Inlay Coffee Table in the Works.
Started by SwampDonkey, January 21, 2008, 09:08:48 AM
bedway
Fastening stretchers to legs on a table i normally use double biscuts. This also works good for the legs to the top stretchers. If the joint is going to be subjected to a lot of stress i use pocket screws also. Ive built hundreds of tables/stands with this method and never had a joint faliure,,,bedway
Table top mounted, ready for sanding and polishing.  ;D
WDH,
In the previous post you see the front and back rails? The cross members are inlayed into those first, then a strip of walnut 3/8" thick is fit into a groove about 1/2" deep. You can see one in post #23 on the back rail of picture two. Everything is super tight, in fact the glue causes a bit of swell and there ain't no way that's coming apart.
Anyway, the legs have grooves 1/4" deep into them cut 1-3/4"x1-1/2" for the rails. Once that  framework of the shelf with just the back and front rails and the cross members are jointed and glued, I slide that onto the grooves of the legs. The rails of this piece are about 1/4" thinner than the left and right rails. The left and right rail are glued and slid on last with and they keep the main shelf from sliding backward or forward with a 1/4" overlap that extends toward those cross members. The rails are all glued to the leg grooves. I never saw any need to biscuit or dowel them because everything is tight fitting with the legs tending to pull tight into the rails. The glue is very strong and I challenge anyone to remove those rails without busting the legs up in the process. ;D
Dave Shepard
Wow! That is really awesome SwampDonkey!  8) 8)
Dave
Dodgy Loner
Beautiful table, SD! :)  You've been working fast.  I can't wait to see it with a finish!
Hey Dodgy, long time no see.  ;D
Applying the finish today.  Got two applied already on the underside, shelf and legs. :)
sgtmaconga
I have been following this project and my wife just looked over my shoulder as she passed me. needless to say i now have another project added to my honey do list. great job
Measure twice cut once
Three coats of finish. Going to give a light rub tomorrow and add another coat.
Dodgy Loner
Looks great, what kind of finish didja use?
metalspinner
 8) 8) 8)
You work fast!  It must be cold up there. :D
That is another great project and had fun following it.  What's next??? ;D smiley_whip
Coon
Great job there Swamp.  I sure wshed my grandmother could have seen this table.  She woulda got right on making one for ya just for something to do.  ;)
Burlkraft
Good job SD   8)  8)  8)
That's one purdy table   ;)   ;)   ;)
Why not just 1 pain free day?
Loghead
great looking table and I bet its solid as a rock  ;D ;D ;D
lovin anything handcrafted with logs!!
Norm
Very nice SD, always enjoy watching your projects.
Glad ya enjoyed the show folks.  ;D  I'm sure proud of those tables. And your right Loghead, when you take that coffee table in your hands you know you got something.  :)
I just discovered something today while looking at some hardwood flooring and I'd like to know if anyone ever saws yellow birch crotch wood. I'd sure like to see what it looks like. From what I seen in the flooring, around the knots at least, it has figure much the same as walnut only thing it has a golden color to it. Yellow birch is nice wood to work with. Maybe roger 4400 can try some from his 40" Y. birch?  8)
IL Bull
Case Skid Steer,  Ford Backhoe,  Allis WD45 and Burg Manual Sawmill
Dodgy Loner
From what I've seen, most any hardwood can produce beautiful crotch wood.  Based on my (limited) experience, walnut just seems to produce crotch wood without bark inclusions more often than other species.  I've got some beautiful crotchwood stashed away from river birch, white oak, cherry, and walnut that's just sitting around waiting for my craftsmanship to improve the the point where I feel comfortable using it ;).
Yeah, yellow birch may be one of those trees with bark inclusions. I see some in Y birch burl products quite often, but it still sells well for good money. There is one fellow that produces $3000 bowls that wouldn't be any bigger than a football. Some include green stain or maybe foxfire fungus. Of course it's dead. I don't see anyone using crotch wood up here. But, I have not been to a lot of places to look for it. They mostly use figured woods like curly and birdseye.
ghulst
That is my kind of table. I love it. nice job.
    Gary
Lud
SD ,
           Nice top, nice table.
Yes, I wish I had one long before this. :)
I have a plywood table in the window now with my potted hardwood seeds.
Walnut, plum and oak. I put an extra 4 hours of light them in the evening.
Just potted them yesterday, so I won't see much sprouting for a
couple weeks at least.
cheers
