Help with hinges
Started by brdmkr, May 17, 2007, 11:21:56 PM
brdmkr
I am getting ready to hang the doors on my bay door fo the shop 8).  I really don't know what these doors weigh, but they are heavy.  I figure 200 lbs or so, but that is just a guess.
I have 8" 'T' hinges that were given to me.  They are new and appear to be realatively heavy duty, but I am having second thoughts  ???.  How would you guys hang one of these these doors?
There are 2 of them and they will meet up to form a diamond shape.  I would really prefer a hinged door as I think I can make them seal up better.
Those T hinges otter work ok if ya put 3 of'em on each door.  I'd anchor them well, though.  Bolts would be best, but nice, long lag screws otter work ok.
isawlogs
Nice doors, I am building a set somewhat like those ,one will be 40"wide , the other18" . These will have " T " hinges also . Bolted through the doors andlagued into the wall .
  So , did you put yours together ....  and if so , how did you go about it .  ???
   Marcel
brdmkr
Thanks for the opinions on the hinges.  I think I will go with bolts for the install.  I really don't want them tearing the wall out :o
I put the doors together myself.  Every board is 3/4 x 6 SYP.  The edges are 3 layers thick as is the middle cross.  The 'panel' is ship lapped with one nail  in each end to allow the boards to expand.  Every other panel board has one screw in the center of the front diagonal.  There is also a diagonal on the back.  Boards that were not screwed to the fron diagonal were screwed to the back diagonal.  This pulled everything together really tight.  Also, all of the edge pieces and the cross piece are glued and screwed for strength.  They seem to be pretty stout doors.
thurlow
We started our shops at near-a-bout the same time;  I still gotta put on a front porch and lack about 2 days boxing the inside.  I looked at strap hinges at the big box stores, but they had too much "slop" in them to suit me.  When I had cattle and numerous corrals, I built my own hinges by the dozens......3/4 inch cold-rolled rod, 3/4 inch black pipe and 3 (or 4) inch by 1/4 inch flat metal.  I found 4 in my scrap pile and used them.......will have to build 2 more to have 3 per door.  My doors are heavy, also.  I used 4 inch (or 6 inch depending on where) lag screws to hang 'em.  Gotta put some more screws in;  didn't realize I only had 4 per hinge 'til I was taking the pictures.
Here's to us and those like us; DanG few of us left!
Thurlow, ya been sandbaggin' us!  I didn't even know you was building anything.  Nice lookin' building! 8) 8)
thurlow
DanG.........I've got a modicum of woodworking tools, but they're scattered over Hade's half-acre.  Still got my farm shop, but it's a mile down the road and not set up for woodworking.  Always said when I retired, I was gonna build me a shop here at home.  It's only 24 by 30, but will have to do.  Studs and rafters are big-box store; everything else is homegrown/homesawn yellow popular.  Been working on it almost a year..........by myself.......in between everything else    retirees gotta do.
Oh yeah.  I remember seeing them pics now.  I guess my brain retired before the rest of me, eh? :D :D
How 'bout emailing me a plate of them ribs? ;D
brdmkr
Thurlow,
I like your hinges.  They may work a little better that what I have.  I may have to see if I have the skills to weld some up.
Your shop is looking good!  You are a little farther along than me.  It has taken me about a year as well.
Fla._Deadheader
When I had the farm in Ark. I found the best way for me to hang heavy doors, was them lag type gate hinges. One pointin up, one pointin down. Plenty stout and mostly burglar proof. You can always adjust 'em a little, to line the door up with the frame.
isawlogs
 I make mine some what like Thurlows ,  once done hanging I weld a washer on the top shaft ... and a tack on the lague , that is when I dont have a carriage bolt in dere ... still gets a little weld to um . Keeps dem light figured little Dangs out ....  ;)
   Marcel
rebocardo
On heavy doors I use four hinges. What I do is put put all the hinges on the jamb side in, then position the door where I want it. Bolt the top and bottom hinge on, swing it open (hold it up) and close. If nothing binds, close it, bolt the other two hinges on.
