Gas Cans
Started by Dugsaws, April 03, 2003, 08:54:02 PM
Dugsaws
Mobile sawyers, how do you carry your gas or diesel to the jobsite gas cans small steel tanks  plastic drums etc just trying to get an idea
Doug
ohsoloco
I usually either toss in the 5 or the 2.5 gallon plastic gas can in the back of the truck when I'm sawing somewhere else.  My mill has a 2.5 gallon tank, and the 20hp honda rarely uses up all the fuel in a day of cutting...but I usually average about 600bd.ft a day of 4/4 lumber.
One time while cutting at home I ran out of gas about halfway through the very last cut  >:(   Didn't have any other cans full, so I had to run to the station just to make a 4ft. cut  ::)
biziedizie
When I got my mill my brother in-law bought me some plastic cans full of gas as a present and that's what I use. Now I'm just waiting for him to bring some cans of diesel by for the tractor!
    Steve
Minnesota_boy
I used the detatchable tank from my mill for years until some critter decided it liked to eat gasoline filled plastic containers. I patched the hole, but it still leaks while carrying so I just leave it on the mill.   I felt it kept unwanted volunteer sawyers away from the mill as it had no fuel.  Now I carry a plastic gas container.  The one I like was made by rubbermaid, squatty can with a wider bottom, nearly impossible to tip over while bumping over the rough ground, but I can't find another like it and I don't think it will last much longer. >:(
ARKANSAWYER
  I have always carried 5 gal of gas and a gallon of chainsaw gas.  I make a habit of putting my fuel, extra water, spare tire, on the back or the truck before I hook up the mill.   I try to always have everything I need.  More then once I have gone for a log or two and spend a whole day in one spot.  Here it is often a long way to a gas station for fuel.  I fill up my truck on the way home and top off my tanks so I do not have to do it on the way to the next job in the morning.
    ARKANSAWYER
ARKANSAWYER
BBTom
Shortly after getting my mill, I bought a spare fuel tank.  I fill it up with diesel and throw it in the truck along with a spare 5 gallon plastic jug of blade lube.  Once when sawing over 2000 bdft in a days time, did I need to switch tanks before the end of the day, but normally just change tanks at the end of the day. I leave my saw on site at times, (when it is well hidden), so I just have to fill the empty tank and am ready to go for another day.  The 42 HP kubota seems to drink in small sips instead of large gulps.   8)
ohsoloco
Don't forget to bring extra belts with you.  I was on a job once and the drive belt popped off in the middle of a cut.  Luckily it didn't break....cuz I didn't have an extra, and didn't know what kind it took.  I called Norwood the next day and they told me the belt size....the local Napa had one 2-3 times cheaper than Norwood was selling them.
Kevin
Good point, Kevin, but the bulletin was inadequate to the point of irresponsibility. ???   While it is entirely true that the plastic liners, or any other insulated surface will spawn static electricty under the right conditions, and it is true that static can ignite fumes, the article implies that it is ok to fill a gas can in the back of the truck without a bed liner.  You should ALWAYS put the can on the ground to fill it, because the truck bed will fill up with fumes, which are heavier than air, making your truck bed a serious hazard until it is cleared of fumes. Static is not the only thing which can cause ignition. :o
Of course, this doesn't apply to foresters or sawyer/telephone man types, whose truck beds would probably benefit asthetically from a good explosion, if they could manage to contain a fume, to start with. ;D
For my 24 horse onan on the woodmizer, I carried a 20 gal drum, that was originally intended for mineral oil.  I syphoned from it until I realized that it would be much easier to store it on its side and gravity feed the gas through a valve in the 3/4" bung and through a plastic hose that would reach the ground where I put the fuel tank.  Prior to this I just used 3 portable fuel tanks.  I like the drum concept better because I am not tied to the filling station quite as tightly.
Now that I'm using Diesel in a 38 horse Kubota,  I have a 55 gal drum laying on its side with the same valve and plastic hose arangement.
