carrage wheels
Started by bandmiller2, February 17, 2008, 03:26:10 PM
The flat wheels on the chase circle mill I'am restoring were a little worse for wear.Found some 10# barbel weights ,i had in stock ,machined out center for bearing and turned outside to the right diameter, good enough for this fat farmer.The made in china cast iron was quite good just a very thin chill on the surface.Keep it in mind for some of those hard to find wheels.
