Husky 61
Started by bandmiller2, May 03, 2008, 03:25:36 PM
Quick question guys I have a husky 61 ran and started fine last week.Today it will start right up then quit,will restart and quit choke can't keep it running.Yea its got gas,what should i check before getting into the carb.The electronic module was replaced recently and its run since.Thanks Frank C.
jokers
Captain
My Husky 61 will crank and run fine until it gets hot.  If you cut off the engine and then try to re-start in a minute or two, it will not start.  It has to cool all the way down before it will start again.
What do you think is causing this problem?  I am very frustrated with it at this point.
logwalker
CDI is a good place to look. Joe
sawguy21
Capacitor Discharge Ignition a.k.a ignition module. They can crap out when hot. Check for spark with a reliable tester as soon as it quits. If D.O.A. replace the module. If you buy a module and it does not solve the problem, the dealer likely will not take it back.
Thank you logwalker and sawguy21.  That is probably it.  I ran over the saw with the tractor.  That toasted the chain-brake and it needs a new cover (duct tape is wonderful stuff....).  Now a CDI probably.  Will probably cost about $250 - $300 to get it back in top condition.
ely
any updates on this 61. just curious i have mine in the shop now for repairs.
