Rot resistance of swamp tupelo
Started by Jesse Frank, June 14, 2007, 08:02:48 AM
Jesse Frank
Hey guys,
I was thinking of splitting out some recently downed (bulldozed) water tupelo trees for shakes on a small outbuilding..... was wondering if this stuff has a good rot resistance. I have seen people use pine and red oak for it, so I thought I might give this a try. I was looking for cedar, but haven't found much of that yet! :)
There are absolutely no absolutes in life, and that's a fact.
I don't think that it is a notably rot resistant species.  Probably on the lower end of the scale I suspect.
Dodgy Loner
Water tupelo is near the bottom of the totem pole for both of the qualities you want in shakes: rot resistance and ease of splitting.  It has interlocking grain that will thwart even the most enthusiastic froe-wielder.  In your neck of the woods, red oak will be far and away the most desirable species for splittling shakes.  Find a nice one between 2 and 3 feet in diameter, and it'll really riven up your day ;D ;D ;D.
Jesse Frank
If it is truly Water Tupelo, there are carvers who will knock down your door to get some.  It is a soft wood, especially the base, that they treasure.  If you can get some and save the buttressed trunk, or saw into manageable blocks, you may have a windfall of dollars on your hands.  Check your area for a carving club or woodworking club with carvers.  If you have no luck and still want to pursuit it, check out Wood Magazines discussion groups.
Jesse Frank
Thanks Tom!
I got a bunch of it and have the ends painted and curing now. :)
