My adventure or don't try this at home
Started by Moulder, June 01, 2003, 07:56:36 PM
Moulder
Well I had the chance to get a rather large butternut tree and being a bowl turner I thought that this would be nifty to make large bowls out of . There is a whole story of how I got the logs out of a tiny tiny gated back yard but as I say that is another story. Everything was going on hunky dory as I was cutting out my bowl blanks in mass {these mills are wonderful to do this on and beats the heck out of trying to slab with a chain saw} with visions of  forms and curves dancing in my mind,when I came to the last log the creme al la creme. Butt end 29" 5 feet long tapering down to only 28". Oh baby I know I'm going to have to turn these bowls on the outboard side of my lathe. I crank this beauty up on the mill and whats this? Well I have just dropped this 400lb monster between the bunks. OH DARN! [this shows my level of dismay] Ok ok I know that this has never ever happened to you'll,but being a avid reader of this forum I thought about it a moment got a log hook out attached to my winch stuck the log hook into the butt end of the log and cranked away! Wow this is cccoool its working its working snapp whats this ??????  Will you look at that it's a log hook know embedded in my forearm. Being a nurse with lots of alphabet soup behind my name married to a nurse with alot of alphabet soup behind her name this problem was easily fixed and with a min amount needles catgut and drug therapy I was happily on my way to solving the problem of getting my log back up on the mill. I am happy to report that with direct supervision from my wife that the log is now  in blanks ready to be turned into bowls as soon as I get feeling back in my arm.But right know I'm going to get myself a big bowl of ice cream with lots of hot fudge {no grits right now thank you] and with my left hand I'm going to make a huge mess but what the heck I'll find my mouth!
RANDY
Fla._Deadheader
Bet the arm is starting to hurt, eh?? If ya get where ya can type, would you explain how you cut the log for bowl blanks?? Crosscut or what?? I get some nice logs that would be good for bowls, if I knew how to cut them. ::)
Don't forget the crushed pecans. They always help make me feel better on my ice cream and hot fudge. :)
Yeah, and the second bowl is even better yet.  Makes you want to drink a glass of ice cold milk for some reason or another. Water will do in  pinch though.
The log won't go anywhere if that's any consolation. :D
Man, I'll bet that smarts!  Don't you just hate it when you do that?
Moulder
Jeff I'm not a nut kind of a guy but after all the hot fudge I probably won't  be able to sleep to night.
Deadheader  when you cut bowl blanks especially for large bowls you want to present the side grain to the tool instead of end grain. The side grain will be stronger in the bottom of the bowl. So  I find that it is easier to work in 5 ft lengths of log since my bunks are 4 ft spaced.[you will see why in a moment] First you want to cut parallel to the bark, Turn the log and make your next cut, now  at this point you need to evaluate where you can get the most wood in relation to the pith of the tree. You ideally would like to make the next cut about 1" above the pith  so that the pith is not in the blank. Since the pith is basically hollow you are about certain to get splitting  from this area .Since it is my experince that the piths are erractic in their travel it is much easier to have shorter lengths of logs to work with  since you may have to taper the log to get as parallel cut to the pith. If you are going to turn the bowl soon cross cut the bowl blank to the width of the wood ie 12'"x12" .If you are not going to turn the blank soon leave the wood as long as possible because the ends will probably split and this will allow  the turner to trim off the ends until he/she gets to solid wood. Splits are the enemy of the wood turner once they start they are hard to stop. Always seal the end grain with something,endgrain sealer, paint what ever to slow the drying. Give the turner as much wood as you can as he can always waste the wood when he is turning. I generally try to give myself 4" as a min but 6 to 7" is better.I hope I have not rambled much if you have any questions I can help with give me a hollar. Hollar if ya hear me. Randy
RANDY
Fla._Deadheader
So, you are actually sawing cants off the log, leaving the pith in the wedge?? That's no problem. My log stops are 32" because we buck the logs and have short sweeps and crotches and ?? to deal with. Sometimes the log leaves a short piece that just doesn't make a good long log?? Thanks for the explain.
Percy
Heya Moulder
Not to be a smartass but, better your arm than your forehead ya? It can happen so fast. When I installed a MkII debarker on my old LT40, I was watching it work for the first time and had planted a nugget into the log, right in the path of the debarker just to see it perform. Well that nugget drilled me right in the middle of my forehead quiker than I could close my eyes. Had a biggass dot there for about two months. Not as serious as your situation but a tad scary none the less.
On the ice cream thingie, ya ever had Strawberry Cheesecake Ice cream?...ooooh lordy, I can eat that stuff till I puke....... ;D
Neil_B
ROLO ICECREAM, MMMMM. :D
Take care of that arm Moulder
Timberwolf / TimberPro sawmill, Woodmizer edger, both with Kubota diesels. '92 Massey Ferguson 50H backhoe, '92 Ford F450 with 14' dump/ flatbed and of course an '88 GMC 3500 pickup.
chet
Percy, I'll bet ya felt perty DanG dumb after dat nugget drilled ya.   ;)  Of course most of da rest of us never tried nutt'in we wish we hadn't.   ;D
Take care or dat arm Moulder, ya only gots 2 of dem.
Brian_Bailey
Moulder,  My arm ached all night thinking about your mishap. Here's to a fast recovery!
Below are some pictures on how I go about getting bowl / turning stock using my mill.
This is one of those sugar bush maple logs. This log is about 14" on the small end and I selected it because of the spalt in the butt end.
Using a chainsaw I blocked the log into 16" sections.
Using my crane I set the block onto the mill.
I use a couple of boards to keep the block on the mill. I position the block so the center crack is parallel to the mill bed. I cut the slab, then lower the blade down to get the max.thickness but stay an inch or more away from the pith.
