12"x12"x16' beams
Started by Ivey, July 25, 2007, 01:02:42 PM
Ivey
Help on pricing beams.. Fellow called me and needed 24= 12"x12"x16' beams.(SYP)
  I never cut and sold beams this large before, Told him that I could. What should I charge per B/F.  I charge .50 B/F for framing lumber (SYP). Should I charge a little more because of size-- or a little less because of less cuts? ???
     Thanks, Ivey
Logmaster LM-4 , New Holland 4x4 w/FEL , Ford L-9000 tandem w/ prentice TS-33 loader, Nyle L200M, Cook's 4" board edger, John Deere 310se backhoe w/ forks
woodbeard
It seems odd, but it is best to charge more. Even though there is less sawing involved, there is proportionately more work in handling the logs/beams. Also, it is a very custom order, and logs that size and quality cost more than the ones you would saw 2x6 out of. Even if you charged $1 a bf, chances are the customer could not find the same beams at twice the price. That may be a bit of an exaggeration, but it is to illustrate a point. You will have to figure for yourself how much more to charge based on your particular circumstances. Definitely don't charge less, though.
flip
Are you supplying the wood?  I don't know much about SYP but it would seem to me that size and length would call for a premium.  So, cost of logs+your labor (fuel, blades etc..)+mark up=what you charge.  That looks to be about 192bf/beam or 4608bf for all of them.  Average 10-12 cuts per log to make sure it be good and true, works out in my head to about $2300 in labor.  I'd take that deal :)
Timberking B-20, Hydraulics make me board quick
Haytrader
Might as well round it up to $100 a beam.
Haytrader
flip
That is if you don't have to fell, buck, drag out, or limb 'em and if you have the support equipment to easily handle them.  If it takes an hour to drag off and stack the $$ goes up.
Engineer
I cut a bunch of 8x12x16' beams for my house, and lemme tell ya, if I was sawing them for someone else, I'd have charged a premium.  Those are a bear to handle.  I don't even want to think about how difficult a 12x12x16 out of SYP would be to deal with.  If you have the big forklift or the crane, fine, but it's still your time and effort.  I'd be trying to get more than $100 apiece for them, and that's assuming that he provided the logs.  Probably double that for beams from my own logs.
Ivey
I have a fully hydro mill, and also a FEL so handling the logs and beams will no be a problem. I will be buying the logs and having them delivered.
Dan_Shade
I'd do large beams by the hour. (hour for hour, not saw hour-meter)
lots of dull bands and chains
mike_van
I just finished a pile of oak [their logs] 4 of them, 15 footers, 24" dia average. They wanted all 2 1/2" thick by 8's 10's & 12's for bridge decking. Came out to 1000 bf, I charged .35 bf for it, 350.00. Took me most of 2 days. Fewer cuts with 2 1/2 yes, but I have to handle all those planks, I think some weighed more than me. I never did pick one up clean,  only 1 end at a time. Or, you slide, lever, whatever. Then move a pile with the forks. Lot of work in that heavy stuff. But boy, that log turner I made last year - priceless   8)
WH_Conley
Don't know abything about pine so I will use the numbers for poplar.
18" log= 196 bdft x .40 per foot= $78.40
20" log= 256 bdft x .40 per foot= $102.40
18" log will do a 12 x 12, if it looks like a piece of pipe, a 20 gives you some room to work. Don't even count the side lumber because of the possible trim cuts needed to get it on the money, also you don't know when or if you are going to sell the side lumber. Figure  $50.00 an hour for mill, labor and expenses. I would figure it at an hour per, shouldn't take that long, but if you are going to  err, do it on the cautious side. I guess if the customer would take the side lumber to that would make a difference, ready market, not waiting to get your money back, cause you paid for the whole log, not just the part he wants. I know that I can cut a 20" log into 2x12 and have them stackek faster than I can move the beam off the mill and stack it with the loader. Your numbers will be different but the principal is the same.
Hope that's at least clear as mud. ;D
Bill
Ron Wenrich
I think $1/bf is about right.  I used to get more than that for large bridge timbers made from oak.  I did cut some 10x20x10 in oak and got well over $1/bf.
If the buyer balks at $1, you can always come down.  If you start too low, you'll never be able to go higher.   ;)
Brad_S.
