Author Topic: Economical wood finish?  (Read 7341 times)
Offline Cutting Edge
    • Rix-Saws CBN Wheels
Re: Economical wood finish?
« Reply #20 on: September 12, 2013, 07:11:52 am »
uncle larrys walnut stain
5 gal diesel
1/2 gal boiled linseed oil
1/2 gal unfibered roofing tar (more or less for desired color)
works well, lasts long, roll or spray
If you were to add wax to Uncle Larry's Walnut Stain, I assume you'd warm the wax up first, but would it stay dissolved in the stain?
I use a shaved wax finish on some of my bowls. All I do is scrape a block of wax with the edge of a knife and drop the shavings into a bottle of mineral oil. In a day or two it disolves, no heat necessary. I never tried it with diesel, but it seems like it would.
Like the looks of uncle larrys stain. I would add powered graphite ( $3.00 # from a farm store ) and deck sealer ( $9.00 a gal. ). Graphite to help keep the sun out and deck sealer to help keep the rain out.
I use the graphite ( 1 teaspoon to gal. of water ) for glass cleaner and use deck sealer (1/4 cup to qt. of minaral sprits ) for car wax. Like both of them better than anything you can buy.
uncle lloyd
Hello All,
I resurrected this old thread (1) because with the huge price increase in wood treatments and (2) to get the thoughts of others and possible variations or "special" blends others may have tried and improved the original recipe.
The "mix" sounds very effective, especially the reply/input of adding dissolved wax for waterproofing and graphite for UV protection.  Any thoughts of a substitute for the diesel fuel as the carrier, say: acetone, lacquer thinner, etc.?? ...something with a faster flash and MUCH lower odor with little to no lingering smell??
Sounds like the insects wouldn't care to bother wood treated with this as well!!  spidey-smiley  musteat_1  steve_smiley
"Winning an argument isn't everything, as long as you are heard and understood" - W.S.
Cutting Edge Saw Service, LLC -
 - Sharpening Services
 - Portable/Custom Milling and Slabbing
 - On-Site Sawmill Maintenance/Repair Services
Factory Direct Kasco WoodMaxx Blade Distributor
Offline beenthere
« Reply #21 on: September 12, 2013, 11:37:35 am »
Quote
Mineral spirits.
Offline WmFritz
« Reply #22 on: September 12, 2013, 01:59:10 pm »
I may try that recipe with the mineral spirits for a deer blind I just built from some red pine I sawed up. I think the smell from fuel oil or diesel fuel would be a bit too strong to be around all day. Even then,  I think I should wait till after deer season to treat with the mineral spirits solution.
~Bill
2012 Homebuilt Bandmill
1959 Detroit built Ferguson TO35
Offline brendonv
  • Arborist
    • www.VorioTree.com
« Reply #23 on: September 12, 2013, 07:07:02 pm »
Just posting so i dont lose the thread.
Good ideas here.  Ive been paying 33 a gallon for a benjamin moore product t finish the boards for my barn and house.  Paint cost more than the wood did.
"Trees live a secret life only revealed to those that climb them"
www.VorioTree.com
https://www.facebook.com/pages/Vorio-Tree-Experts-LLC/598083593556636
« Reply #24 on: September 12, 2013, 08:34:16 pm »
Mineral sprits would indeed be a decent carrier, but even the "low odor" spirits I have used, can still pack a heavy punch for quite a bit of time after application.
I just wonder if using a thinner with a fast flash would actually reduce the long term benefit of the mix since something like diesel or kerosene would help the oils penetrate much deeper into the wood...like good penetrating oil on a rusty bolt.
Offline Sixacresand
  • John and Nancy
« Reply #25 on: September 15, 2013, 08:46:03 am »
For the Chemical experts, I wonder if mixing boron with burnt motor oil has any preservative advantage.
Offline gspren
« Reply #26 on: September 15, 2013, 11:08:58 am »
  Since the walnut stain is mostly diesel I wonder if the red (off road) diesel would make much difference, might be nice.
Offline lgroves
« Reply #27 on: April 16, 2017, 09:07:47 pm »
Hello,
I am new to this forum. I have a new 300 feet long - 8 feet high wood fence that I need to preserve. I think I would like to use "Uncle Larry's" stain.
Should I use tar or used motor oil?
Got any idea how much of the mixture I will need to cover both sides of the fence?
What's the best way to apply it?
Woodmills1 - Your garage looks great! Hope my fence will look that nice!!
Many thanks.
Offline Kbeitz
  • Never enough time...
    • My Hobbies
« Reply #28 on: April 17, 2017, 05:30:54 am »
I'm with the diesel and roofing tar... This was done around 17 years ago.
I have a
machine shop
Wood work shop
And a Weld shop
And now a saw mill
and a bunch of new forum friends.
Offline lgroves
« Reply #29 on: April 17, 2017, 09:02:17 am »
oh ok. It looks as if the tar gives a black look and the motor oil looks brown.
Offline DelawhereJoe
  • Trapped in Delawhere
« Reply #30 on: April 17, 2017, 09:25:07 am »
The roof tar and diesel looks just like what you get from fence black. Tractor Supply has it for $33 for 5 gal. Only thing is they say its acrylic lacquer then they say its oil based and that it cleans up with water. I've got some old fence black thats looks and acts like tar now, I plan to mix with some diesel a paint the sides of my utility trailer.
Offline lgroves
« Reply #31 on: April 17, 2017, 10:57:31 am »
Another question...
My fence is 6 moths old and red mud from digging the post holes has splashed up on the bottom of the wood when it rains. Do I have to wash/rinse this off to have a clean surface before I apply the stain mixture? Since it's 300' long , it's far away from the water spout?? :-\
Offline Joe Hillmann
« Reply #32 on: April 17, 2017, 12:03:54 pm »
How long before the smell went away?
Offline ljohnsaw
« Reply #33 on: April 17, 2017, 12:54:21 pm »
Another question...
At the very least, I'd say try to brush the dirt off.  Are you planning to spray or brush/roll on the stain?
Has anyone used this as an interior finish?  Seems like the smell would never go away.
John Sawicky
SkyTrak 9038, Davis Little Monster backhoe, Case 16+4 Trencher, Home Built 38" cut Bandmill up to 64' - using it all to build a timber frame cabin.
Offline Kbeitz
    • My Hobbies
« Reply #34 on: April 17, 2017, 03:01:06 pm »
Soaked right in... The smell went away in about 2 weeks.
I have a
machine shop
Wood work shop
And a Weld shop
And now a saw mill
