Resurfacing a diamond wheel for swingblade?
Started by fencerowphil (Phil L.), January 31, 2008, 07:10:32 PM
Has anyone out there ever tried "rebuilding" the diamond
rim of their sharpening wheel?  Did it work?
I have one to do of my own and would like to gather a few
worn out test subjects to try as well.
Phil L.
Bi-VacAtional:  Piano tuner and sawyer.  (Use one to take a vacation from the other.) Have two Stihl 090s, one Stihl 075, Echo CS8000, Echo 346,  two Homely-ite 27AVs, Peterson 10" Swingblade Winch Production Frame, 36" and 54"Alaskan mills, and a sore back.
Firebass
Phil,
Is there some kind of diamond dust epoxy or something?  You must know something I don't about diamond wheels.
Steve
When I accidentally damaged the wheel for the sharpener for my
Peterson, I realized that the compound on it was basically just a
cast layer of some sort of mix.  I am still using the damaged wheel
which is missing about 1/3 of its "stuff."  I am running out of time on it.
Diamond powder and Boron Nitride are available.
Epoxies and polyester resins of many types are available.
Obviously one could chip away and replace the diamond compound
on these very expensive wheels.  With the cost of these wheels being
so high, it's worth an experiment or two.  Of course, getting the right
mix of abrasive, binder and fillers is the problem.
PHil L.