These drums sit in a frame I made from 4x4's.  Two parallel to the side of the truck and two Nailed on top at right angles to form a trough that the drum sits in.  I've never had one move but considered strapping them down for awhile until I saw how stable they are.  Straps would still be a good idea, I just haven't done it.
When carrying bulk like this it is a good idea to manually empty the drums every once in a while to make sure that you aren't accumulating a bunch of water.  If the drums are tilted just the slightest little bit toward the center of the truck, they will hold a lot of condensation water without it getting to the valve to get out of the drum.
Kevin_H.
I'm with BBTom, I bought an extra fuel tank for my WM as well as an extra water tank. seems to work out the best for me.
Got my WM lt40g24, Setworks and debarker in oct. '97, been sawing part time ever since, Moving logs with a bobcat.
LeeB
even without a bed liner ,you should still put the can on the ground. static can't dissipate through rubber tires. LeeB
CHARLIE
Tom, strap that tank down! While it may be stable while driving normally, you don't need all that fuel all over you the road and everywhere else if you happened to hit something that would cause you to stop more sudden than you were prepared to....if you get the drift. :o  When you come to an unexpected sudden stop, the things not fastened down just tend to keep going. :-/  Strap it down......
Charlie
Fla._Deadheader
My engine is mounted a little higher than the fuel tank. I plan on using outboard motor gas tanks. They even have a "primer ball" for pushing gas to the carb after changing tanks.
Dugsaws
I carry mine in 5 gal containers also as my tank is not detachable, but sometimes i feel like i am the only one who does this,I am glad to hear i am not the only 1 now  thanks
Doug
Doug
I was surprised to find upon a safety inspection of our mill that the plastic cans are illegal in our commercial mill and that we must use steel cans. DanG me, but I argued the point and the safety man agreed with me but for the life of me I cannot remember why he said the plastic cans had to go. (we still are using them. ::))
LeeB
supposedly the plastic can cause static elec while filling and then explode from the spark. LeeB
Mark M
I have plastic safety cans that we use for heptane in the lab. They have a metal tab for attaching a ground wire. The hand-crank pump, barrel, and safety can are all connected with the ground wire. If you place your plastic tank on the ground (even cement) when filling you should be safe.
PS - I used to think it was silly grounding plastic, but static electricity doesn't need a good conductor to flowl. Just rub a plastic pipe and a piece of glass tubing together and see what happens.
Minnesota_boy
Contrary to Hollywood, gasoline is not explosive.  It is quite volitile and flamable, so you can get a nice fireball, but not a true explosion.  It requires a fuel-air mixture between 9 and 15 percent to ignite properly, which is why you get engines that don't start because they are not choked enough or too much.  If the safety man says explosion, tell him it isn't nitroglycerine in that tank.
chet
Minnesota_ boy I have to differ with you, are you familiar with the term BLEVE. Very small amounts of flammable materials are capable of tremendous explosions.
Minnesota_boy
Yep, I took a course on firefighting propane.  It still isn't the same as nitroglycerine or TNT, but the blast is quite impressive.
A mechanic at a shop we used to use said he cleaned his hands with hot gas. I said HUH? he said yep, heated it on the electric stove in the shop in a double boiler. I never saw it done but I don't think he was kidding.  I have never tried it. I'll stick to Sportsmans bar hamburger grease.
I'll bet he uses (used) a match to see how much gas was in the fuel tank too. :-/
Our fuel man said he would much rather haul gas then diesel per risk of explosion. He posed that question to me one time. Would you rather throw a lit cigarette at a pan of gas or a pan of diesel. (Stupid question but he asked)(stupid conversation for that matter :D) I was surprised that he would have picked the gas. He said that the diesel fumes were more volatile. dunno.
ohsoloco
My brother and I were talking about lighting gas a while back (for some reason).  When he was in Desert Storm they were burning (something...don't know what).  He wanted to see if his cigarette would light a pool of gas, so he poured some out, puffed on his smoke, and flicked it into the gas....the cig. fizzled right out in the gas.