I'm with Woodbeard on this one. At LEAST a buck a boardfoot, two isn't unrealistic either. If it were me and I could get logs that size, I'd charge $300-$350 per beam. You may need to pay a premium for the size log you need and, like WH Conley said, you'll be buying a lot more wood than you need that will sit as inventory in the form of 1 or 2 inch lumber off the sides. Also, it's the law of supply and demand. Is there anywhere else the customer will be able to get beams like that? If so, find out what the competition would charge for it and either match it or price just below them but don't price way below them. If not, then he has no choice but to meet your price.
Before you commit though (or is it too late?) make sure you can find 24 logs 18-20" on the small end of a 16' log. They may not be easy to find.
Don P
I can buy 6x12 White Pine rough cants for $1.175/bf from the local log home co in 24-40'. Their better grade, dried and surfaced is $1625/mbf.
woodmills1
premium for sure where else can ya get them.   add ing in the handling too.
Ivey
 Thanks for all the input guys..All these heads are better than one.
    I live in pine country, Lobloly, longleaf so  finding logs is not a problem.
    The 12x12 beams are only part of the order he also needs 260 2x8x16
    so he will be getting the side lumber as well, if it will make a 2x8. I buy pine here by the ton, $55.00 a ton saw logs. The calulator says that a pine log 20" x16' weights about 1900 lbs, about 1 ton. So thats $55. per beam
plus some uppers for 2x8s. At .75/bf thats about $144. per beam or $89.
profit. With those #s do you think I will be OK. This will more than likely be a repete costomer. He has these beams treated, and uses them for bulkheads
Thanks everyone, Ivey
Brucer
My main customer sells D. Fir 12" x 12" boxed heart beams for $1.80/BF CDN. By comparison, 2" x 8" boards sell for $1.00/BF. Those are wholesale prices and my sawing charges are the same in both cases. The rest of the cost comes from purchasing logs (bigger ones cost more), handling the timbers, etc.
The species, market, and dollar value are all different from your case, but I thought the ratio of big timber to lumber would useful.
Bruce    LT40HDG28 bandsaw
Ron Wenrich
You could set your price like this:  lumber value = log value + mfg costs + profit.  You will have to figure out how much you will get in your side cuts to get a true lumber value.  You should end up with an additional 100 bf in side cuts.  At 50¢ on that, you'll get a lumber value of about $195
You get about $465/Mbf to cover your costs and profit.  There's not nearly as much cutting in your log, and you will get a pretty good overrun.  There's a lot to be said about repeat business.
Ivey
Thanks everyone for your insight, and thoughts, I gave the customer a price of .75/bf for the beams I am sure I will be ok with that. I could have got more I know, but the customer is getting a good deal, and I am making money so we both are happy, and I'll bet he'll be back along with his freinds
Thats what it all about, Right!!
Thanks, Ivey
Haytrader
Ivey,
Can you handle a little constructive criticism? Hope so.
You asked for advice on sawing these beams, and got it. Then you ignored it. This is a prime example of why this industry has some scratching thier heads wondering why they can't make it profitable. By you offering this product at a reduced price (at least according to other forum members), you have set the price in your area for beams and it would be very hard for another sawyer to recieve more for like product.
You stated you had the capability to handle the large and heavy pieces because you had the equipment to move them. Let me ask you, who bought and paid for that equipment? Was it free? Is it maintenance free? Is there any insurance on that equipment? Does it take fuel?.
I do not know how you make your living. Maybe you have a job and saw part time. Maybe you saw full time, in which case you should know what it is worth to saw these beams and not have to ask. Maybe charging more makes you feel as if you are making to much for the product. Have you bought a new car or truck lately? A major appliance? Have you had major repairs to machinery? Everything seems too high, I know.
Bottom line is, you may get repeat business from this customer, but now he expects a low price. I give my customers in the hay business a fair price and mention a better deal on repeat business.
Next time, take your fellow sawyers advice. Charge a fair price and you and your fellow sawyers will all make a good profit on your investment in machinery and time.
Haytrader
Brad_S.
I debated with myself long and hard earlier about writing a response much like the one Haytrader posted but decided to bite my tongue. I couldn't have said it any better. Thanks, Haytrader.
Ron Wenrich
Well, I disagree with your assessment.  His first question on the subject was that he is charging 50¢ for dimension lumber and asked if he should charge more or less for a bigger piece of lumber.  Everyone agreed more was the way to go, since it takes bigger logs and the pieces are heavier.  Your rub seems to be that he didn't go enough.