Here is the 1st.blank.
I flip the remaining section over and repeat cut.
On this section I was able to get a 5" thick blank. The remaining piece, I cut the same way, only I'm getting blocks that are 4"x4" or whatever thickness the section is.
I then use a drawknife to remove the bark and then paint the whole blank with anchorseal.
Here's the bootie from that log.
I did this to some cherry, now all I have to do is find a buyer or I'll be in the bowl business too.
WMLT40HDG35, Nyle L-150 DH Kiln, now all I need is some logs and someone to do the work :)
Moulder
Brian I was looking at your pictures the bowl blanks are right nice.I wish I could find a better way of sawing my blanks in smaller lengths because as small as you have them the pith would be easier to get ride of . As it is now I tend to get some drift and end up with the pith in some of the blanks.Just as a side note, you may consider cutting them in longer lengths just in case they have to sit for awhile.Even with the anchor seal some woods are prone to splitting out. Most turners I deal with want to get to the wood asap before it even has a chance to think about splitting.For your customer base you may want to contact the American Woodturners Assoc. They put out a booklet of all the clubs in the US and Internationally along with members names ect.I don't know where you live but chances are there is one near you.If you would like let me know and I will get there adress and e-mail to you. Now about that crane! Thanks Randy
RANDY
Fla._Deadheader
Very interesting Brian. Thanks for the great pics. ;)
Brian_Bailey
Moulder -    Thanks for the offer on the Turners assc. I have the Nat. & some local web sites bookmarked.  I'm near Buffalo,NY and there are 3 turning clubs there.
I had a specific request from one of the members for the 16" lenghts.  I cut some boomerang cherry ( boomerang, is my term for a crooked log, real crooked, that's where the figure is ) like you stated earlier as a 5' section.  I had problems getting away from the snaking pith with the longer lenghts. So, if I cut any more I'll keep them shorter because of the pith issue.  Hopefully,  they wont sit long but I sense a pricing issue as I'm not going to give them away.
Neil_B
How do you price something like that??
I've got a nice crooked chunk of cherry that would be perfect for blanks as well as a big chunk of maple that used to be about 36 diameter but is split in the middle. could probably get 2, 24" by 12" blanks out of it.
Brian_Bailey
New_Sawyer -
  I'm figuring the price of each piece by the avg. bf of the piece.
  As far as value, I took into consideration on what the piece would be worth if I had sawn it into lumber. I also considered the character ( figure, spalt, etc.) and the amount of time I invested into cutting this specialty item.  I also checked out what simular items were selling for.  The value that I came up with was $2 / bf.,  which I think is quite reasonable with everything considered. I'll know in a couple of days.
One consolation is, come winter if they're still here, a couple of wacks with the splitting maul and they'll fit the wood stove quite nicely.
Moulder
Guys on pricing of bowl blanks, one of the wood turning mail order bussiness I work through sells ambrosia maple a block 4/4/10 inches for aound 20.00. Now this comes out to about 2bf.I'm currently at work so these are ruff figures as i'll probably get my hand spanked for being in the forum right now. Anyway that works out to 10.00 a bf. I was talking to Alan and he told  me to double the price of klin dry 4/4 and go with that. So with that in mind if you have a blank 12/12/5 that gives you 5bf. say it is in cherry which if memory serves correct is about 3.75 a bf  the starting price would be 35.00.I believe that this will hold out as I have blanks  auctioned off for more than this.The last blanks I sold off were some butternut 10/10/4 which is 3bf and sold for 20.00 a piece. I plan to expand selling and see what happens, I am fortunate in that the club I belong to is about 300 strong.Also to let you all know that blanks are also sold by the pound but I have no experince with that and would not know were to start. Anyway hope this was some help and also if anyone else has experince with this I would like to here from you.Randy   PS another area is exotic woods they are hugely expensive but really sell well.
RANDY
Brian_Bailey
Moulder -
 When you refer to an auction, is this a local one involving the club members or something like Ebay? Twenty $$ and up wouldn't be hard to take. Brings a smile to my face just thinking about it :D.
 The local woodworking store has bowl blanks available in the ten to fifteen $$ range.  That kinda limits the price unless you have something very unusual.
Moulder
Brian,This is a auction that the club holds during meetings. I have a friend who states that he has seen blanks on e-bay but I have no personal knowledge of this.Tell you what if you do come up with some unusual let me know and I'll see if I can peddle it for ya. Anything with burl prefix or sufix can be a winner. Randy
RANDY
Brian_Bailey
Moulder -  Thanks again for the offer.  If I ever come across some burl, I'll give you a holler.
CHARLIE
Hey Moulder, here's a small 8 1/2" Cherry Bowl I just finished. I put a walnut rim around it.  Whaddaya think?  I'm glad to see some other turners on the forum! 8) 8)
Charlie
Brian_Bailey
Beautifully done bowl, Charlie.  I see you have the segment joinery down pat!
Fla._Deadheader
Nice bowl, Charlie. Ya don't reckon it will ever split??  Hard to imagine that wood will split after being sawn, but, the bowl won't.
Norm
Nice work Charlie, I was hoping to see an example of bowl turning. The walnut cherry contrast looks great.
CHARLIE
Thanks for the compliments, everyone. I'm just glad to know that there are other Forestry Forum members that are woodturners.  I always learn stuff from other turners. :)   Fla_Deadheader, do a search in the archives for I reported on a method discovered by a woodturner in Hawaii on being able to turn green wood to completion without splitting by soaking it in dish detergent and water.  It works very well and allows a turner to complete a bowl within a week with green wood without worring about splits.
Charlie
OneWithWood
One With Wood
