Biscuit Jointer
Started by submarinesailor, December 24, 2007, 10:23:19 PM
submarinesailor
I need (want) a "better than average" biscuit jointer.  Do any of you world class wood workers have a suggestion as to a brand.
Bruce
Don K
Lamello is supposed to be high end. I just want a Porter Cable model 557.
Don
Lucky to own a WM LT40HDD35, blessed to have a wife that encouraged me to buy it.     Now that\'s true love!
Massey Ferguson 1547 FWD with FEL  06 GMC Sierra 2500HD 4X4 Dozer Retriever Husky 359 20\" Bar  Man, life is getting good!
isawlogs
 Well now I aint no world class wood worker , but , I do own a Makita that I really like .  ;)
   Marcel
pigman
I am not qualified to answer your question, but I have used a Poter Cable 557 for several years with some success.  :)
Kevin
I have the Dewalt and it does a good job.
scsmith42
Bruce, if you want "top of the line", you want a Domino from Festool.  It's world class and you can do things with it that none of the others would even think of.
Scott
Tom's 3638D Baker band mill
Larry
The biscuit joiner is probably the least used machine in my shop and I suspect the same in a lot of other shops.  It's pretty simple machine also.  I would get whatever is on sale or used.
Full disclosure...I've had a Dewalt for a long time and it has worked perfect after a little alignment when new.
Couple other thoughts...I would want a Krieg pocket hole jig way before the biscuit joiner.  I would also investigate the Festool Domino as it makes a joint better suited for a lot of applications...sticker shock is keeping me away from that one at present.
Sitting hear in the semi dark typing this and smelling the turkey roasting in the oven...life is good.  Merry Christmas to all. :) :) :)
Norm
Merry Christmas to you too Larry. :)
Bruce I've owned the Porter Cable for years and have nothing but good things to say about it. If you could find a used one all the better, I don't think you can wear them out.
Now I've been drooling over the Festool also but would like to hear from someone that owns one to hear if it's all that it appears to be.
woodhick
I have a Freud and have had good luck with it.  I agree with others that a pocket hole jig (Kreg) will be more usefull.  I use it more than the biscuits.  I agree also with the sticker shock of the Domino! :o.  Probably will never own one of them.  I will opt to cut mortises on my mortiser and use a slip tenon.  Just my opinion.
Woodmizer LT40 Super 42hp Kubota, and more heavy iron woodworking equipment than I have room for.
metalspinner
I'm with Larry on the usefulness of it.  My PC joiner has been collecting dust for a couple of years.  I'm not even sure which model it is. ::)
submarinesailor,
What do you foresee yourself doing with the joiner?  Making joints or for alignment on panels?
submarinesailor
Alignment of panels.  For some reason, I keep having problems getting the top surface to align.  Less sanding - I hope??????
Bruce
metalspinner
Have you tryed these clamps?...
http://www.woodcraft.com/family.aspx?familyid=321
They compress from all four sides of your panel so they hold all edges flat top one another.  The are fairly inexpensive considering how handy they are and their unlimited length.
submarinesailor
MS,
I like them.  Do you have any of them?  If so, do they work real good?
Bruce
metalspinner
Bruce,
I have several and they work as advertised.  I used some 8/4 ash for my bars.  A slight (1/32") crown in then really pulls things flat.  If the wood beams crown too much or twist a bit over time, a quick run across the jointer true's them up just fine.  My favorate featrue is that you can make the clamp as long as you need without running out to buy others.  A dry run to make sure the clamp is adjusted in the correct holes should be done to decrease glue up hassles. :D
ely
i use a porter cable but i also have a dewalt bisquit machine also. as for glueing up solid panels it seems i had less trouble when i used the doweling jig. i mean the panels lined up with less trouble with the dowels.
logwalker
I have the porter-cable and have used it for several years. I don't think you can find a better one. As for the Festool, it is a nice piece but it should be for almost $800. Have always gotten by without one. If you were doing high-end furniture it might pay but not otherwise. Joe
I use a Craftsman Professional that I bought back in 2001 and finally used it last winter and am using it this winter also. The biggest hassle is getting the biscuits. The local hardware stores don't like keeping the shelves stocked. If I buy the last bag today, go back in 4 weeks and there still are none on the shelf. I cleaned out all the bagged biscuits a local store had last winter and there were a few loose ones left. I went back a couple weeks ago for biscuits and those loose ones were all they had in all that time.  Went to Lowe's in Maine yesterday and got a bottle of 100 #20's.  In a huge store like that, they didn't even have all that many on the shelf either and they were practically hidden. You can use a splined edge to edge joint, which can be made with the table saw (router might be better) and probably a stronger joint anyway.  ;)
I just ordered 4 of metalspinner's clamps.  :)
submarinesailor
Swamper,
You beat me to it.  I had to wait for the eagle (US Government) to s$%t my pay check before I could order mine. I'm thinking about getting 4 of them.  How many did you order?
Bruce
ely
show me what clamps you guys are speaking of please. i sort of feel left out. ;)
Kevin
Ely, follow this link...
There might be a problem with the boards sticking to the glue from the project if it wasn't properly cleaned.
ely
thanks i was just looking at sme similar in the lee vally catalog last nite.
metalspinner
SD,
I wish I held the patent on those! ;D
Kevin,
A quick polyurathane finish on them will solve the glue sticking issue.  Believe me you only make the mistake of not finishing them once. :-[
Well from now on they are known as metalspinner's clamps.  ;)
They'll come in handy for my yellow birch table.  :)
logwalker
You can't clean it well enough to eliminate sticking. Just lay a narrow strip of wax paper across the glue and it will release.
