chimney caps
Started by mountaineer, June 17, 2008, 07:11:36 PM
mountaineer
i need to put a cap on my chimney and i have been looking around at other peoples caps on my drive to work. does anyone have the cap that has a top that turns whichever way the wind is going. i have heard these cut down on certain downdrafts. also, where could i get one? and do they work well?  thx andy
olyman
some people around this area have used the old caps they used on chicken houses--they would turn with the wind--and were about 9 in inside dia--
isawlogs
  I don't have one of those , on the house we have metal four sided caps with spark aresters . On my shop in Chelsea I put up a stainless steel cheminy but had no cap ...  I improvised one  ;D  Alls I had was a old 1 ton cheve truck hub cap . A few rivets and straping later , we had a cap for the cheminy  ;)
   Marcel
LeeB
Marcel finally found something good to use a chevy for. :D :D
logwalker
Quote from: mountaineer on June 17, 2008, 07:11:36 PM
We had one as a kid and it didn't work well. We took it off. Joe
Warbird
I've never heard of a cap like that, Andy.  I'm thinking about taking the cap off of mine this winter.  I'll leave it on until the roof has a good covering of snow.  My thinking is that removing it will improve the draft a bit and reduce creosote buildup at the top of the stack.  Do you guys think this will be the case?
mountaineer
i'm gonna drive down the hill and take a pic of the cap. i cannot find one on the net(and thats not usually the case)
mountaineer
here are two pics of what i am talking about. the top turns with the wind. do these work well?
I've been led to believe that they do not work well on a wood-burner chimney, but can work for a vent. Apparently the pivot point gets sticky from creosote and doesn't allow the top unit to turn away from the oncoming wind.
But have given it serious consideration.
Warbird
I'm thinking chimney caps for wood stoves are overrated and am considering taking mine off.
Andy, I've never even heard of a chimney cap like the one in that pic.  It's pretty interesting looking!
olyman
Quote from: mountaineer on June 18, 2008, 09:51:19 AM
THAT--is exactly what i was talking about--and friend next town over has used one that way for the last 20 yrs--and no problems--but he burns his wood hot-----
