Author Topic: Husqvarna 346XP compression release?  (Read 4954 times)
Offline jjmk98k
  • Crystal, My Shetland Sheepdog and forever soulmate, REST IN PEACE 7 May 2007
« on: March 18, 2008, 06:50:18 pm »
quick question, does the 346XP have the compression release button, if not is it NOTABLY more difficult to pull start than comp release saws? reason asking, I thought I read a post saying that it did not......
thanks, Jim
Jim
Warminster PA, not quite hell, but it is a local phone call. SUPPORT THE TROOPS!
Offline Kevin
Re: Husqvarna 346XP compression release?
« Reply #1 on: March 18, 2008, 09:10:11 pm »
I'm pretty sure it's only on the 353 and not the 346.
Just pull it like a man, pull it like a logger... J.Browning.  ;D
Offline onionman
  • I'm no longer Brand new!
« Reply #2 on: March 18, 2008, 09:23:44 pm »
Mine does not..
Offline jjmk98k
« Reply #3 on: March 18, 2008, 09:49:50 pm »
advantage or not to have one?
sissyness aside, does it really help on wear and tear to have the comp release liek they say?
Jim
Offline beenthere
« Reply #4 on: March 18, 2008, 11:13:08 pm »
Jim
I have the compression release on my Stihl MS361, but never use it.
Advantage..?   don't know.
Offline letsgetitracing
« Reply #5 on: March 18, 2008, 11:45:27 pm »
  Just bought a 346 xp today with the grey side cover and the salesman said that that is the new one with 3.7 hp.  And i can tell you it screams especially once you take the rakers down and remove the screen in the muffler. wow is all i can say! for a light weight saw this is the real deal.
   We are going to put a 9 tooth sprocket and a 12 inch bar, it'll eat.  Mine has a black compression release the salesman also said that the different colors are for different rates of release the blue ones are for the bigger saws. the saw is very very light.
It also has the new type chain very bad to the bone
Homemade firewood processor, 200 ton log spliter, 322 cat excavator, 966 c cat loader, 3 semis, 11 trailers, 50 ton low boy 12 inch tree chipper 3120xp 394 xp 372 xp 3 365  357 55 rancher 346xp 338xp  stihl 056 mag ms 290 026 echo cs440  4 cs3000's  jonsered 2165 2150
go BIG or go Home
Offline ladylake
« Reply #6 on: March 19, 2008, 07:21:53 am »
9 tooth?  You must not be cutting anything very big.  Over on another forum a 7900 Dolmar took 3 seconds longer with a 8 tooth compared to a 7 tooth.   Steve
Offline KC
« Reply #7 on: March 19, 2008, 11:31:48 am »
The very first models didn't have one. Everything after that should - on the right side by the handlebar.
WHS full!
« Reply #8 on: March 19, 2008, 11:41:00 pm »
  The place only had the 8 tooth 325  pitch sprocket so we too the clutch off and put the new bigger sprocket on and the chain speed is alot more.  No it's a 5 inch diameter and smaller trim saw not for blocking firewood hense the 12 inch bar i have the 365 class for that
go BIG or go Home
