World's Smallest Spark Fired Engine.
Started by logwalker, December 20, 2007, 03:21:20 AM
logwalker
If you are interested in workmanship then you need to see this craftsman's handiwork. I was absolutely amazed at the scale. Get this: the bore is 1/8" and the stroke is 5/16". It is a push rod engine too. Joe
http://www.craftsmanshipmuseum.com/Luhrs.htm
sprucebunny
That's pretty cool. A 4 cylinder engine that will fit in your pocket  ;D
isawlogs
  The spark plugs must be on da small size ... !!!!
  Yep quite the craftmen , thats a special breed to have that much patiences and skill .  8)
   Marcel
Coon
I am guessing he musta had alot of spare time on his hands
Dave Shepard
They do a series on small engines in the machinest mag I buy, but not that small! Very cool. 8)
Dave
I've been fascinated by the scale model aircraft engines you can buy. They are pretty expensive, but WAY COOL.
They are MUCH bigger than those first ones, and use glow plugs, but are otherwise normal 4 strokes putting out about 4 hp.
4 cyl inline - http://www.osengines.com/engines/osmg1330.html
4 cyl flat - http://www.osengines.com/engines/osmg1320.html
5 cyl radial - http://www.osengines.com/engines/osmg1300.html
and even a mini Wankel - http://www.osengines.com/engines/osmg1401.html
Cheers
ely
those are cool, my brother always messes with stuff like that. he built a steam engine that was very small like those. seems like you got the steam from match heads or something. it really worked, he also had one you could hook to a air hose and it ran on really low pressure.
scgargoyle
I've been to his website (there's a link to it in that article). He makes his own sparkplugs, as small as 0-80 thread.
I hope my ship comes in before the dock rots!
