"Linn Lumber's" Sharpener
Started by Fla._Deadheader, May 10, 2003, 04:06:33 PM
Fla._Deadheader
Anybody have one and use it?? How well does it work and who's blades do you use it on??  I can't afford an automatic unit, Don'T have enough blades for re-sharp and can't afford more of them. Tom is too far away and I need some sharp blades??????????
Mark M
Yea - I'm interested in this unit too. It looks like a pretty good unit and the price isn't too bad.
Fla._Deadheader
Mark, I figger while I use it, I can figger how to turn it into an automatic unit??
MrMoo
I had considered their sharpener but went with an automatic unit. I am glad I did. You might want to consider that these machines are a dry grind and the gritty dust goes into the air. Because of this I think you are are better off not being right up close to the machine while it is grinding.
I have also found that with the auto type machine you can set blades while it grinds.
Fla._Deadheader
Thanks, Mr. Moo. Right now I'm "In a tight" and can't afford an auto.sharpener. Whatever I do, you can bet it will have water on the cut. ;) ;D
