Need Advice From Cedar Expert
Started by dail_h, May 17, 2003, 04:29:40 PM
dail_h
   I backed into a shot of cedar logs today,problen is one of them is rotten-hearted. Big ole thing,about 30 india.but a lot of wood around the rot I want to try splitting as for post,then have Mr Spruill saw it 1/8 for woodweave.Am I wasting my time and energy? The rest seem ok,one dead and dry,two more still standing,the farmer is going to cut them for me this week.
World Champion Wildcat Sorter,1999 2002 2004 2005
      Volume Discount At ER
Singing The Song Of Circle Again
Fla._Deadheader
Unless you have lots of cedar available, I would saw whatever the thing would make. At 30", there should be a lot of sound wood, I would think.
Oregon_Sawyer
I don't know if I qualify as an expert, but I cut alot of cedar.  Last weekend I cut a log truck load of cedar.
I cut a cedar with center defect like this: I  cut it just like I would any other log.   I cut each side and then cut one side down untill the defect starts to show.  Then I turn and do the same on the other sides.  At that time I see if I can cut the defective end off and still have a usable short log.  If not, burn pile time.
Loren
Sawing with a WM since 98. LT 70 42hp Kubota walk behind. 518 Skidder. Ramey Log Loader. Serious part-timer. Western Red Cedar and Doug Fir.  Teamster Truck Driver 4 days a week.
Kevin
I see a substantial amount of heart rot in the cedar I cut.
Most can be milled but some aren't worth it.
On a large log I'll make one flat surface and use these for small light duty bridge stringers back in the bush because the sapwood is good.
I use the flat surface to nail the deck on.
Percy
Im no expert on Cedar either but when I get a large butt that is rotten in the center, the sound wood around the rot is usually clears($). If you can split it,and putt each half/quarter/whatever, you get all vertical grain clears...they lovem around here.
Maybe cedareater will stop buy and tell ya'll how to cook what you dont saw. ;D
dail_h
It's always food time here on theFF :D :D :D Thanks guys
Tim
The wife wants to open a restaurant Jeff... If your cedreater has any published recepies, she'd be interested in buying the book... Might help me get rid of my sawdust pile to boot... :)
Eastern White Cedar Shingles
ARKANSAWYER
  Percy is right that it is good to saw them as the side wood is clear.  Some times it runs the whole way and others just a little.  It is a crap shoot but often worth it.   I would saw them all.
ARKANSAWYER
ARKANSAWYER
dail_h
   Spent a good part of today working on the cedar logs. The butt of the first log was already split,so I finished it into 4 pieces,3 on the first load. Second tree got 3 good 8 ft logs and a short.After I got here and unloaded found fence in butt.Returned to finish first tree got two more logs out of top.I gave out of steam befpre I finished.Tomorrow will try to get last logs and any bits that might be valueable for turners or carvers
