Firewood Kiln from Shipping Container
Started by evergreenforestmgmt, February 19, 2008, 08:40:40 PM
evergreenforestmgmt
Hello everyone,
       I am a firewood producer in the northeast who is looking at building a firewood dry kiln out of a shipping container.  It would be a run by a wood chip boiler.  I have seen set ups and kits on the internet that are very expensive.  I'm pretty handy, but not quite sure on how to build one.  Does anybody know much about these, or could direct me to some information.  Thanks a lot.
Kelvin
Howdy,
Well i guess you wouldn't be worried about lumber degrade so i guess you would just put the heat to it and have circulator fans and make sure the air could get through the lumber.  If you don't have the container yet, why bother?  I would just build a hoop house with greenhouse film and load firewood inside for the summer.  My hoophoue could be 100 degrees warmer than outside temps and it cost me nothing to heat, and its not sunny here.  Why not go solar?  You could even simply make moveable pvc house with greenhouse film to put over stacks.  Skip the work. I've dried lumber in my solar kiln for quite awhile till i added a wood burner to make up for my cold overcast winter days.  If i wan't impatient they work great, and you could make just about any length for not much $$$$
KP
Dave Shepard
How are you going to load the container? Any added labor is going to eat up profits.
Dave
Don_Lewis
If you are serious about drying firewood as a business, then you should install a system that burns wood and can heat the chamber to 225-235F. That means that hot water is out but hot air can work and steam can work. You will burn about 25% of your total supply to dry the remaining 75% but what you burn will be the stuff that you wouldn't package anyway. You certainly can dry wood with solar and hot water but it is slow and/or not predicatable enough to base a real business upon. If you are in an area where people are paying very high prices for firewood (like near New York City), you can justify a slow system using hot water heating and much lower production
You can buy hot water coils, fans, vents and controls and make a firewood dryer that will work. There are various grades of coils and their price varies widely. The BTUH rating can be comparable but the life expectancy varies a great deal.  Same with all the other parts and pieces.
Don_Lewis
By the way, make sure you buy a refrigerated shipping container. You cannot insulate an unisulated container well enough to have it last and by the time you insulate an uninsulated container, you will have spent more than you would on a "reefer" and have a poor chamber
evergreenforestmgmt
Hi Guys,
    Thanks for your replies.  I have read about those solar kilns and think they are great, but I move a lot of firewood and don't have all summer to get it dry.  I need to be drying wood every day of the year pretty much.  I think a solar kiln would work good on smaller scale operations, but I already have some of the components for a dehumidification kiln.  I have the boiler and an endless supply of waste product to feed it.
      I would like to set up a storage container and have racks built that I could load approx. 1/3rd of a cord in each basket right off the processor.  Then I could load the container with my skid steer.  That would be pretty easy handling.
     I plan on finding a reefer trailer somewhere.  If I can't find one near where I live, I'll get a 40 foot high cube trailer and spray foam the inside.  I was wondering if anyone had built one of these and would be able to give me some advice.  Thanks
KnotBB
To forget one's purpose is the commonest form of stupidity.
scsmith42
Don, if I recall correctly the commercial reefers / insulated containers do not make good choices for high temp kilns because the insulation starts breaking down above 160F or so?
EGFM, ditto Don's comment on converting a non insulated container into a kiln; I've done this and in hindsight it was not cost effective.
There are two big problems with containers for kilns; the non-insulated ones will rust out over time, and ingress/egress from the end of the container is a real pain - you will need some type of track and cart system at a minimum.
I think that it's better to stick build something that is optimized for your needs.
Scott
Tom's 3638D Baker band mill
Don_Lewis
Urethane insulation is usually used in reefers and it can tolerate higher than 160F (72C). I would not worry about it at 225F (108C). But if it is extruded styrofoam, 160F is tops. White EPS should be kept iunder 140F
MikeH
 So would that pink foam board from box stores be okay in a solar kiln? I think that is extruded?
evergreenforestmgmt
scsmith,
     Can you describe your kiln that you made?  Did you use steam or hot water?  I would like to use steam for mine so I can get it hotter than hot water in the kiln.  I would have a track system with baskets that I could move in and out with a skid steer.
      I'm kind of set with a container set up rather than a stick building because I don't want anything that is permanent and can't be moved easily.  That is why I think a container would be better for me.
Don, is there a way to tell if an insulated refer trailer is in fact urethane insulated?