Ivey is satisfied in making an $89 profit on a $55 investment.  If its a free market, then each producer can set the price.  If Ivey can produce at a lower cost than you, he can charge less and still make a better profit.
We don't know what prices are in his area.  50¢ for dimension lumber may be his local market price.  We do a little better, but not much.  If he charges too much, there might not only be no repeat business, there may be no business.
Brad_S.
What you say is true Ron, but I went back and read Ivey's original post upon joining the forum. His milling operation is a retirement career. His equipment is most likely paid for and there is probably a pension check covering basic expenses. Ivey can therefore afford to live on less because his old job essentially subsidized the new one. The new career is basically just to earn some spending money. I can't help but think that if Ivey had to support all his equipment and expenses off the sawmill, he would find that selling lumber that cheap cannot sustain a small sawmill business. I always value prices you post as a guideline but they are always at the lowest end of what I can afford to sell for. You make your profit in volume. These small mills most of us own can't generate the volume you can so we must be more savvy in our marketing and pricing. The fact that Ivey sells his lumber for even less than you worries me that he's basing his pricing on factors other than sound business analysis of his costs.
Ivey,
I'm sorry if I seem to be ragging on you here, that's not my intent. If you can sell your lumber for 50¢ and still live a comfortable life, more power to you. It's just that this is an example of a pricing structure that I see all too often by my own competitors who are subsidized by other income sources but fail to realize that fact to themselves. Guess it strikes a nerve here. No disrespect is intended and I hope no offense is taken, it's just an opportunity to have an open discussion on a problem plaguing some areas of the industry.
Ron Wenrich
No disrespect taken or given.  I think its as good of place as any to bring out pricing.
I see things in a little different light.  Market prices are not driven by the small time operator.  They are driven by much bigger players.  If you can't produce a comparable product to larger producers, then you will lose out in their market place.  That's how the free enterprise system works.
Our prices may seem to be on the lower end, but that's what the market in my area dictates.  It reflects stumpage, logging and milling prices.  If you can't get one of those in line with the market place, you won't be able to compete.  Our milling costs are half what I've seen posted on this board.  Should I not take advantage of that in the market place?  Shouldn't I pass that on to my customer?  Or should I take advantage of my customer to artificially inflate the local market price to protect other producers?
The markup in this case was $465/Mbf from sawlog to product.  That's a pretty wide margin for someone to work in.  That doesn't seem to be way out of place.  What is the cost range you want to deal at?  It seems to me that you should be able to make a living wage at that rate.
I've been in the business for a long time.  I have seen small businesses that have flourished by picking up the crumbs of what us commercial guys don't want to deal with.  There's simply not enough volume to make it attractive to us.   That's the niche that small guys can fill.
I kind of look at this pricing thing as a difference between wholesale and retail.    Small businesses need to sell at retail to cover their increased overhead, while the larger mills can sell at wholesale.  As a customer, which one would you buy from given the quality to be the same?
mike_van
Kind of a side note on prices - Some 10 years ago a lumber yard not far from me was selling shiplap e. w. pine for .50 a sf. I used to tell people to go there when they asked me about shiplap. There was no way I would buy logs, mill into boards, dry it, plane it once, rip straight edges & shiplap for .50 sf.  At 1.00 sf it's still a lot of work for a one man show.  50 cents, I don't know how they did it. But, they're out of business now & I'm still here -
Frickman
I have one of those small businesses Ron mentioned. Today I sold 2 x 4 x 16 foot tulip poplar and 1 x 10 x 10 foot tulip poplar for a little over $1.00 / board foot. Around 2 mbf in all. All for barn lumber, log run out of better, number 1 logs, but not prime logs. How can I charge so much? These are crumbs noone else wants. There are big, wholesale commercial mills all around me, and none of them do custom orders unless you're a friend of the owner. These mills send people my way, and I charge a dollar foot or more. They have a problem that needs solved, and I'm there go-to guy. Niche marketing.
For a 12 x 12 x 16 I'd charge a minimum of $1.50 / bf, maybe $2.00. We have all hardwoods, no softwoods, so that inflates the price some. It's a free country and a free market, and I don't have a gun at their head. They can pay my prices if they want, or walk away if they want. 80% pay.
