310 sensitive starting
Started by mrcaptainbob, June 07, 2008, 12:25:34 AM
mrcaptainbob
Had a scare yesterday. The 310 wouldn't start. Did not hit not even once! Stooped to letting frined use some starting fluid. Nothing. A few hours later, a new plug....stihl nothing! Removed the new plug and let it set overnight. This morn I just set it to the 'idle' on position. No choke. Started right up! So...87* and much humidity requires no choke. Never ran into that before...but that's the first way I go from now on. I can always bump it a bit to choke if it doesn't start right off.
logwalker
If it really was flooded then open the throttle all the way and crank. It will usually start eventually. But when they flood they almost always make a little burble when they try to start. Kinda strange. Joe
