Hello everyone - new member here
Started by Mrs. Haytrader, January 19, 2008, 04:43:45 PM
Mrs. Haytrader
Hello everyone.  Just wanted to introduce myself as I am a new member here.  My husband (haytrader) speaks of this site often, and has for the past several years since he became a member.  Three months ago I quit the corporate world to become a full-time woodworker, and I have lots to learn!  I'm sure that all of you pro's out there have a vast knowledgebase that I can learn from.   :P
Mrs. Haytrader
Fla._Deadheader
  Well, Howdy, Maam  8) 8)  Welcome.  We been getting peeks at some of your projects. Looks to me like you could teach some of us a few things.  8) 8) 8)
faronskid
5 rugrats = no dull moments here
Welcome to the forum,Mrs.Haytrader.Good luck with your wood working skills.
Norm
ronwood
LT40HG25 Woodmizer Sawmill
LX885 New Holland Skidsteer
Kevin
Welcome Mrs. H.
What wood working projects are you projecting?
sgtmaconga
I would like to request you to post his honey do list. i want to see if my wife has a bigger list
Measure twice cut once
Hi Mrs.
Ask anything that comes to mind. Well let me rephrase that..... well anyway... Many of our posts might slant toward food, but we do what we can.  ;D
Hey Mrs Haytrader.  Good to have you along.
slidecreekdan
Welcome Mrs. H! 8)
Bout time you joined in here! ;)
Mrs. Haytrader
Hi there Furby, good to "see" you again!
And in response to your question, Kevin, "What woodworking projects am I projecting?"  Well, that depends on what Mr. Haytrader tells me ... shows me ... teaches me to do!   :-\  I'm sort of groping around in the dark right now .... feel like a babe lost in the forrest at times ... totally out of "my element" that I have been so comfortable in for so long.  I'm sure it will get easier as I learn.  But, there's nothing any nicer than the smell of sawdust, and being your own boss!  (Well, almost my own boss ... )  ::)
Stump Jumper
Welcome Mrs.Haytrader good to hear from you again. I was the one that Furby drug along to visit and camp out in the canyons of OK. and look at ERC.
brdmkr
Welcome!  I hope that you have worked out computer sharing time as this place sort of grows on you.  You may find that you both want to post at the same time.
Haytrader
Got that covered brdmkr.
She got a new lappy so I could have my puter back.
Haytrader
Mrs. Haytrader
Hi Stump Jumper.  Yes, I remember you, too!  And I am fortunate enough to not have to share my time on the computer now with Haytrader as he was kind enough to buy me a laptop of my very own!  Isn't he great???!!! 8) smiley_clapping
brdmkr
Well I'll be, already posting at the same time 8)
CHARLIE
Welcome to the forum Mrs. Haytrader!  8)  You'll enjoy it here and there is a lot of expertise to answer just about any question you can come up with.
In my opinion, the most important thing about working around sharp tools and cutting machines is to not lose any fingers, run your fingers or hand into a saw or cut yourself with a razor sharp wood chisle. When using the table saw, bandsaw or jointer, use push sticks to keep your hands clear of the blade. If the wood kicks out and you are pushing with your hand, you can't stop pushing fast enough and it's over before you knew it starteted. :o
Charlie
Mrs. Haytrader
Very good advice Charlie.  In fact, one of the very first things that I made was a push stick.  I saw one in a tool store and thought that would be pretty handy to have, so I went home and made one.  I use it all the time when I am ripping boards.  It's become my best friend when I use that monster of a radial arm saw.  I'm still a little leary of all those machines, and have great respect for them!  My favorite to use is the scroll saw.  I enjoy doing detailed work.  I also have had fun using the router making signs.  Haytrader bought me this sign maker kit with templates and everything to use, but after struggling off and on for two days trying to get the dang things set up, I just decided to throw them aside and go free-hand .... and I managed a lot better!  I used to be a professional cake decorater for years so I find it's a lot easier for me to "write" with the router free-hand.  Right now that's pretty much about all I can do ... unless you want to count all the mistakes I've made!   :-[
CHARLIE
Just remember that the router bit is spinning about 25,000 RPM and when you're done cutting to hold it away from you until the bit stops spinning.
Also.....I got rid of my radial arm saw 'cause I feel they are a very dangerous tool. The blade will have a tendency to climb on top of a board and walk across the top of the board very fast. If your hand or arm is in front of the blade, it will shorten your arm by 1/8 inch after the doctors reattach it.  I absolutely wouldn't rip with my radial arm saw. :o
You'll always make mistakes. Then you'll either have to cut a new piece or re-engineer your project. I always measure carefully, twice, before cutting my boards to short.
Charlie
Mrs. Haytrader
Yep, that's the road I've been down ... measuring & cutting wrong.  I'm ready to try a different route!  I keep thinking that someday I'm going to get this down ...  ::)
fat olde elf
Welcome Mrs. H !!  Early in this post I was going to suggest that you try working with a scroll saw. DanG, you are already there.  There is a lady in Tennesse that is an intarsia artist.
Google intarsia and you can find her.  She has great patterns for detail oriented folks like you.
Hope to see your work here on the Forum.  Paul R. aka Fat Olde Elf
Cook's MP-32 saw, MF-35, Several Husky Saws, Too Many Woodworking Tools, 4 PU's, Kind Wife.
At the very least you'll have firewood. Nothing wasted. ;D
Fla._Deadheader
QuoteYep, that's the road I've been down ... measuring & cutting wrong.  I'm ready to try a different route!
  No problem, Senora.
  Measure twice, cut once, shim to fit.  8) 8) :D :D