KnotBB, I've looked into that particular website, they are very expensive through them.  Plus I like a good challange of building it myself.
I'd like to talk with someone who has knowledge of how to set one of these kilns up using steam and what components to use.
Don_Papenburg
From the FoamulaR  booklet ,  Architectural Notes    ..... should not be used ...........where temperatures exceed 150 F.  It is not recomended where sustained temperaturs exeed165 F.
Dan_Shade
unless you really know how to fit pipes, I'd avoid the steam...  dangerous stuff.
lots of dull bands and chains
logwalker
I don't think the steam needs to be pressurized, it is only a medium for the heat. Where steam leave the surface of non-pressurized boiling water it is 409 deg. at sea level. At least that is what I remember from my high school class 40 years ago. I could be wrong. :D
If it isn't pressurized, isn't it really water vapor?
Reddog
Furby,
From Wikipedia
"In physical chemistry, and in engineering, steam refers to vaporized water."
So yes all steam is water vapor.
scsmith42
EGFM, I sent you a PM with some info about my kiln.  No steam here - I use a Nyle 200 / Woodmizer 4000 dehumidification system with a Delmhorst Kil-mo-trol Plus.  Overall I have been very pleased with it.
Scott
I was taught that steam is invisible (as the rest of your quote should say) and as soon as you could see it as it cooled it was considered water vapor.
Under pressure it maintains temp longer and stays as steam.
But yes, I guess I do think your quote is correct Reddog, and my question is probly purposeless. :)
Greg Cook
I had kinda thought that when it comes time to build a kiln, I could take a shipping container, cut me a nice round hole at one end so I could slide in and old boiler, steel pipe with a cap welded on, or some type of heavy steel tank.  Just something plate steel and about  30" to 36" in diameter. I'll put the door for this "woodstove" outisde the container, as well as the flue pipe. I figured keeping a fire going in this stove with a few fans circulating would work nicely, there would be no sparks inside the container, and you could burn 3' to 4' slabs for fuel.
Just a rough idea, and it could be fine tuned when running.
"Ain't it GOOD to be alive and be in TENNESSEE!" Charlie Daniels
evergreenforestmgmt
Hi, Just starting to get back to this subject, it's starting to get into that cold weather season up here already.  Not sure if anyone will read this anymore, but I was thinking that Greg from TN has a good idea.  If you had a insulated shipping container, and built a set up that you could burn wood in that hooked up with it, and used the convection off the fire, you'd be able to heat the container very, very hot.  The hotter the better, and it would be much safer than steam.  It would be simple as there would be not water hook up to fool with, and no boiler.  What a great idea.  The only thing, is it would have to be fairly efficient, as you would have to fill it all the time to keep it hot.  That might be tough if you already had a full time job and weren't there all the time to keep it fired.
RSteiner
There is a firewood dealer just northwest of Keene, NH that is kiln drying firewood in what looks shipping containers.  They are burning saw dust to produce heat for the drying process.  They also debark all the wood that goes into the kiln.
I talked to the owner last fall about the process asking if it was worth the extra labor necessary to load the kiln.  The owner said the quality of the product was greatly increased and allowed them to charge a higher price.  I believe it took three weeks to dry a load to around 12% - 15% moisture content.  After running through the kiln the processed wood was stored under a large carport type structure to keep the rain off.
With all the bark off the wood dried better and was much cleaner for the people who purchased it.  Prior to this method of drying they purchased log lengths let them season for a year in log form then processed them.  The cut and split chunks were stock piled outside.  The wood on the outside of the pile was good and dry but the inside was always a little wet.
There is a bit more labor in the kiln dried wood but the finished product is much better.
Randy
Randy
kilndirect
I believe the company mentioned in the previous post is a customer of ours.
Timberline magazine wrote an article about their firewood drying operation in December of 2010.
link to Timberline article: http://www.timberlinemag.com/articledatabase/view.asp?articleID=3295
The article does not have any pictures of the kiln.
Some of the pictures on this web-page is of this kiln setup: http://www.kiln-direct.com/miniquickfirewoodkiln
Niels
PS: I know this is a dormant thread, but I think anyone seeking information will learn from the article.
jim king
If you do a search for ----container kiln----- there are a lot of photos and ideas.  1,140,000 pages.
As degrade is not a problem I would think using barrel stove and blowing the hot air directly in there would be simple and work well.  All you would need is a used kiln fan inside and some vents on top.
