Homemade dry kiln.
Started by Woodchuck53, April 06, 2008, 08:26:40 PM
Woodchuck53
Does anyone else think a 20' shipping container with 2 panes of 4x8 tempered glass facing south would work? I can get a container down here on the coast for about the same price as concrete and building a similar size wooden framed one. Probably put a lean to roof on it.
Add a fan to circulate a little air. It should get pretty hot in there. Home built is always best. Chuck
Case 1030 w/ Ford FEL, NH 3930 w/Ford FEL, Ford 801 backhoe/loader, TMC 4000# forklift, Stihl 090G-60" bar, 039AV, and 038, Corley 52" circle saw, 15" AMT planer Corley edger, F-350 1 ton, Ford 8000, 20' deck for loader and hauling, F-800 40' bucket truck, C60 Chevy 6 yd. dump truck.
redprospector
I have built a few dry kiln's in the past, some worked better than others. In my experience I've decided a constant even heat gives the best results, so I don't think you'd be happy with just the tempered glass. If you built a "heat collector" using the glass with some volcanic rock, or something to hold the heat for a time you'd be a lot better off.
Other than that I don't see why a container wouldn't work. You might want to insulate it though.
Andy
Woodchuck53
Morning Andy, up the road one of the customers has a oak chair operation. I think he does use a constant heat source. I'll have to get up there and talk to him about it. He uses old panel truck body's so that was why I thought a container would work. Not sure if he insulates them. It's not like there isn't enough scrap wood around here to burn. Thanks Chuck
