Actually, all of us were there hoping for some kind of instruction as well as having the use of the equipment for special projects.   There was even one fellow that signed up for every class, there were two a year, to plane all of his rough wood.  He would come in with his pickup loaded to the gills, plane the wood and leave.  The twenty dollars for the course was cheaper than buying a planer.
Now, I read anything I can on tool safety.  I still don't adhere to it as anally as some people.  I still run the chainsaw in work clothes and don't put on my hardhat to drive the tractor, but, at least, I know that those things are recommended by some people.
