Auction Value ?
Started by Woodwalker, January 25, 2008, 10:42:17 PM
Woodwalker
We've got an in house employee auction that has a 1980 Clark electric fork lift up for bid. 2,150# lifting capacity, less than 2 year old battery, good condition and charger included.  Anybody got an idea of what the thing is worth? ???  ??????
Just cause your head's pointed, don't mean you are sharp.
I've seen a lot of the little ones like that sell at auction here for between $250 and $750.
Hardest part is the chargers are usually 3 phase.
Some of the cheaper ones don't have a good battery.
They don't work good off pavement. You can use them a little on hard packed gravel, but it's REAL easy to get stuck.
Is it a three wheeler or four?
rebocardo
Maybe $1000 tops. I just checked, all the nice 5k ones (newer Clarks too) on Craigslist Atlanta seem to run between $1700-$3500.
Woodwalker
Furby, I was thinking more along the lines of using the battery (new 9-06) for a solar/wind set-up. I have several different projects to use the hydraulics on. Then, scrapping whatever else I can't find a use for. The auction is only open to employees and the bid is so low now I' m embarrassed to say the
rebocardo,  That's about the range I had in mind. Gonna get out of the bidding before it gets that high.
Thanks for the information guys.
