Unisaw blade and dust?
Started by Brad_bb, January 22, 2008, 01:07:53 AM
Brad_bb
I recently acquired a 1953 Unisaw in the best condition you'd ever want to find.  Two questions:  What would be the best blade for me to get for it (10").  It currently has a 10" Craftsman carbide tipped blade, but now sure if it's cutting as fast as it should.  Also, do you guys take the time to clean pitch etc off a blade?   I have lacquer thinner handy so it wouldn't be much trouble.
Lastly, my unisaw didn't have the dust collection cover that goes over the motor when I bought it.  Are there any reproductions available?  Sure i could probably take the time to make a wooden one, but I'd rather have an original if possible.
Thanks, Brad
flip
Depends if you are doing a lot of ripping or crosscutting.  I use a thin kerf Freud for ripping and if I am doing much crosscutting I put in a Forrest Wood Worker 2.  The Freud line is less expensive and does a good job for the $$.  I generally don't have a pitch problem with the woods I use.
Timberking B-20, Hydraulics make me board quick
metalspinner
I stopped switching blades around when I recieved the Forrest Woodworker II.  It is a very nice blade.  Sending it out to get resharpened is a pain, though.
Larry
Blades I use...and even with pictures for your enjoyment.  Reply #37 on the second page.
https://forestryforum.com/board/index.php/topic,24381.20.html
I worked in a shop where we sawed a lot of Formica for signs and also quite a bit of hardwood ply.  We cleaned the blades maybe every 10 to 20 hours with lacquer thinner.  In my home shop, with just hardwood I still clean with lacquer thinner...but it might be several months apart and only if I need a perfect splinter free cut.
For rectangular motor covers I have been buying Grizzly...you have to fab up a hinge.  If it is a egg cover which I suspect you have good luck.  Originals come up for sale on eBay and there are some reproductions out there...both are quite expensive.
Brad_bb
Where are these repos?  Someone else mentioned it on another site (owwm.org) but didn't tell me where to look for them.  I haven't found any repos via google.
Thanks for the replies on blades.  $110 for a blade is pretty expensive, but if it's worth it, it's worth it.
shopteacher
Take a look at the systematic line of blades.  I use them at school and at home. I also have the Forrest blade and dado set at home.  The Forrest is only slightly better than the systematic from what I've seen, but a lot harder on the pocket book.
I've seen the egg shape covers on ebay and they do go for a good bit, but haven't seen the repro's.  If you could find some one who had one you could layup one out of fiberglass and marine epoxy using the original as a mold.  Sand and paint it and only you would know.
Kcwoodbutcher
Google unisaw or delta parts, I remember seeing one from one of the aftermarket suppliers very close to the top of the list.
My job is to do everything nobody else felt like doing today
