one tough hickory
Started by Lanier_Lurker, June 25, 2008, 12:13:54 AM
Lanier_Lurker
This small pignut hickory tree is growing on the edge of the lake bed of Lake Lanier here in Georgia.
This first picture shows that it seems pretty vigorous and healthy.
This second picture shows the hardships it has been coping with.  Once it reached about 4 inches in diameter someone decided it needed to be cut.  Then it sent a couple of stump sprouts out.  And somewhere along the way, the water level of the lake washed out and undercut the bank - exposing much of the tap root.  This little tree is certainly determined.  :)
The sweetgum is trying to lend a hand ;D.
Dave Shepard
First time I've seen that technique to get around the 450 pixel limit. :D
Dave
Lanier_Lurker
Well, I figured it was a reasonable thing to do since there is apparently no limit (that I have found) on either the number of pictures, or the total aggregate size of all pictures, that can be included on an individual post.  I've seen single posts from other members with over 20 pictures in them.  At 40KB a pop, that can add up.
I do ensure that the composite picture will render correctly on a screen that is 1024 pixels wide.  Very few people nowadays use a horizontal screen size smaller than 1024 (especially with the 16:10 aspect wide screens).  I also try to keep the total size of the composite picture as small as possible.  Most of the individual "piclets" are well under the FF size limit.
With plant id pictures in particular, one good picture is worth a dozen mediocre pictures.
Don P
It does come up on my slow connection as 9 red x's though, as do many of the pic intensive threads. I can bring them up a click at a time but its something to think about. The you tube links usually just time me out :-\
Quote from: Lanier_Lurker on July 27, 2008, 08:17:30 AM
Say it again, brother!
