PLEASE, 'Splain Me
Started by Fla._Deadheader, June 26, 2008, 08:42:12 PM
Fla._Deadheader
 I'm studying and playing with an idea.
  Could anyone or all of Y'all, "splain me how this Electronic Fuel injection works. How it atomizes the fuel, and how it's timed. Can the timing be drastically changed ???
  Be as technical as possible  ::) ;D ;D
olyman
you can change the timing on a car fuel injected by "reburning" the computer----any fuel injected engine can be changed--if you can hook into the computer!!!
stonebroke
As I understand it, Electronic fuel injection is a solenoid that opens and closes the injector. it is controlled by sensors on the crankshaft that tell the computer where the pistons and valves are. it is really a better way than the old mech. systems that were linked by gears and could not be adjusted on the go.
Stonebroke
Fla._Deadheader
OK. Where does the pressure come from, and how much ???
  Is there a seperate injection pump ???
stonebroke
The pressure comes from the injection pump. The pressures on modern diesels are very high. The electronic part is just to control the fuel flow.
Stonebroke
Fla._Deadheader
What about so-called fuel injection on gasoline engines ???  What are the thingys in the throttle body, and if they are injectors, where is THAT pump ???  Could they be used for direct injection ???
low_48
The fuel pump on a car is in the tank. I think they are all vane pumps. Here's a pretty good link;
http://auto.howstuffworks.com/fuel-injection.htm
amberwood
Ok
it can be supplied in two ways
low pressure pump usually in the tank, then a high pressure pump down the line to feed the injectors, or just a high pressure pump in the tank.
electricaly controlled injectors, usually one per cylinder for OEM squirting into the manifold, idealy at the back on the inlet valve, but depends upon the manufacturer and packaging requirements. Higher spec vehicles may have multiple injectors per cylinder to supply more accurate fuel delivery at low demand, then bring on more injectors for high demand high HP use.
An ECU or computer to control the whole mess, relies on inputs from external sources such as throttle position, water and air temp, manifold presure, exhaust temp, o2 sensors, air flow meters, fuel pressure etc etc. It depends alot on the age of the system and the manufacturer. Most OEM ECU's can be reburned to change the program, or piggyback ECU or chips can be changed, or you can replace the whole ECU with one from MOTEC or similiar.
confusing?
DTR
MS460 Magnum
MS250
DAF CF85-430
ASV RC-85 track loader
logwalker
Our turn, why are you wanting to change the timing? Joe
Fla._Deadheader
 I want to inject water vapor at BDC.
logwalker
What happens to the H2O at BDC? Have you looked into Bruce Crower's 6 stroke cycle engine? Joe
http://www.autoweek.com/apps/pbcs.dll/article?AID=/20060227/FREE/302270007/1023/THISWEEKSISSUE
flip
Normal gas fuel injection uses 40-60 psi for pressure.  If you ever take an injector out the atomization holes are very very small. Fuel pressure is on the injector at all times and the computer determines, in miliseconds, how long to open the injector. Timing is determined by engine RPM, engine temp., throttle position, ambient temp., quantity of air entering the engine, barometric pressure, oxygen sensor feedback.  They shoot in right above the intake valve.  Now if you are feeling saucy look at NOS (nitrous oxide systems) set up.  They bore a hole in the intake in each runner for fuel injected systems to inject the nitrous, carb systems use a place under the carb.  Problem with that is it dumps in all cylinders all at once, no regulation or timing.  If you inject water on the intake stroke, unless you have some sophisticated engine management systems, you will be diluting the atomized fuel and putting out the fire.  Not saying it can't be done but you would need to engineer a timed delivery system, independant of the fuel deliver system which would be piggy backed to a cam sensor or crank sensor.  I don't even want to get into the situation if one of the water injectors sticks open, Mr. Rod will come out for a visit :(
Timberking B-20, Hydraulics make me board quick
Fla._Deadheader
 I used to run an 8 cycle engine.  ??? ???
  My idea is way past what I want to explain. I just would like to know the answers to my questions, for now. Later, IF I get this to work, I have a list of folks here that I will share with.
  My world, right now, is running in many different circles. This is why I need y'all's help.
QuoteNot saying it can't be done but you would need to engineer a timed delivery system, independant of the fuel deliver system which would be piggy backed to a cam sensor or crank sensor
  Flip, this is EXACTLY what I am talking about.  8)
flip
Most sensor systems run off of a 5 volt reference system.  I guess I don't see any reason you couldn't tap into the cam or crank sensor and use that as your timing device.  You would need to be able to advance or retard your water injection based on that signal for proper combustion, which is where some type of mgt. system would be needed.  Not impossible but very intriguing....what kind of debauchery are you up to ??? ??? ??? ;)
Fla._Deadheader
Quotewhat kind of debauchery are you up to
  Right now, I'd rather not divulge my idea.  ;) :) :)
  Got any devices in mind that I could read up on ???  Anyone ???
flip
What kind of vehicle or application.  Model years.  Engine sizes?
