Modified my ATV log skidder
Started by PawNature, May 19, 2007, 03:05:12 PM
PawNature
Was thinking of buying one of those 3 point hitch attachments for ATVs. Was just DanG to tight to part with that much money. So I came up with this. Everything comes off with the pulling of pins so I can use the skidder as needed.
GOVERMENT HAS WAY TO MUCH CONTROL OVER OUR LIVES!!!!
Paul_H
It looks good Paw  8)
Is it a winch lift on the blade or a lever?
PawNature
Electric Winch. I am able to raise and lower it from the seat. Still have a little work to do on the wiring to make it permanent and a quick connect.
TeenSwinger
I bet you can skidd some logs with that four wheeler.
TeenSwinger
Peterson ATS 827  Nyle L200  Ebac 800  Bridgewood M-562
