Pecan logs.
Started by deeker, March 07, 2008, 05:52:10 PM
deeker
A client here in utah, has several pecan logs and wants me to cut them 4/4.  He is asking the value of it as green wood.  Any ideas?  Thanks.
Kevin Davis
Ruff cutts
To those who fight for it, life has a flavor the protected will never know.  On an empty C-ration box.  Khe-Sahn 1968
Warbird
I thought you were talking about this.  ;D
deeker
Actually, I am trying to find out the bf price of 4/4 green pecan.  The owner wants to sell some if after I cut it.
Kevin Davis
Ruff Cutts
LeeB
I think it sells about the same as hickory. Don't quote me. I never sold a stick in my life.
Warbird
Any local mills in the area you could call and get a quote from?
deeker
Not much pecan in utah.  None of the mills I have talked to have ever cut any.  How would I find the hickory price?  Not real common in utah either.   8) 8) 8)  Found the price.  A bit pricey but it works!!  It is about $4.50 per bf.
Kevin Davis
Ruff Cutts
LeeB
$4.50BF sounds like a KD price. Not likely to get that for it green although you might considering where you are.
Woodwalker
Long way to Utah, but a local mill around here has 4/4 FAS/SEL kiln dried pecan/hickory is $2.65bf.
Just cause your head's pointed, don't mean you are sharp.