If I have access to the backside of the jamb (like a barn or shed or I have removed the trim) I bolt the jamb side too. You can use a pan head type threaded screw and counter sink the steel with a larger metal bit.
The reason for doing this is to prevent thieves from crow barring the hinge from the jamb since even 3" deck screws can be pulled out with a big enough bar, but, bolts with washers can not. The have to break the (2) 2x4s.
Nice work Thurlow, even with a crooked slab ;D.
isawlogs
I was so sure it was done purposely I never mentioned none of it . Knowing how long it could take to get the building up and covered , I figured he did not want any water to stay on da slab ....  Call that good enginarin  :P  Yes sir ......
   Marcel
thurlow
Quote from: WDH on May 18, 2007, 04:31:14 PM
a crooked slab ;D.
I can't tell if you're gigging me about my pictcher-taking or my concrete-pouring.  ;D  Probably my camera was whompy-jawed.   :)   I guess I lied when I said I did it all myself.  Hired the slab formed up and poured.  I did haul the several yards of dirt to APPROXIMATELY level the site.
I hate it when I get a-hold of a whompy-jawed camera :D.  That is a fine shop, Thurlow.  When DanG and I come to visit, you will have to whomp of some of those other slabs, and I don't mean concrete ::).
We goin' ta see Thurlow?!  HotDiggityDog!  I'll pick ya up at 5am tomorrow!  YEEHAW!  This is gonna be fun! 8) 8) 8)
isawlogs
Dan,
  Have a nice visite , check out dat camera of his and whomp its jaw to unwomp da jawed in it ....
   Marcel
The shop was nice...........those ribs looked sorta invitin'..........one thing leads to another........
I ain't whompin' nuttin but some of them ribs!  I'll just let down the jack on that trailer a bit, and the slab will look level, even if it ain't. ;D 8)
We will have to go by and get Brdmkr too.  That way he can research hinges while we whomp those ribs ;D.
Yep, I kin pick him up on the way by his place.  He ain't gonna have time for hinges, though.  He gotta whomp us up some bread to go wit dem ribs! ;D
brdmkr
I'll make the bread, but we can stop by my Ma's on the way for a warm-up meal.  My Ma is not too far away if I remember my TN anatomy (she is in Selmer).
Hey Thurlow, I really will be up TN sometime this summer.  How far are you from Selmer?  I'd like to see that shop first-hand!
BTW, I bought some 10" T hinges that have a good bit more beef that the 8 inchers I was given.  They cost about 7 bucks apiece, but I don't want my doors sagging.  I also picked up some 8" long 3/8" lag screws.  I'm hopin to hang thme doors tomorrow 8) 8) 8) 8) 8)
thurlow
'Thout looking it up, I think Selmer's about 2 hours from Ripley.  If your Mother's there, I'm sure you know about  Shiloh National Military Park and Cemetery.  Here's another link.  It's the only major Civil War battlefield which I've visited;  it's still very rural/undeveloped;  a truly hallowed, sacred place.  Just down the road is Pickwick Dam, Lake and State Park.   Used to be, you could tour the power house, locks, dam, etc, but the last time I was there, the events of 9/11 had stopped that.  Fort Pillow is about 20 miles from me; it's a State Park and nothing remains of the original except breastworks.  Even the river has moved away.  There is a small museum and some cannon.  The greatest cavalry officer (IMHO) of all time.......actually his troops were more dragoons than cavalry........caught a lot of grief for the battle there.
brdmkr
Thurlow,
I have spent many an hour at Shiloh and at Pickwick.  Pickwick for the fishing and Shiloh was always good to help me think through things.  I spent a good bit of time at the cabin in the peach orchard.   There was just something about that site that always helped me focus in on the important things.  I could stand a visit there now.