The world I know with Ford, our diagnostic equipment is about 7G a wack.  But we are not able to modify or tweak any settings, just monitor and reprogram if there is an update for the software.  I know there are things out there that people are using to get in and change some settings but am not sure who they are or what type of software they use.  I can get EEC 5 or OBD 2 cables for a lap top no prob. but need to know what kind of veh. you're playing with.
http://wiki.xtronics.com/index.php/EFI_ECU_FAQ
This may be a starting point...
Fla._Deadheader
Alright, I know you are really trying to help me, so, I am wanting to add water vapor injection to my '78 Land Cruiser Diesel. Injecting at BDC will cause the vapor to increase in volume as the piston rises and compresses, in the cylinder. As this happens, the vapor will flash to steam, and as the cylinder fires, you get a LARGE increase in power from the expanded steam vapor.
  That's why I need a seperate injection system.
flip
OK, diesel.  I know the tractor pulling guys use this for extra bang, let me look here...
http://www.scheiddiesel.com/waterinjection.htm
Scheid is not too far from me and one of our parts guys worked for them for a while.  This should be near the same principal.  I would think you could probably fog in the water mist into the intake and let vacuum from the intake stroke do the rest.  All you need is a way to atomize and regulate.  You may not need computer controls knowing the rest of the story. ;D  In a house I use to live there was a humidifier nozzel installed that was about the size of a shirt button, small hole, very fine mist and just used house water pressure. Hmmm, let me do some more thinking. :P
Fla._Deadheader
I'm sure that misting into the manifold, on a diesel, is not real effective, because of the lack of vacuum. It NEEDS to be injected at the BOTTOM of the stroke. When compressed, it makes a somewhat superheated steam, that gives a LOT of uumph to the power stroke.
Interesting idea Harold.
Here is another discussion, that seems related to what you are investigating.
http://forums.tdiclub.com/showthread.php?s=11a86be56faba954b45a6e116cf7bb8f&t=202520
To me, compressing steam makes me think of a lot of engine knock... ;D  I like your thoughts tho.  :)
Fla._Deadheader
Not compressing steam, water vapor. That's why injecting at BDC is necessary.
StorminN
All you need to inject steam is an original early-to-mid 80's 6.2L GMC... if the heads aren't cracked yet (unlikely) take it up a big hill to heat it up and drive fast down the back side... this chills the heads, "crack" goes the little valley between the valves, and PRESTO, you've got steam in your diesel! Of course you can "fix" this by pulling the heads and sleeving them, but that takes the fun out of it!
P.S. I'm sorta joking, but even so, I've still have put about 700,000 miles on these motors over the years...
-Norm.
Happiness... is a sharp saw.
flip
If injecting is what you are going after, short of getting rid of your glow plugs and having a nozzel made for that port, along with the other complications, I don't have any good suggestions.  I did talk with a few of my techs here and they did think that the water mist in the intake would work, maybe not as well as direct injection but a heck of a lot less machining and electronic and injection devices.
Dale Hatfield
The currant method of water injection in diesel is  on the pressure side of the turbo. For example its onthe intake horn on my dodge after the turbo and intercooler. Its also a methenal injection system. Does it improve fuel milage no. A little bit more power. Big bennie for me is the cooling effect. It lowers EGT temps that can keep me on the go fast  for much longer on long hard pulls.  It has a computer controlled unit to allow  when the mix is injected into the intake.  If it comes on too soon or too hard it puts the fire out. dead in the water .
It only works under boost. not all the time.
Based on your info on the yota  it sunds like its a non computer controlled motor. The  best would be with a ecu ecm fueled truck something you could tap into.  A non comp truck would need a computer that controlled the injection at the correct timing.
Dale
Chainsaw Carver
Fla._Deadheader
  OK guys. I know about "Current" water injection.  That's NOT what I want to develop.
  When water is turned to steam, it expands 1400 times it's volume. I want to INJECT VAPOR at BDC so, when it turns to steam, it's AT TDC, AFTER the diesel fumes fire. This would be adding STEAM power to the Power stroke. Has nothing to do with putting out the fire of diesel, so to speak.
  Manifold injection is not what I want.
  Back to more thinking.  ::) ??? ::) ;D ;D
