white pine pitch
Started by Splinter, June 15, 2008, 04:11:53 PM
Splinter
Had some white pine milled up and its seeping some pitch.
How long before the pitch stops coming out of the wood? It will not be painted or sealed.
Kiln drying is not a possibility.
Thanks.
Until it's kilned. No kidding I'm afraid. If you use it for molding and paint or treat it, it will eat through the knots in the boards.
zackman1801
you can set it out and wait like some of the smaller mills do, but it could take up to 6 months to wait for, but then it will still absorb the moisture from the air if its humid or it rains.
"Improvise, Adapt, OVERCOME!"
Husky 365sp 20" bar
I had some setting for 3 years, it still weeped through knots. Ya gotta set the pitch to a crystalline form I think
isawlogs
It all depends on the size of the pitch pocket ...  :-\   I have some post that support my garage that are still weeping , five years later . It also depends on the thickness you had it milled , thicker will take longer to weep out and dry up .
   Marcel
Splinter
Thanks for the feedback,
Was going to use it for some picnic tables & seats..... Guess the kids are getting a new fort.
zackman1801
well at least you know that the napkins wont blow away on a windy day :D
maybe  you could put on some lacquer on it to make the pitch not come through, but maybe it would get through that idk?
Husky 365sp 20" bar
You can stop some minor bleeding with shellac.
Quote from: isawlogs on June 15, 2008, 07:12:15 PM
resin/pitch canals. Tiny little pores that bleed pitch.  ;)
Quote from: Splinter on June 15, 2008, 09:02:24 PM
Your gonna be loved with all those pitchy hands and clothes to wash. ;D
Splinter
Quote from: zackman1801 on June 15, 2008, 10:28:56 PM
Now thats funny :D
Cedarman
Put the pine boards in an attic or someplace that it will get very hot. Leave them there for a couple months if possible.  This should set the resin good enough.
Don P
I've been using the owners sauna at work for some white pine that I needed to push through ;D 3% per day and got it to 150* for hopefully long enough to drive off all the volatiles that would vaporize at up to that temperature. The attic would work too if the wood does not see the attic temperatures in service. A few years ago I resawed some pine beams in an old cabin. I had laid a few boards in the sun and some sticky droplets formed on the fresh surface. The wood was 160+ years old.
Phorester
"well at least you know that the napkins wont blow away on a windy day"
Or the kids.
As far as building with the white pine, I know that when when using any type of pine for interior trim it should always be shellaced as Tom says before painting to prevent the knots from bleeding through the paint.
