sharpening plug cutters
Started by ohsoloco, March 28, 2008, 07:46:51 PM
ohsoloco
Today I cut some walnut plugs for some breadboard ends on a couple coffee table tops.  It's a cheap plug cutter set I got from Harbor Freight years ago...it's done alright for me.  I think I could've started a fire today with some of the embers I made   :-\  The smoke was really cranking out of the holes.
How exactly do you sharpen a plug cutter  ???  It looks like the one in the link below.  I just googled plug cutter and saw this one first.
plug cutter
Ironwood
ohsoloco
Should I file the angled part right at the "tip"?  Any other parts I should touch up?
shopteacher
I sharpen them with a diamond sharpening stone and water.  Sharpen the bevel edge at the tip of the cutter. Try to maintain the same angle all the way around.  You could make a little jig out of wood the keep the angle consistant and maybe find a piece of rigid tube to fit over the shank of the plug cutter. That way you could lenghten it for a better grip and to rotate the cutter against the angled piece of wood and the face of the sharpening stone.
fstedy
Don't forget to sharpen the inside of the slot. I think you'll find thats where the cutting is going on not the bottom bevel.
Timberking B-20   Retired and enjoying every minute of it.
Former occupations Electrical Lineman, Airline Pilot, Owner operator of Machine Shop, Slot Machine Technician and Sawmill Operator.
I know its a long story!!!
ohsoloco
fstedy, I got to looking at the cutter, and it dawned on me that is what is doing all the cutting.  Just a dozen strokes or so with an auger bit file got me cutting wood again, not burning it   :)
